You'll Never Be Able To Figure Out This Cost Of Ghost Immobiliser's Se…
Protect Your Car From Key Cloning and Theft With a Ghost II Immobiliser
Guard your car against modern day key cloning and theft with our TASSA approved ghost immobiliser ghost. The device is hidden within your vehicle and works on the vehicles CAN data network connecting to buttons on the steering wheel, door panels, and the centre console.
It is able to alter the sequence for disarming by pressing existing buttons up to 20 times. This makes it unnoticeable to anyone who would attempt to steal your car.
No circuit cuts
The Ghost is an interior security system you can install in your vehicle. The Ghost is designed to deter thieves from stealing your pride and joy. This system connects to the CAN data network cost of ghost immobiliser your vehicle and operates through the engine control unit (ECU). The ECU sends a signal whenever the key or fob is pressed. This stops the ignition. This prevents the engine from starting unless you have the correct PIN code.
The system is easy to use, and it can be programmed by using the buttons on the steering wheel, door panel, or on the centre console. Once programmed, Ghost will generate a unique PIN code which can only be entered by pressing the correct buttons. This feature is not only ideal for safeguarding your car against theft, but also makes it very difficult for thieves to hack the system.
The Ghost also has the benefit of not requiring any extra wiring or circuit cuts. This makes it a good choice for customers who wish to keep their car's original look as possible. This is particularly important for those who plan to sell their vehicle in the future. The system can be turned off via a smartphone remotely, which makes it harder for thieves to steal your vehicle. It is also connected to the CAN network, so it isn't detected by radio frequency scanners.
Ghost is a brand new technology that helps to protect your car from cloning attacks, relay attacks and hacking. The system is discreet and does not have any LED indicators or keyfobs that show its position. It doesn't leave behind any installations marks which is a fantastic option for future car sales.
The system can also be used in conjunction with other security products, such as Tracker to offer a greater level of protection. It includes a GPS tracking system and an alarm that prevents theft. This system is compatible with a wide range of vehicles such as cars, vans, and motorhomes. It can be installed in only a couple of minutes, and it can be turned on and off with the press of one button. It also features an option for service mode that allows you to start your car without a PIN code. This is ideal for valet parking or when the vehicle is being repaired.
No key fobs
A ghost immobiliser provides an extra layer of security to your vehicle by stopping your car from starting unless you follow a distinct disarm sequence. This helps combat key hacking, cloning, and relay theft, and prevents thieves from stealing your pride and joy.
The TASSA-approved ghost immobiliser and tracker-ii device is a low-maintenance, discrete device that utilizes the buttons on your car to create a secret code that must be entered to allow your vehicle to begin. This means that there is no need for extra key fobs or LED indicators to indicate the location of the device. It is also hard to detect as it operates in a silent manner and does not transmit radio signals, and is completely invisible to the naked eye. This makes it a great option for those who need an effective and discreet system to protect their car from contactless theft.
There were 108.542 cars taken in 2022. It's crucial to take the necessary steps to stop your vehicle from becoming the next victim of crime. As contactless technology becomes more sophisticated, criminals are discovering ways to snatch vehicles without using keys that are physically present. ghost immobiliser price immobilisers can be an excellent investment for those seeking to secure their vehicle.
This discreet and low-maintenance device can be hidden in many locations in your vehicle, such as under the floor mats, or in the engine bay. It also connects directly to the CAN data network, so there is no need for additional wiring and is virtually impossible to find.
The Autowatch Ghost-ii is a powerful and discrete anti-theft system that can be installed on all vehicles. It connects to the CAN (Controller Area Network) of your vehicle and operates through the ECU (Engine Control Unit) so it is totally silent and inaccessible. It also does not communicate with diagnostic tools or employ any radio signals which means it isn't able to be manipulated by a hacker who might attempt to add new keys or replace the ECU with a different one.
No LED indicators
Autowatch Ghost II immobiliser is the ultimate vehicle security system designed to stop key cloning, hacking, and car theft. The device is discreet and uses the factory buttons on your vehicle (steering wheel door panels, steering wheel and central console) to produce an unique PIN code push sequence that you must enter before the vehicle can be started. It is inaccessible to a criminal and doesn't have LED indicators to give away its presence or whereabouts. It can also be activated by the vehicle's engine stalling system. This provides you with an additional degree of security.
It does not transmit radio frequency signals, and is not connected to CAN data network, which means it is not detected by diagnostics. This means that thieves are unable to make use of sophisticated RF scanning, code-grabbing or other techniques to identify the ghost immobiliser tracker. This renders it nearly undetectable to thieves and it is able to be placed virtually anywhere in the vehicle.
The unit is directly connected to the CAN data network, which means that a thief can't listen for the telltale clicking of a traditional immobiliser relay. It isn't able to be removed, and a burglar must undergo the risky task of cutting wires in order to bypass it and start the vehicle. The Shadow also has a small internal relay that can be used to back up the Ghost-II in the event that it is cut off or altered.
This additional layer of protection is an excellent deterrent to criminals. If a thief does try to remove the Ghost-II, it will immediately activate the engine stall feature which stops them from reinstalling it or using another method to start the vehicle. In addition to that, the Shadow will also disable your vehicle's engine ignition in the event that the original fob or key is used to try to start it.
This is a highly effective anti-theft device that provides the best level of protection for your Range Rover Sport. We recommend that this security system is fitted to all Range Rover Sport models, as it will make them much more difficult to steal.
No installation marks
The ghost ii works completely different from older immobilisers which can be detected using diagnostics or code-grabbing technology. It is water-proof, does not require additional wires and utilizes the buttons on your vehicle to generate an unique PIN number which you need to enter before your engine can be started. There are no LED indicators to indicate that the device has been activated or even been fitted and because it relies on the vehicle's data network there is no risk of the system being compromised in any way.
The device cannot be detected by diagnostics and it's not able to steal your car key or to clone it. This is a breakthrough solution to stop key cloning.
It is also an TASSA approved device that could aid in reducing the Cost Of Ghost Immobiliser of your car insurance. Most insurers will classify this as an anti-theft device that is likely to reduce your chances of your vehicle being stolen. They might also offer a discount for installing it on your vehicle.
Our expert team of installers is prepared to manage the entire installation for you. They will ensure the installation is completed to highest standards that are possible. We will show you the system and address all your questions. We will then give you the owner's manual as well as the installation certificate and a Ghost 2 emergency card.
Recently, we were awarded the status of a TASSA approved company. This means that we are able to discreetly mark your vehicle using QR codes that connect directly to information in a secure TASSA data base. If your vehicle is ever taken by the police, you'll be able to immediately identify it as the owner. This will allow you to return your vehicle faster. Our service comes with a warranty for the lifetime of the product, meaning you can drive with peace-of-mind knowing that your investment will be secure.
No circuit cuts
No key fobs
No LED indicators
- 이전글9 Lessons Your Parents Teach You About Replace Window Handles 25.04.24
- 다음글Nine Things That Your Parent Teach You About Window Doctor Near Me 25.04.24
