The 10 Scariest Things About Item Upgrader > 자유게시판
작성자 Mervin
댓글 0건 조회 19회 작성일 25-04-12 15:36
World of Warcraft Item Upgrades
The upgrade of an item can be used to increase the stats of a particular item. Depending on the type of upgrade, it can increase an item's Rarity or Mark Level and increase other stats.
Upgrading equipment in The War Within requires a set number of Flightstones and Crests and each item has an upgrade track. Each upgrade increases the cost of the following one by a set amount.
Item Level
When an item is upgraded, its basic stats are increased in value. The value is the sum of all the leveled up perks (attack magic attack, attack defense). Upgrades can be expensive depending on the person you hire and what you decide to do. This is because of how many perks must be replaced to allow the item to be upgraded.
The level of an item is a widely used measurement of power and can be seen on all tooltips for items. It can also be used to limit the amount of PvP gear players can wear, since PvP is limited at a lower level. Players can see their average item level in their character sheet.
When deciding whether to purchase or sell equipment players can look at the level of an item. It's a good gauge of an item's worth and the amount of damage it is able to deal. The item level can also be used to compare items when looking at a vendor's inventory.
On PC, you can view the item level by pressing ALT or using the left stick on XB1 or PS4. The item will be displayed with its full description, including ilvl. You can also locate it by hovering over an item and typing in /itemlevel chat.
There are several theories on how the item level calculation is made. One theory is that the level is a number derived from a formula that determines the value of an item's stats are worth. It considers the fact that different perks have different values, and also that gems in sockets add to the overall value of the item. This can result in a calculated value for the item's level, which is usually close to the actual Blizzard level of the item.
This isn't the only factor that influences the value of an item. The location of where the item dropped can also change its stats. For instance, it could add a level to the item's haste or crit score. Items that drop in higher-level instances will have a higher value.
Item Stats
The stats of an item can determine the fate of an item for players. The game uses them in many ways to encourage players to not limit themselves to a single weapon and to encourage them to try out other weapons. The base stats of a weapon are enhanced by the weapon's stat modification that are in turn increased by the player's skill.
The upgrades to items add by boosting certain stats on the item. The rarity of an item determines its upgrade cost. An item that is white or grey, for example, will only be upgraded once and items that has rare tiers can be upgraded several times at higher costs.
Another method of altering the stats of an item is to use affixes. These are special stat boosts that can be added to an item by the player, and are available in all shapes and sizes. Affixes can do things like give the item extra damage, or add a unique capability to the item (such as reviving dead or decreasing the cooldowns) or make the item unique by adding a special name to the item upgrade.
All affixes can be currently re-rolled by selecting them in the upgrade window pressing the green button. This procedure will cost the player a specific amount of gold and items, which can be added to the upgrade gauge in the same manner as other rerolling options.
Players can choose to upgrade an item to specific stats or reroll the affixes. The possible stat ranges of an item are determined by the level of the item, however all items are guaranteed to have at least 1 stat within that range, unless it's an item that is unique or a God roll from a boss of a raid.
This is another thing that can be modified by adding the option to upgrade the equipment without rerolling the affixes or choosing which stats to enhance. Similar to base equipment, it would have to be done per item, and the interface for item comparison will not show all possible stats at once.
Item Luck
The Luck stat of a player boosts the chance of finding items as well as the properties generated by loot, and the strength of these properties. It does not, however directly impact damage or the ability to upgrade items. It gives the player an opportunity to get better equipment earlier in the game. This is especially advantageous for early game runs, since players tend to prioritize the scaling of weapons and defenses over raw damage gains.
In addition to influencing the discovery of items, Luck also increases the chances of success when upgrading items with the Blacksmith. This is not to confuse with the Blacksmith’s overall chance of upgrading that increase with each new level of item upgrader kit (just click the up coming article). They can also be increased with the use of anti-materials, such as a Scroll of Strength and a Jewel of Blessing.
The shields, armor and weapons come with an initial Luck value of 40. These items can then be enhanced by golden ingots, spined leather or oak boards (depending on the type of material used) to grant a further +40 Luck, or to increase the Luck of an item up to 140.
Additionally, certain items, such as the Hollow weapon that is infused with hollow can be outfitted to increase the damage dealt by any damage-dealing skill by 5%. These items can be bought from the shop or constructed using the right ingredients.
Item Failure
Not all upgrades work. Cash shop items can be used to increase the success rate of an upgrade, or to protect players from losing their item in the event that it fails.
When you upgrade an item, the success rate is displayed in the Honing UI. The percentage is the chances of successfully upgrading the item, and can be increased by adding Additional Materials or Special Materials. There are limits to the extent to which the success rates can be improved and the probability of a failed upgrade cannot exceed 100%.
The success of an item upgrade item is also affected by the luck of that item. Each item has a base success rate of 25%, and every item with Luck increases that chance by an additional 5%.
Note that upgrades to items are rendered above the items in the inventory, so enchantment glint and other effects can be obstructed by the overlays. If you wish to disable the upgrade overlays, the config option decoration.renderUpgradeOverlays can be set to False in the Item Upgrader CORE client config.
