How To Find The Perfect Ghost Ii Immobiliser On The Internet > 자유게시판
작성자 Roberta
댓글 0건 조회 18회 작성일 25-04-24 03:47
Autowatch Ghost 2 Immobiliser Installation Service
Secure your precious possessions from the modern day car thieves by using our TASSA approved, DBS security checked and Ghost immobilisers that are trained by our system service.
The Ghost system operates silently on the vehicles CAN data network, and is unnoticeable to thieves who use diagnostic tools because it doesn't emit any radio signals.
Easy to install
Autowatch Ghost is a discreet anti-theft device which can protect your vehicle from key cloning and hacking. It makes use of your vehicle's buttons to generate a pin code push sequence that must be entered in order to start your vehicle. This prevents thieves from stealing your keys and driving away with your joy and pride, or at the very least delaying your trip to have your car repaired!
The system can be easily installed by a certified installer like Car Theft Solutions. No wires are cut during installation. It connects directly to CAN data network of your vehicle, meaning there aren't any 'fobs' or indicators' to indicate the presence of the system. This makes it extremely difficult for a modern burglar to identify, unlike passive anti theft devices such as steering wheels locks.
The ghost immobiliser cost 2 will make your Porsche virtually impossible to track down thieves. If they attempt to start the engine without a pin code or app authorization the engine will be stopped. The system can do this by using the factory buttons on the steering wheel and central console. You can set up a unique sequence of buttons (similar to a pin number) that must be used to start the engine.
You can set the ghost immobiliser car in Service and Valet mode once you have developed your own disarming sequence. This allows you to start your car even if it's being repaired or taken to a garage to work, but it will only let you do so with your pre-set app or pin. You can retrieve the pin if you forget it. This means you don't need to worry about people driving your car who aren't.
The Ghost 2 has QR finger print labels that are connected to the International Security Register and registered to you. This provides you with an additional degree of security in the event that your vehicle is damaged by parts, as the unique code allows your car to be immediately traced back to you.
Low-maintenance
The car thieves are more sophisticated than ever, and technology has advanced to keep up. The result has led to the creation of stealth immobilisers, designed to stop your pride and joy from becoming their next target. Ghost immobilisers operate independently of the vehicle's factory-installed alarm or tracker, as well as other security devices. They offer an additional security level that cannot be altered.
This advanced technology connects to your vehicle's CAN Data Network and a personalised PIN code sequence is programmed into it using the buttons on your steering wheel door cards or central console. The Ghost immobiliser won't begin to start the engine if the specific code isn't inputted before starting it. This prevents you and your passengers driving away.
The device is small enough to be concealed in the vehicle wiring harness. It's weatherproof, works silently and doesn't emit radio frequency signals so it can't be detected by the sophisticated RF scanning or code grabbing technologies that some thieves employ. It also requires minimal maintenance because it's connected to the CAN Data Network and can't be removed with simple wire cutting.
If you're planning to sell your vehicle at any point, the Ghost immobiliser ghost can be transferred to the new vehicle as long as it meets the compatibility requirements. If you decide to change cars during the time that you own the Ghost, it will not become obsolete. This is an excellent benefit for those who take pride in their vehicle.
The Ghost is an immobiliser of the present that does not require an additional keyfob or LED indicator to work. This means that it is able to be used in the dark. The PIN is adjustable (up to 20 presses) and can be changed in a moment of need in case you forget it. It can be set to valet or service mode, which means that your car can drive for a short time when you need to leave it at a mechanic's garage or valet company to do some work.
Unrecognisable to thieves
Standard factory installed immobilisers protect your vehicle from theft by preventing it from starting without the correct code and key fob. However the Ghost immobiliser operates differently. It communicates with the electronic control unit in your vehicle by connecting to the CAN data circuit. This means that thieves cannot get around the system by programming or other methods. It's also quiet and doesn't emit radio signals making it difficult to detect or fake.
Ghost will safeguard your precious or expensive vehicle from theft. You can feel secure knowing that the money you put in customising or modifying your vehicle is protected.
Ghost is a discrete, simple device installed in the wiring of your car. It will not affect the appearance of the vehicle. It works by connecting to the CAN bus network and communicating with your vehicle's center console or the steering wheel's buttons. It's easy to install and hide to ensure that it's unnoticeable to thieves. It's also low-maintenance and does not require batteries or a radio signal and therefore won't be vulnerable to hacking.
The autowatch Ghost-II Anti-Key Clone Immobiliser an elegant new device that can provide your vehicle with advanced security. The first CAN bus aftermarket immobiliser that has been verified by TASSA the system is a must-have for anyone who cares about the safety of their vehicle.
With car theft increasing It is crucial to take steps to stop it. The Ghost immobiliser is a great solution. This smart system locks your vehicle until you enter a specific code or use the app. This stops thieves from starting your car even with the correct keys.
Investing in the purchase of a Ghost immobiliser is only a small price to pay for peace of mind. Particularly if you've invested many hours and money into your vehicle It can be devastating to lose it to criminals. The Ghost immobiliser is the best method to protect your precious possessions so you can keep it where it belongs.
It can be fitted without marks on the internal body of the vehicle.
An immobiliser is a device to prevent your vehicle from being stolen without a key fob. Since 1998, immobilisers are required on all new vehicles. They are a part of the CAN data network of your vehicle and therefore thieves cannot detect them or disable them by cutting wires. This makes it nearly impossible for thieves to steal your car as they won't be capable of starting the engine without your key fob or mobile phone with the Autowatch app downloaded. This is essential, especially if you've spent lots of time and money on customizing the car. It will stop thieves from taking it away without your permission.
The Ghost 2 immobiliser can be installed in a concealed location so that it is not visible to the untrained eye. It has a connection to the CAN and operates through your ECU (engine control unit). It is small, quiet and has no radio signals, so it won't be detected by a thief. The Ghost has a built in battery that is replaceable so it can continue to operate even if there is a power failure.
After the Ghost is installed, it will require the pin code sequence to be entered for the car to begin. The app on your phone will allow you to enter the code, so that only you know it. You can also put your car in Service/Valet Mode which allows it to start without requiring the PIN code. This is helpful when you need to transport your vehicle to a garage or valet service. You can alter your PIN at any time to give yourself extra security.
310300814_438157535072560_441431797686435441_nlow.jpgThe technology used to stop thieves has also advanced as they have become more sophisticated. The Ghost is a great example, as it guards your vehicle from theft by stopping key hacking, key cloning, and even preventing them from obtaining keys in the first instance. The Ghost is a renowned aftermarket immobiliser and is TASSA-verified which means insurance companies will be aware of it and provide drivers with lower premiums. If you're worried about the increase in new thieves and are looking to do your part to lower the risk, then the Ghost is the ideal solution for you.
