Meditation Blend Live Resin Disposable Vape Hawaiian Haze – 3 grams > 자유게시판
작성자 Leland
댓글 0건 조회 4회 작성일 25-04-20 01:24
$34.99
16 in stock
TOTAL MEDITATION BLEND THC: 2700MG
INGREDIENTS
THC Meditation Blend: (D8) Delta-8 Tetrahydrocannabinol / (D9) Delta-9 Tetrahydrocannabinol / (THCA) Tetrahydrocannabinolic acid / (THCP) Tetrahydrocannabiphorol / (CBN) Cannabinol / (CBG) Cannabigerol, Live Resin, Plant-Derived Terpenes. THC Meditation Blend Total: 2700 Mg
INSTRUCTIONS
Click button 5 times to turn on/off.
SUGGESTED USE
Take 1-2 small puffs not exceeding 3 seconds.
All users may not react the same to product use.
The onset of effects may be experienced at different times.
First time users may experience stronger effects. DO NOT EXCEED SUGGESTED USE.
STORAGE
Store at room (or cool) temperature and away from sunlight. Try to store upright to prevent leaking.
CAUTION
KEEP OUT OF REACH OF CHILDREN. THIS IS A HEMP-DERIVED PRODUCT. NOT INTENDED FOR INGESTION – DO NOT EAT. This product is intended for use by healthy adults age 21 years & older. Consult a healthcare professional prior to use of THC Meditation Blend: (D8) Delta-8 Tetrahydrocannabinol / (D9) Delta-9 Tetrahydrocannabinol / (THCA) Tetrahydrocannabinolic acid / (THCP) Tetrahydrocannabiphorol / (CBN) Cannabinol / (CBG) Cannabigerol. THC Meditation Blend may be harmful if you are pregnant, nursing, taking any medication or have a medical condition. Discontinue use immediately if adverse reaction occurs and consult your physician. The FDA has not evaluated this product for safety or efficacy. As required by Florida state law, THC Meditation Blend potency is verified by an independent third party lab. The results of the independent third party lab tests are available to you on our website and by scanning the QR code on the package. There is no current standardized methodology cbd tinctures for sale - Ongoing - verifying THC Meditation Blend content therefore test results may vary by individual laboratory and/or test method. This product contains less than 0.3% total delta-9 tetrahydrocannabinol (Delta-9 THC). Drug tests vary in sensitivity, and you may test positive for Delta-9 THC when taking THC Meditation Blend products. Over time color variations may occur in this product. The amount (mg) of THC Meditation Blend may vary by dose and by packaging. If THC Meditation Blend is used beyond the expiration date, potency may decrease. May cause drowsiness. Do not drive or operate heavy machinery while taking THC Meditation Blend.
RELATED PRODUCTS
HAZE – Pre-Roll – Blueberry Muffin – 3.5g
HAZE – Pre-Roll – Cereal Milk – 3.5g
HAZE – Pre-Roll – Maui Wowie – 3.5g
Fantasy Blend Live Resin Disposable Vape Gelato – 3 grams
Surreal Blend Live Resin Disposable Vape Cotton Candy 3 grams
Haze Brain Stew Delta 9 Gummies – Hybrid
Brain Stew THCA Disposable Vape Hybrid – 3 grams
25 First Ave. SW STE A
Watertown, SD 57201
Products on this site contain a value of 0.3% or less Δ9THC (or no more than 0.3% Δ9THC). FDA Disclosure: This product is not for use by or sale to persons under the age of 21 depending on the laws of your governing state or territory. This product should be used only as directed on the label. It should not be used if you are pregnant or nursing. Consult with a physician before use, especially if you have a medical condition or use prescription medications. A doctor's advice should be sought before using any of these products. All trademarks and copyrights are property of their respective owners and are not affiliated with nor do they endorse this product. These statements have not been evaluated by the FDA. These products are not intended to diagnose, treat, cure or prevent any disease. By using this site you agree to follow the Privacy Policy and all Terms & Conditions printed on this site. Void Where Prohibited By Law.
Autoship powered by qpilot.svg
