CBD Bath Bombs
Experience the ultimate relaxation with CBD bath bombs! Infused with cannabidiol (CBD), these luxurious bath bombs can relieve stress after a long day. Using a daily routine of topical CBD make it an excellent choice for soothing tired feet, sore muscles, and promoting calmness. Discover the benefits of CBD-infused bath bombs for a truly calming and rejuvenating experience.
Popular Products
DESCRIPTION
What Is a CBD Bath Bomb?
A CBD bath bomb is a sphere-shaped product added to bathwater, creating a fizzy reaction with ingredients like baking soda, citric acid, and essential oils. What sets CBD Topicals apart is their infusion with cannabidiol (CBD), derived from hemp oil. JustCBD offers a range of CBD bath bombs in flavors like Citrus, Eucalyptus, Lavender, Rose, and Sweet Cherry, each containing 150mg of CBD. These bath bombs also feature nourishing ingredients like Olive Oil, Jojoba Oil, Aloe Vera, and various essential oils, providing a soothing and relaxing bath experience.
What Does CBD Do in a Bath?
When using a CBD bath bomb, as it dissolves in water, it disperses and behaves similarly to oil floating on the surface. Despite limited exposure, you can still experience the potential benefits associated with CBD during your bath.
How to Use a CBD Infused Bath Bomb
Drop it into a tub filled with warm water. It will release essential oils, fragrances, and CBD as it fizzes. Get into the bath, lather up, and relax for a soothing experience. Spending a few minutes lathering with the bath bomb can enhance the CBD’s penetration into the skin and improve its potential effects.
What to Look for in a CBD Infused Skincare Products
When looking for a CBD bath bomb, consider the following factors to ensure you get a quality product:
Look for third-party laboratory-tested products with readily available test results (COA) from independent labs.
Choose a bath bomb with CBD concentrations that suit your needs, typically 150 milligrams.
Opt for bath bombs with a detailed ingredients list free of any unfamiliar additives or components.
Compare prices to find a product that offers good value, considering that some CBD may be lost when the bath bomb dissolves.
Research the company’s reputation and history of providing high-quality CBD products.
Will CBD bath bombs make you feel ‘high’?
CBD Topicals should not make you feel "high" as they typically contain minimal or no THC, the psychoactive compound in cannabis. However, the presence of THC depends on the product’s formulation. Full-spectrum CBD products may have trace amounts of THC, which could potentially cause a high in large doses. To avoid this, opt for broad-spectrum CBD, isolate products, and stick to a low amount. A CBD bath bomb will not make you fail a drug test.
How to shop for Skincare Products with CBD
When shopping for CBD bath bombs, ensuring the product comes with an up-to-date and comprehensive certificate of analysis (COA) from a reputable third-party lab is crucial. Look for the following information in the COA:
Check if it matches the label’s claim.
Ensure that it contains less than 0.3% THC, as federally legal products should.
Some brands provide batch-specific COAs, while others may offer a sample COA.
Verify that the product passes tests for heavy metals, pesticides, molds, and, if applicable, solvent testing for products made using solvent-based extraction methods.
Transparency is essential, so buy from companies that openly share information about their hemp sourcing and production methods. Checking the brand’s reputation and whether they have received any FDA warning letters can also provide insights into the company’s credibility and compliance with regulations.
How to use a CBD Topical
Using CBD bath bombs is a simple and enjoyable process. Start by dropping the bath bomb into your tub of water and soak in the relaxing experience. However, these are not ordinary bath bombs, so it’s essential to consider the product’s potency before use.
Since the ideal dose of CBD varies from person to person based on factors like body weight, body chemistry, and the CBD concentration in each product, it’s recommended to start with the lowest dose bath bomb if you’re new to CBD.
CBD Bath Bombs FAQs
While CBD bath bombs on our list contain trace or nondetectable amounts of THC, there is always a slight chance of a positive drug test with any CBD product, although it's less likely with CBD Topicals due to their low THC content.
The frequency of CBD bath bomb use varies depending on the individual and their skin type. Some ingredients in bath bombs may be irritating or cause allergic reactions, so limiting their use is advisable. Generally, it's recommended to soak for no longer than 15 minutes at a time.
For optimal CBD absorption without drying out the skin, aim for 20 to 30 minutes in the tub.
Limited research on the efficacy of CBD Topicals exists, but experts suggest they may provide similar, though milder, benefits to other topical CBD products.
Yes, CBD bath bombs are legal in most countries, including the United States, as long as they contain less than 0.3% THC.
CBD bath bombs are intended for single use in regular bathtubs, not hot tubs. They are formulated for approximately 80-100 gallons of water and take about 5 minutes to dissolve. For optimal results, it's recommended to soak in your hot tub for 20-40 minutes to allow the CBD to penetrate your pores.
Like any CBD product with natural ingredients, CBD bath bombs have an expiration date. It's best to use the bath bombs within six months of purchase.
CBD is non-psychoactive and safe for children as it does cbd contain thc not cause "high" effects like THC-based products. However, it's always a good idea to consult a healthcare professional before using CBD products on children.
25 First Ave. SW STE A
Watertown, SD 57201
This product is not for use by or sale to persons under the age of 18. This product should be used only as directed on the label. It should not be used if you are pregnant or nursing. Consult with a physician before use if you have a serious medical condition or use prescription medications. A Doctor’s advice should be sought before using this and any other supplement. All trademarks and copyrights are property of their respective owners and are not affiliated with nor do they endorse this product. These statements have not been evaluated by the FDA. This product is not intended to diagnose, treat, cure or prevent any disease. By using this site, you agree to follow the Privacy Policy and all Terms & Conditions printed on this site. Void Where Prohibited by Law. Our products contain less than 0.3% THC.
JustCBD Florida Only Website
Welcome! You must be 21+ to enter this site.
Please enter your date of birth.
- 이전글CBD Relief Cream 25.03.22
- 다음글Alluzience Longer Lasting Botox near Badshot Lea, Surrey 25.03.22
