Crema de alivio con CBD > 자유게시판
작성자 Odessa
댓글 0건 조회 64회 작성일 25-03-24 01:33
39.99
Ingredientes:<\/strong> Agua, parafina l\u00edquida, \u00e1cido este\u00e1rico, alcohol cetear\u00edlico, polisorbato 60, alcohol cet\u00edlico, estearato de glicerol, amazon Customer service call dimeticona, alcohol desnaturalizado, gliceret-26, propilenglicol, diazolidinil urea,
Metilparabeno, Propilparabeno, Acetato de tocoferilo, Mentol, Aceite de gaulteria, Alcanfor, \u00c1rnica, Copol\u00edmero de acrilamida\/acrilato de sodio, Trideceth-6, Alcohol estear\u00edlico, Polisorbato 20, Extracto de c\u00e1\u00f1amo Cannabidiol (CBD*),Trietanolamina, Parfum, Hya-luronato s\u00f3dico, PCA s\u00f3dico, Amino\u00e1cidos de trigo, Pantenol, Extracto de Symphytum Offici-nale (Consuelda), Hidroxiprolina.<\/p>
Uso sugerido<\/strong> S\u00f3lo para adultos.
Agitar bien antes de usar. Aplicar no m\u00e1s de
3 veces al dia cada 6-8 horas en la zona deseada.<\/p>
<\/div>Leer m\u00e1s<\/a><\/p>
","variation_id":7533928,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/D","has_lab_report":false},{"attributes":{"attribute_pa_tamano":"4oz-500mg"},"availability_html":"
Sin existencias
Ingredientes:<\/strong> Agua, parafina l\u00edquida, \u00e1cido este\u00e1rico, alcohol cetear\u00edlico, polisorbato 60, alcohol cet\u00edlico, estearato de glicerol, dimeticona, alcohol desnaturalizado, gliceret-26, propilenglicol, diazolidinil urea,
Uso sugerido:<\/strong> S\u00f3lo para adultos.
<\/div>
","variation_id":7533929,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/D","has_lab_report":false},{"attributes":{"attribute_pa_tamano":"8oz-1000mg"},"availability_html":"
Sin existencias
<\/div>
","variation_id":7533930,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/D","has_lab_report":false}]">
Descripción
Elimine el enrojecimiento, la irritación y el dolor antes de que se extiendan con nuestra crema más vendida en su fórmula más potente.El potente poder de las plantas es el nombre del juego con esta mezcla concentrada, utilizando ingredientes que se unen para crear una solución verdaderamente calmante. La mezcla incluye aloe vera, hamamelis, aceite de coco y glicerina vegetal. Y para el golpe de gracia, la crema analgésica CBD 250mg, 500,1 000 mg de CBD derivado del cáñamo funciona como el ingrediente nº 1 para penetrar en la capa dérmica de la piel y llegar a CB2 los receptores de tus músculos. A nuestros clientes les encanta esta crema de CBD porque dicen que es de acción rápida para dolores articulares y musculares leves, y que se absorbe rápida y fácilmente; no tiene un olor fuerte ni residuos grasientos. Y como esta fórmula no contiene fragancias ni ingredientes irritantes, esta crema de CBD es ideal para las personas con piel sensible.
Información adicional
2oz 250mg, 4oz 500mg, 8oz 1000mg
FAQ
Cada una de estas cremas analgésicas de CBD incorpora una dosis de CBD más alta que el resto; a quienes se inician en el uso de la crema analgésica de CBD se les recomienda empezar con la de 250 mg, mientras que a quienes ya se han acostumbrado a la crema analgésica de CBD les puede ir mejor con la dosis de 1000 mg.
Lo ideal es aplicar la crema analgésica de CBD en momentos en los que sabes que el dolor va a aparecer pronto, como inmediatamente después de un entrenamiento intenso. De esta forma, tendrás más posibilidades de sentir alivio sin tener que lidiar con el dolor durante demasiado tiempo.
Algunos estudios han observado que las cremas de mentol pueden ayudar a mejorar la circulación cuando se añaden a la crema analgésica, y algunas personas con fuertes dolores articulares y musculares han reportado éxito con el uso de la crema de CBD. Sin embargo, se necesita más investigación antes de que la FDA pueda determinar si las cremas de CBD son un tratamiento eficaz para el dolor.
Aunque se necesita más investigación antes de que se puedan hacer afirmaciones sobre el CBD para tratar el dolor, la crema analgésica de CBD se ha convertido en una opción popular para los atletas, ya sea para tratar músculos doloridos y tensos, o para ayudar con lesiones deportivas menores.
A la hora de entender cómo usar la crema analgésica de CBD, determinar la dosis correcta es clave. Lo ideal es empezar con una dosis pequeña y aumentarla gradualmente cuando sea necesario.
Productos relacionados
CBD Heat Roll-On Crema caliente
Crema de alivio con infusión de CBD Bomba sin aire
CBD Roll-On Crema con Mentol
Gel Ultra Alivio CBD+THC Mentol 4oz
Gel Ultra Alivio con CBD -1000mg
3406 SW 26th Terrace C1
Fort Lauderdale, FL 33312
Este producto no debe ser utilizado ni vendido a personas menores de 18 años. Este producto sólo debe utilizarse según las indicaciones de la etiqueta. No debe utilizarse en caso de embarazo o lactancia. Consulte con un médico antes de usarlo si tiene una condición médica grave o usa medicamentos recetados. Se debe buscar el consejo de un médico antes de usar este y cualquier otro suplemento. Todas las marcas comerciales y derechos de autor son propiedad de sus respectivos dueños y no están afiliados ni respaldan este producto. Estas declaraciones no han sido evaluadas por la FDA. Este producto no está destinado a diagnosticar, tratar, curar o prevenir ninguna enfermedad. Al utilizar este sitio, usted está de acuerdo en seguir la Política de Privacidad y todos los Términos y Condiciones impress en este sitio. Nulo donde esté prohibido por la ley. Nuestros productos contienen menos d 0,3% de THC.
