Aceite de Coco con CBD > 자유게시판
작성자 Marjorie Waldro…
댓글 0건 조회 6회 작성일 25-04-12 15:29
83.99
Botella de 30 ml Cuentagotas de 1 ml
<\/p>
Dosis:<\/strong> Dosis 1\/ML 30 Dosis por envase. Aceite MCT (Aceite de Coco), Dosis: 1 gotero completo (1mL), Dosis totales: (30), Aprox. 3.3mg CBD por gotero completo,
Cantidad por raci\u00f3n:Calor\u00edas 9, Calor\u00edas de Grasa 9, % Valor Diario* Grasa Total 1g: 1%, Grasa Sat. Grasas 1g, 5%, Grasas trans 0g , Grasas poliinsaturadas 0,2g, Grasas monoinsaturadas 0,9g , Colesterol 0mg, 0%, Sodio 0mg, 0%, Potasio 0mg, 0%, Carbohidratos totales 0g, 0%,Fibra diet\u00e9tica 0g, Az\u00facares 0g, Vitamina A, 0%, Vitamina C, 0%, Calcio, 0%, Hierro, 0%.
*Porcentaje de valores diarios basados en una dieta de 2000 calor\u00edas<\/strong><\/p>
INGREDIENTES:<\/strong>
Aceite de coco fraccionado, extracto de c\u00e1\u00f1amo, cannabidiol (CBD*). <\/p>
CONTIENE:<\/strong>
Nueces de \u00e1rbol (cocos).<\/p>
<\/div>Leer m\u00e1s<\/a><\/p>
","variation_id":7535002,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/D","has_lab_report":true},{"attributes":{"attribute_pa_tamano":"250mg"},"availability_html":"
Sin existencias
<\/p>
Dosis:<\/strong>Dosis 1\/ML 30 Dosis por envase. Aceite MCT (Aceite de Coco), Dosis: 1 gotero completo (1mL), Dosis totales: (30), Aprox. 3.3mg CBD por gotero completo,
ed Grasa 0.9g , Colesterol 0mg, 0%, Sodio 0mg, 0%, Potasio 0mg, 0%, Carbohidrato Total 0g, 0%,Fibra Diet\u00e9tica 0g, Az\u00facares 0g, Vitamina A, 0%, Vitamina C, 0%, Calcio, 0%, Hierro, 0%.
CONTIENE:<\/strong>
<\/div>
","variation_id":7535001,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/D","has_lab_report":true},{"attributes":{"attribute_pa_tamano":"550mg"},"availability_html":"
Sin existencias
<\/p>
Dosis:<\/strong> Dosis 1\/ML 30 Dosis por envase. Aceite MCT (Aceite de Coco), Dosis: 1 gotero completo (1mL), Dosis totales: (30), Aprox. 18.3mg CBD por gotero completo,
CONTIENE:<\/strong>
<\/div>
","variation_id":7535000,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/D","has_lab_report":true},{"attributes":{"attribute_pa_tamano":"1000mg"},"availability_html":"
Sin existencias
<\/p>
Dosis:<\/strong> Dosis 1\/ML 30 Dosis por envase. Aceite MCT (Aceite de Coco), Dosis: 1 gotero completo (1mL), whole foods market redding ca Dosis totales: (30), Aprox. 18.3mg CBD por gotero completo,
CONTIENE:<\/strong>
<\/div>
","variation_id":7534999,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/D","has_lab_report":true},{"attributes":{"attribute_pa_tamano":"1500mg"},"availability_html":"
Sin existencias
<\/p>
Dosis:<\/strong> Dosis 1\/ML 30 Dosis por envase. Aceite MCT (Aceite de Coco), Dosis: 1 gotero completo (1mL), Dosis totales: (30), Aprox. 50mg CBD por gotero completo,
Cantidad por raci\u00f3n: Calor\u00edas 9, Calor\u00edas de Grasa 9, % Valor Diario* Grasa Total 1g: 1%, Grasa Sat. Grasas 1g, 5%, Grasas trans 0g , Grasas poliinsaturadas 0,2g, Grasas monoinsaturadas 0,9g , Colesterol 0mg, 0%, Sodio 0mg, 0%, Potasio 0mg, 0%, Carbohidratos totales 0g, 0%,Fibra diet\u00e9tica 0g, Az\u00facares 0g, Vitamina A, 0%, Vitamina C, 0%, Calcio, 0%, Hierro, 0%.
