Why We Love Item Upgrading (And You Should Too!) > 자유게시판
작성자 Marko
댓글 0건 조회 49회 작성일 25-04-02 23:48
World of Warcraft - Item Upgrading
The upgrade of an Item Upgrader Kit (Wiki.Iurium.Cz) allows players to boost the gear score of an item to 700, and then add a final perk. Items can be upgraded if they're in your inventory and you bring them to the kiln.
Certain items can be upp'd to benefit from their unique stats (like an ideally made breakpoint armour that can be rolled to use in melee PvP) and others, like weapons, don't change much post upgrade, and therefore aren't worth upgrading.
Weapons
Upgrades to weapons can improve their numerical stats, such as attack damage, crit chance, and PvE/PvP damage. Weapons also come with a flat bonus which increases the damage they deal per second. Some weapons also come with an unaffected bonus that is activated when three or more identical weapons are placed in a single unit. In some cases this bonus could amount to more than the amount of damage that a weapon is able to upgrade on its own.
The cost of upgrading a weapon is based on the rarity of the weapon and its current level. For example an item with a rating of +2 will require two regular Smithing Stones to upgrade while an upgrade of +3 requires four. The number of stones needed to upgrade a gun will increase until it requires more Smithing Stones. At that point it will reset to one.
The upgrade of weapons can also change their base stats. This is usually a good factor, but it could also have negative effects. In the case of items that only see use in a certain build (Whistant's shield for FB sorcs for instance) upgrading them can make them unusable unless you happen to have an extremely lucky roll.
Armor items can also be upgraded to improve their stats. For example, if you upgrade chests or helms it will boost its base defense while gloves and belts will increase their strength and dexterity. Armor also offers a reroll option for its Enhanced Defense percentage, which means that it can sometimes change its roll to a lower value.
The upgrade template of a weapon will display the new stats it will gain upon upgrading, along with the relative values of those stats. This means that an upgrade from an 8 attack-damage sword to an 11 attack-damage sword will result in a weapon gaining 33% attack damage. However, the 3% doesn't mean that it will strike 3 times less often, since it is an absolute statistic.
A weapon can be rerolled by pressing the green button, which is accompanied by circling arrows in the item menu. This will roll an item and change its statistics, but not reset the weapon's level or connect it to an account's status.
Armor
Making a few improvements to your armor could make a huge differences in your capacity to withstand. Certain sets offer massive improvements in the resistance to curses, poison and fire as well as magic. This can make it easier to traverse difficult terrains. In general, the more defense you have for your character, the greater health you'll receive from each point. So, it's best to upgrade your armor.
You can upgrade your armor by visiting one of the Great Fairy Fountains. There are four Great Fairy Fountains in the game and to unlock each one you have to complete an additional quest involving the Stable Trotters. After you've completed your main quest, and the corresponding fountains, you'll be able to talk to any Great Fairy in order to unlock the menu for upgrading armor.
Each piece of armor can be upgraded up to three levels and the amount of material and Rupees required for each will vary. You'll need anywhere between three Red Chuchu jelly and 10 Rupees to upgrade the first armor piece, and between five Rubies or ten Fire-Breath Lizalfos Horns to upgrade each subsequent one. For example the Champion Leathers can be upgraded to +5 defense, which allows you to keep pace with a good-sized group of adversaries in most cold environments and the Snowquill Headdress can be upgraded to +20 defense, granting the protection needed to survive the full-on assault with a few of your friends.
Be aware that armor can't be upgraded in the same way as weapons, so you'll have to focus on upgrading it for physical power if you're Warrior or Spell Power if you're a Mage. It's also a good idea to save your armor upgrades to use for armor you'll still be wearing at the end of the game, such as the Ring of Lightning and Spectral Shield or the helmet you'll wear to fight the final boss, the Monter Parts Merchant's mask.
You can also unlock some benefits to your armor by giving the jeweler in Gerudo Town 10 Twinkling Titanite. In general, you should save these upgrades for the weapon you'll be using to win the game like the Longsword, Battleaxe or Warhammer however, it could be useful to have a few upgrades of the chest armor and helmets to permit you to sneak past some monsters.
Potions
Potions are liquids that when consumed by a player, provide a temporary effect. There are five types of potions, each with specific effects and durations. Certain potions can be upgraded to increase their level of effectiveness. You can also increase the effects of certain potions by adding glowstone dust and redstone.
Upgrades to your potion require a specific amount XP. This can be earned through crafting them on a craft table or by placing them in the Alchemist chest. However, the upgrade price is dependent on the kind of potion you wish to upgrade, and also on the item upgrader's Mark Level and rarity.
To upgrade a potion to the next level, right-click on it in your inventory and choose the "upgrade item" option from the menu. This will open an GUI that lets you select the potions that you would like to upgrade and the amount of experience they will offer when upgraded. You can upgrade potions in batches of up to five at once, and their XP will be added to the total XP you currently have.
Once a potion is upgraded, it will not degrade until you use it again or break the bottle it's stored in. Clicking on the potion in your inventory will also allow you to rename it.
There were a few updates to potion mechanics in version 1.7.2. For example, splash potions now have an average duration of 0.08 seconds (this is not the same as the 22.5 seconds displayed on the item hover display). The table for potion can now be constructed using four Wood Planks and two Glass. This allows it to be used by players in Survival and Bedrock. Bedrock Edition potions aren't compatible with cauldrons, as is the case with Java Edition. The same is true for using a potion in a cauldron that is full. This will draw out the potion, and refill the bottle.
There are also lingering potions that are brewed using dragon breath and splash potions. Redstone can also be added to potions that are lingering to increase their effects. The potion table has been rearranged to appear more like the Java Edition. New potions have also been added like the potion of leaping and decomposition.
Trinkets
A trinket can be described as a small and inexpensive ornament or piece of jewelry. It could also refer to an object or ornament that has a purpose but isn't essential such as a trinket. In some cultures, a trinket is used to symbolize affection or friendship, particularly between family members.
Trinkets can be upgraded by players in addition to weapons, armor, and potions. Upgrades can be purchased by paying the appropriate currency to an upgrade vendor. Trinkets like other items which can be upgraded can be exchanged at any time without losing stats.
Upgrade vendors can be found at the capitals of every zone, and in some instances in dungeons. Upgrades for trinkets can be purchased using tokens, gold or fragments of a rare trinket.
The upgrade of a trinket can be a cost-effective alternative to purchasing a new one. You can upgrade a trinket with as little as 12 tokens. The new trinket has the same base level as the previous trinket however, it will also come with an additional bonus of 1% upgrade.
Trinkets can be upgraded once they're no longer needed and allows players to increase their power and worth over time. They can also be traded between players which makes them an extremely popular alternative to gold.
Players should upgrade their most essential items first. This usually means the best-in-slot items for their class, then their secondaries, and finally other gear items that will not be replaced soon (for instance rings or cloaks). It is also important to consider your class's preferred stats when deciding the items to upgrade. For example If Haste and Crit are the two most important stats for tankers, they should prioritize upgrading their chest, helm, shoulders, and belt.
Trinkets can be upgraded to a higher ilvl once they no longer have value, and the new trinket will have an additional 1% upgrade bonus. However, a re-upgrade will destroy the old trinket in the event that it is not saved using a Black Lion Salvage Kit or a higher-tier salvage tool. Upgrades to trinkets can be more expensive than other upgrades, but still less expensive than purchasing an entirely new trinket.
