European Odds – A Basic Form of Football Betting > 공지사항
작성자 wintips
댓글 0건 조회 3회 작성일 25-04-15 11:57
European odds are one of the three fundamental types of bets that every bettor should understand when starting out. You simply need to accurately predict one of the three possible outcomes of a match to win a prize. However, don’t be overconfident—start with the following basic knowledge provided by Win tips.
Basic Understanding of European Odds
European odds are a popular betting format found in all matches listed by online bookmakers. Bettors place wagers on the outcome being a win, loss, or draw for the home team.
This type of bet is also commonly known as the 1X2 bet, which corresponds to the following three options:
Option 1: Predict that the home team will win the match.
Option X: Predict that the match will end in a draw.
Option 2: Predict that the away team will win and take all three points.
With these three options, players won’t need too much time to grasp the concept. You have a 33.33% chance of winning with this bet. However, winning consistently requires careful match analysis. That’s why applying basic knowledge properly is essential to achieve success.
Starting to Bet with the Odds Information on the Platform
Simply reading the above information gives you a basic understanding of how European odds work. Still, you should pay attention to the odds details provided on the sports betting platform. Understanding the data will help you make better decisions using insights from the top 5 betting sites.
How to Read European Odds on the Betting Board
When reading the 1X2 odds on the board, take note of the following:
Bet Type: 1X2.
Team Names:
The team listed first is the home team.
The second team is the away team.
If neither team is the home team, a (N) symbol will appear next to their names.
Betting Time:
Full match bet: 1X2 FT (Full Time).
First half bet: 1X2 HT (Half Time).
Payout Odds: The payout rates are shown next to each team name.
AD_4nXcBFuXf3w61HlsPSjB_dcMtg8ZTXN4maFXPbaWqjwWbnuOlZLKLcOnvHLRiPFfO6HLpNv0xrDf6stxRJhwujuslTFQX5TbZQUKH17NjzJDVpnpPk-bnRihOf6US1hBPyEOEe1AEFYr78TFGIMBVDzg?key=xRz80FYIarY-RqEaNBBwVg
Understanding European Odds with a Real-Life Example
The data above makes it easier to understand the 1X2 format, but applying it in a real match is the best way to learn.
Example Match: Aston Villa vs Brighton (Premier League)
The bookmaker offers the following European odds:
Odds Type: 1X2 FT
Teams:
Aston Villa is playing at home.
Brighton is the away team.
Payout Odds:
Bet on Aston Villa to win: payout ratio is 2.49.
Bet on Brighton to win: payout ratio is 2.57.
Bet on a draw: payout ratio is 4.00.
Calculating Win/Loss with 1X2 Bets
Besides understanding the options and how to read the odds, knowing how to calculate your wins and losses is crucial. Since the bet isn’t based on any handicaps, the formula is straightforward:
Winning Amount (if predicted correctly) = Bet amount × Odds
Losing Amount (if predicted incorrectly) = Bet amount
Example:
If you bet 100,000 VND on Aston Villa to win:
If correct: 100,000 × 2.49 = 249,000 VND.
If incorrect: You lose 100,000 VND.
Winning with Proven 1X2 Betting Tips
The basic information above already gives you a good foundation for understanding the 1X2 bet. However, to truly become a winning bettor, you need to learn a few more valuable tips:
Use Asian Handicap Odds for Reference:
This is a useful way to predict the winner in a European odds bet. The team giving a handicap of 1 or more usually has a higher chance of winning. You can use this to make a more accurate selection.
Analyze All Influential Information:
Factors such as form, head-to-head history, tactics, player quality, etc., must be carefully researched. Finding connections among these factors can help you identify the potential winner.
Monitor Even the Smallest Odds Movements:
Always keep an eye on any changes in odds provided by the bookmaker. This helps you avoid “trap odds” set by some platforms. Don’t rush into betting on odds with high payouts—analyze thoroughly first.
soccer players that wear 19 European odds aren’t too difficult to get started with since they’re simple to place. However, to win consistently, you need to spend time practicing and learning from betting experts every day.