CONTIENE:<\/strong>
<\/div>
","variation_id":7534998,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/D","has_lab_report":true},{"attributes":{"attribute_pa_tamano":"3000mg"},"availability_html":"
Sin existencias
Botella de 60 ml Cuentagotas de 1 ml
<\/p>
Dosis:<\/strong> Dosis 1\/ML 60 Dosis por envase. \u00bb Aceite MCT (Aceite de Coco), Dosis: 1 gotero completo (1mL), Dosis totales: (60), Aprox. 83.3mg CBD por gotero completo,
Cantidad por raci\u00f3n:Calor\u00edas 9, Calor\u00edas de Grasa 9, % Valor Diario* Grasa Total 1g: 1%, Grasa Sat. Grasas 1g, 5%, Grasas trans 0g , Grasas poliinsaturadas 0,2g, Grasas monoinsaturadas 0,9g , Colesterol 0mg, 0%, Sodio 0mg, 0%, Potasio 0mg, 0%, Carbohidratos totales 0g, 0%, Fibra diet\u00e9tica 0g, Az\u00facares 0g, Vitamina A, 0%, Vitamina C, 0%, Calcio, 0%, Hierro, 0%.
CONTIENE:<\/strong>
<\/div>
","variation_id":7534997,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/D","has_lab_report":true},{"attributes":{"attribute_pa_tamano":"5000mg"},"availability_html":"
Sin existencias
<\/p>
CONTIENE:<\/strong>
<\/div>
","variation_id":7534996,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/D","has_lab_report":true}]">
Descripción
A la hora de relajar por completo el cuerpo y la mente, un Aceite de coco con CBD Just CBD es uno de los productos de acción más rápida del mercado. Los aceites de CBD no sólo son un método versátil de obtener CBD, sino que son extremadamente potentes. Basta con poner un poco de aceite de coco con CBD bajo la lengua. La gente suele mezclarlo con café, té y otras bebidas. Incluso se puede hornear en una variedad de alimentos para complementar el sabor, mientras se crean potentes comestibles de CBD. Antes de que te des cuenta, el potente CBD será absorbido por tu sangre y transportado por todo tu organismo.
Elaboradas con cannabidiol, agua y aceite MCT, los aceites de coco Just CBD se producen en los Estados Unidos. También han sido probadas por terceros y son 100% orgánicas. Eso significa que toda nuestra mercancía de CBD está elaborada sin ningún tipo de producto químico. No tendrás problemas para relajarte. La relación completa viene fácil y el sueño puede mejorar dramáticamente, teniendo un efecto maravilloso en sus niveles de energía preciosos a lo largo del día. Lo mejor de todo es que el consumidor nunca tendrá que preocuparse por colocarse, ya que el aceite de coco con CBD no contiene suficiente THC como para producir un efecto eufórico. De hecho, las tinturas de CBD se utilizan a menudo para aliviar a las personas que han tenido un mal viaje.
JustCBD dispone de aceites de coco premium de 50 mg, 100 mg, 250 mg, 550 mg, 1000 mg y 1500 mg. Empieza poco a poco y ve subiendo con el tiempo. Experimentarás todos los efectos deseados que estás buscando. Cada botella incluye un gotero aplicador que hace que sea fácil de obtener su tamaño exacto de la porción. También realizamos envíos a todo el mundo. Los precios de los sabrosos Aceites de Coco Just CBD son extremadamente económicos, ya que oscilan entre los 9,99 $ y los 98,99 $ por unidad. ¿Qué aceite de CBD probarás primero?
Información adicional
1000mg, 100mg, 1500mg, 250mg, 3000mg, 5000mg, 550mg
FAQ
El aceite de tintura de CBD está hecho de alcohol, mientras que el aceite de CBD se produce a partir de aceite de CBD y aceites que contienen aceite, como el aceite de coco o las semillas de cáñamo.
La dosis óptima de CBD está determinada por varios factores, incluido el peso, por qué tomó CBD y el metabolismo. Puede que el médico te prescriba para hacerlo mejor, pero si tú mismo te lo estás probando, empieza por lo mínimo posible.
El aceite de CBD se pueden tomar por vía sublingual o mezcladas con alimentos o bebidas. Las comidas y bebidas a base de grasa, como las mantequillas de frutos secos y los quesos, son especialmente recomendables en este caso.
Los aceites de CBD no son psicoactivas como el THC, por lo que no te causará efectos psicoactivos.
Productos relacionados
Aceite de CBD para dormir
Aceite de CBD de espectro completo
3406 SW 26th Terrace C1
Fort Lauderdale, FL 33312
Este producto no debe ser utilizado ni vendido a personas menores de 18 años. Este producto sólo debe utilizarse según las indicaciones de la etiqueta. No debe utilizarse en caso de embarazo o lactancia. Consulte con un médico antes de usarlo si tiene una condición médica grave o usa medicamentos recetados. Se debe buscar el consejo de un médico antes de usar este y cualquier otro suplemento. Todas las marcas comerciales y derechos de autor son propiedad de sus respectivos dueños y no están afiliados ni respaldan este producto. Estas declaraciones no han sido evaluadas por la FDA. Este producto no está destinado a diagnosticar, tratar, curar o prevenir ninguna enfermedad. Al utilizar este sitio, usted está de acuerdo en seguir la Política de Privacidad y todos los Términos y Condiciones impress en este sitio. Nulo donde esté prohibido por la ley. Nuestros productos contienen menos d 0,3% de THC.
