11 Ways To Completely Revamp Your Immobiliser Ghost > 자유게시판
작성자 Donnie
댓글 0건 조회 43회 작성일 25-04-02 23:42
Ghost Immobiliser Tracker
The autowatch ghost 2 immobiliser Ghost immobiliser system is a discrete device that prevents your car from being started without you entering an entry code. It protects against cloning and theft of relays.
It prevents the engine from starting until you enter a PIN number (up to 20 numbers) by pressing the buttons of your vehicle.
Theft Prevention
A ghost immobiliser tracker will make it much more difficult for thieves to take your vehicle. The device is connected to the CAN data network in your car, and a personal PIN code is encoded into it. This code is entered using a pattern of existing buttons on the dashboard and steering wheel and is only accessible to you. If someone tries to start your car, they will be prevented from doing this because only you have the PIN. The system is discreet and undetectable, allowing it to work in the background of your car without interfering with your driving experience.
The device is immune to relay attacks, the most popular method of theft in the UK. The thieves work in groups of two or three. One thief is likely to be in close proximity to your vehicle while another one, usually in a neighbouring home or along the roadside using an electronic device to detect your key-fob signal and send it to their relay. The Ghost II immobiliser stops the thief starting your car by blocking the signal from the fob.
This prevents the thief adding a new ECU or key to bypass the system in order to start your vehicle. This is because it operates quietly and doesn't emit the tell-tale click that traditional immobiliser relays do. The device also avoids cuts in the circuit, which is an extremely common method employed by professional thieves to tamper on your vehicle and make it easier to take it away.
If a car thief is able to steal your vehicle it will be tracked by GPS notify you via an SMS message regarding their movements. This will allow you the opportunity to report them to police, and perhaps get your car back.
A Ghost immobiliser will protect your investment from theft. However, it should be installed by a properly trained and certified installer to ensure that the system is properly fitted and is functioning properly. We recommend working with an approved TASSA engineer, such as MotorGuard. They can provide an individualized installation service for the Autowatch Ghost as well as other modern security devices for cars.
Remote Control
With an extremely small device that rests on the key ring and connects to the car's CAN data network on the vehicle's CAN board, it is activated by an easy mobile application. It will create a unique PIN (similar to the ones used for credit or debit cards) that needs to be entered to allow your car to be driven. This will shut off the engine stopping thieves from starting your car regardless of what is ghost immobiliser they do using the original key fobs or even using methods of theft relays.
Ghost immobiliser trackers also include systems to prevent signal jamming, device spoofing, and Cloning - all techniques that standard immobilisers are susceptible to. These new generation devices can be connected to other car alarm systems and Trackers (Brand dependent) to allow priority disarming.
This technology can be incorporated onto any of our Ghost Tracker Products, giving you peace of mind wherever you are in your vehicle. It can be used in conjunction with your existing tracking system, and once activated, it will be authorized through the app to start your car and lock it. This is perfect to make a quick trip to the shops or when taking your children to school.
The Autowatch Ghost II immobiliser an innovative security device that utilizes the buttons on your dashboard and steering wheel in a discrete style to create a pin that only you know. This is done through the combination of up to 20 different button presses. This is virtually impossible to break by thieves and can even disable the immobiliser.
Another benefit of this is that it will be active if your car is being tracked by one of our trackers or stolen and can be reactivated from the app. It can be activated by an installer who is TASSA-approved (We are an approved installer by TASSA). This will reactivate your car alarm that you originally set up, and activate any other security features like a car tethering system or location alerts for the driver.
The Autowatch Ghost II Immobiliser is an Insurance Approved Product courtesy of TASSA and can be fitted to almost all automobiles. The product doesn't require any wire cutting upon installation and it is silent and unnoticeable.
Tracking
As more and more people consider protecting their vehicles from theft through contactless technology, a Ghost immobiliser is a fantastic option for any vehicle. It safeguards against key cloning, hacking or keyless entry, ensuring that even if thieves possess the remote keys, they are unable to escape with your car. It has a range of tracking features that allow you to keep the track of your car.
Our Ghost immobiliser is quiet, unlike many other immobilisers that utilize radio frequencies. It is compatible with the CAN data network on your vehicle. It is therefore undetectable by thieves who might try to steal it because they are not able to employ RF scanners that are simple to locate it. Furthermore, because it does not require additional cuts in the circuit to be installed, the Ghost is extremely difficult to disarm.
Once installed after installation, a Ghost immobiliser will stop the engine from running until you have your unique PIN or app authorization. You can enter a 20-digit PIN using the buttons on your vehicle's steering wheel or dashboard. This will ensure that only you can start the car, and anyone else you have given permission to. If you forget your PIN there is a reset option so that you can easily restart the vehicle. Other features that are useful include Service mode, which permits your vehicle to be driven and started without a PIN, which is great for valeting or taking it into the garage to work.
To get the most from your security system, we recommend pairing an alarm system with a GPS tracker. A GPS tracker will not just let you know where your car is but can also send an alert if the vehicle moves outside of the set area. You can take immediate action if you suspect that your vehicle is moving.
As one of the Midlands most reputable installers of ghost and other high-end vehicle security systems, we provide an extensive fitting service to ensure that your car's most prized possession is properly secured. Our team of expert technicians are ready to provide unrivalled assistance and advice so that you can find the right solution for your requirements.
Maintenance
Ghost immobilisers work quietly and doesn't emit radio signals. It is low maintenance. It is connected to the vehicle's CAN data bus, and is controlled by the ECU which makes it difficult for thieves to identify. The device is also highly durable and can be used for a long period of time without causing any wear and tear or damage. It can be hidden in a discreet spot inside the car. It can be placed in several ways, like in the wheel trim, or engine bay.
It's a great way to protect your pride and joy. It is a cost-effective and efficient alternative to traditional security measures such as a wheel lock or a hidden tracking device. It is an excellent choice for commercial vehicles. For instance, it can be fitted in the lorry or van to prevent theft. It is also resistant to hacking, and you can track the whereabouts of your vehicle throughout the day.
The Ghost II CAN immobiliser is different from other immobilisers in that it does not use key fobs or LED indicators. It uses buttons on your Porsche, such as those on the steering wheels, door panels and centre console, to generate an individual code that needs to be entered in order to disable the vehicle.
This revolutionary system doesn't need any special software or programming and is therefore extremely difficult to hack or disable. It is also a very cost-effective and simple to install as it does not require any electrical wiring or an external power source to operate.
Our team of experts from Total Vehicle Systems will provide a full demonstration of the way that the Autowatch Ghost 2 Immobiliser Tracker functions on your Porsche before it is fitted. We will then provide you with the Ghost 2 emergency cards, the installation certification and owner's manuals. Lastly, we will ensure that you are happy with the results before leaving your premises.311135906_1281855972636056_2987376612771239945_nlow.jpg
