See What Ghost 2 Immobiliser Reviews Tricks The Celebs Are Using > 자유게시판
작성자 Lashawnda
댓글 0건 조회 9회 작성일 25-04-27 02:01
Ghost 2 Immobiliser
Ghost is an wireless security system that safeguards your car from key-cloning and hacking. It connects to the ECU unit via the CAN data network. It is silent and isn't identified by thieves.
It is only possible to disarm it by entering a button sequence (like PIN code) you have programmed into your car with buttons on the steering wheel as well as the centre console.
Guard Your Car from Theft
With car theft on the rise and cars being stolen in seconds It is imperative that car owners consider the additional security measures that are available to them. Immobilisers are one of the most effective and established ways to keep your vehicle secure. Ghost immobilisers are an excellent option since they are small and concealed within the vehicle's wires. They also don't emit radio frequency signals. This means that they are untraceable and can be installed without affecting the vehicle's CAN bus system.
Our ghost immobiliser near you can only be disarmed with the pin code we installed at the time of installation. This unique disarming sequence uses buttons on your steering wheels, doors, or centre consoles to prevent anyone from driving away your vehicle. This makes it impossible for thieves to copy your key or use jamming/spoofing equipment that can disable the standard immobilisers.
A ghost immobiliser will not hinder your car from being driven, but also stops it from being smashed for parts. This is a growing problem in the UK due to the growing popularity of these kinds of cars. It can happen within minutes. Ghost immobilisers from TTW are easily programmed to shield your vehicle from these types of attacks.
Installing our ghost 2 immobiliser can stop your car from being stolen at a service station or even if your car is being driven around the garage by an employee. The Ghost can be set to Service/Valet Mode, which will only allow you, the customer, to enter a unique button combination.
Contact us today if you are interested in learning more about our auto ghost immobiliser immobilisers, or if you'd like a no-cost quote. We'll be glad to assist and provide you with confidence that your vehicle is protected at all times.
No Key Fobs, LED Indications, or Key Fobs to indicate its location.
This car immobiliser that is not detectable integrates with your vehicle's CAN network to safeguard your vehicle against the latest kind of car crime. Contrary to other aftermarket CAN immobilisers, Ghost does not rely on key fobs or LED indicators to function instead it uses buttons in the standard factory controls that are already within your vehicle like those on the steering wheel, door panels, and centre console. This means a hidden pin code is created which must be entered prior to when your vehicle starts and is completely inaccessible to thieves.
The developers of the CAN-BUS device have also added additional security measures to stop the device from being hacked, or bypassed. It also has CAN-BUS blocking and a physical immobiliser cut meaning that even if your keys get stolen, the thief is unable to leave with your pride and joy.
308785165_499195788347328_5859105632268553197_nlow.jpgInstalling the CAN BUS in your vehicle is a simple and quick procedure that takes just 30 minutes. We will send a member of our team in your area to set up the time and place that is convenient for you. After your vehicle has been fitted, you will be given an identification number and security codes for your phone as well as the app to make it simple to use and ensure you are always in control of your vehicle's security.
The system is available on most modern vehicles but If you own a unique or vintage vehicle, be sure to contact us to determine if it's compatible. The supply and installation price of The Ghost Immobiliser 2 is APS449 and your car will be added to the International Security Register if fitted by one of our approved fitters. Do not hesitate to reach out to our helpful team if you have any queries. We look forward hearing from you.
Easy to Setup and Program
Immobilisers are installed in numerous modern vehicles to stop theft or hot-wiring. Contrary to physical deterrents such as lock locks for the steering wheel or wheel clamps, an immobiliser is hidden within your vehicle making it virtually impossible to locate and defeat.
The system works by connecting directly to your vehicle's CAN data network and stops the vehicle from starting unless you input a unique personalised code. The unit is compact and sealed, meaning it can be installed anywhere inside your vehicle, without the need for the need for additional wiring. It doesn't emit radio frequency signals, therefore it isn't detected by scanners or other code-grabbing equipment.
Ghost uses your vehicle's existing buttons on the steering wheel as well as the door panels and central console to create a customised disarm sequence (like PIN codes) that needs to be entered to authorise startup of your vehicle. The pin code sequence is dependent on 4 to 21 button presses and is easily reprogrammable if required. You can also place your car in Service/Valet mode to ensure that it is able to be operated, but the car is not able to start or drive. This will ensure that your vehicle is safe when you bring it to the mechanic for service or valet parking, and that the mechanic cannot access your pin code to turn off your system.
You can make use of our app to set an interim pin for your ghost device in the event that you plan to be away from your vehicle for an extended period of time, such as working or vacation. You can enter your pin manually when you drive the vehicle.
Our CAN bus immobiliser can also be connected to an electronic remote key fob or tracker (Brand dependent) which will take priority over the ghost 2 immobiliser reviews (try what she says) system. This can provide additional security if your vehicle is stolen or if your keys are lost.
If you're looking for a method to protect your vehicle from key-cloning or hacking contact us today to discuss how we can help. We provide our services across the UK and at our installation center in Derby.
Service/Valet Mode
Modern cars come with sophisticated stop/start systems that require the right inputs to function properly for example, battery voltage, engine temperature, external temperatures and what electrical systems are active. They can cause issues, and it can be difficult to determine if the problem is related to Ghost or not. This is especially true when the vehicle has been recently cleaned or valet parked. You can utilize the ghost service mode that allows the vehicle to start and drive temporarily without a pin code. This can be useful for when your vehicle is being serviced or valet at an independent garage.
Press the button for service five times to enter service mode. The indicator signal will flash twice when service mode is selected. This can be canceled at any time by entering a PIN code. After you exited the service mode the auto ghost immobiliser immobiliser will return to normal operation.
This is a very discrete system that communicates with the vehicle ECU through the CAN data circuit. It is directly connected to the original buttons of the vehicle and does not employ radio frequency signals like other immobilisers. This makes it nearly impossible for any other device or hacker to break into the system. Even devices that use spoof codes from an original key fob won't be able to affect this.
It is a TASSA certified anti-theft device that complies with the highest standards of protection. This includes the only vehicle marking system that is linked to the international security register which is an insurance company requirement.
The ghost immobiliser is extremely compact design and can be easily concealed within the wiring of your vehicle's factory, making it near impossible for thieves to track. It is a sealed device that is so small it can be placed in different places in the vehicle, such as under the dashboard or on the steering wheel.
The system makes use of the existing buttons within your vehicle (such as the ones on your steering wheel doors, door panels or the center console) to enable you to create a unique and changeable disarm sequence of up to 20 presses in length that must be entered before your vehicle will start. Anyone who has your unique pin code is able to enter it - so you, your family, your colleagues, or friends can utilize it.
