You'll Be Unable To Guess Cost Of Ghost Immobiliser's Benefits > 자유게시판
작성자 Jack
댓글 0건 조회 10회 작성일 25-04-12 01:12
Protect Your Car From Key Cloning and Theft With a Ghost II Immobiliser
Our TASSA approved Ghost Immobiliser will protect your car from modern key cloning, theft and key cloning. The device is hidden in the vehicle. It is compatible with the CAN data network and is connected to buttons on the steering wheels as well as door panels and the central console.
It can change the disarming sequence by pressing existing buttons up to 20 times. This makes it difficult to detect by anyone trying to steal your car.
No circuit cuts
The Ghost is an interior security system that you can put in your vehicle. The Ghost is designed to stop thieves from stealing your pride and joy. This system connects to the CAN data network in your vehicle and is controlled by the engine control unit (ECU). The ECU sends out an alert to turn off the ignition when the remote or key is press. This stops you from starting the engine until you know the correct PIN code.
The system is easy to use and can be programmed by using the buttons on your steering wheel, door panel or centre console. Once it is programmed, the Ghost will generate a PIN number that is exclusive to you and only enterable using the correct sequence of buttons. This is not only a great feature to help secure your vehicle from theft, but it also makes it difficult for thieves to hack into the system.
The Ghost also has the benefit of not requiring any additional wiring or circuit cuts. This makes it an ideal option for those looking to preserve their vehicle's original appearance as much as is possible. This is important for those who plan to resell their cars in the future. The system can be disabled remotely from a smartphone, which makes it harder for thieves to steal your vehicle. It also connects to the CAN data network, which means that it is not detectable by criminals using radio frequency scanners.
Ghost is a technology that protects your vehicle from cloning attacks, relay attacks, and hacking. Ghost is discrete and doesn't have LED indicators or keyfobs that would give away its location. It doesn't leave behind any installations marks, which is a great feature for future car dealers.
The system can be utilized together with other security devices like the Tracker to offer more protection. This includes the GPS tracking system and an alarm for theft prevention. This system can be used with a wide range of vehicles, including cars or vans as well as motorhomes. It can be installed in only a couple of minutes and is able to be switched on and off with the press of the button. It also comes with the option of a service mode that permits you to start the car without entering a PIN. This is ideal for valet parking or when the vehicle needs to be maintained.
No key fobs
A ghost immobiliser adds an extra layer of security to your vehicle, preventing your car from starting until you go through a specific disarm sequence. This helps prevent key hacking and cloning, as well as relay theft.
The TASSA approved ghost immobiliser review-ii is a discreet and low-maintenance gadget that makes use of the existing buttons in your car to generate a secret PIN code that must be entered before your car starts. It is not necessary to use additional key fobs or LED indicators that identify the location of the device. The device is also incredibly difficult to identify since it operates in a silent manner and doesn't transmit radio signals and is invisible to the naked eye. This makes it an ideal option for those looking for a quiet and efficient device to safeguard their vehicle from contactless theft.
There were 108.542 cars taken in 2022. It's important to take steps to avoid your vehicle from becoming next victim of crime. As technology that uses contactless is becoming more sophisticated, criminals are able to find ways to rob vehicles without having to use a physical key. A ghost immobiliser can be an excellent investment for anyone looking to protect their vehicle.
This low-maintenance, discrete device can be concealed in your vehicle. For instance, it can be hidden under the floor mats or inside the engine compartment. It also connects directly to the CAN data network so there is no need for additional wiring and is almost impossible to spot.
The Autowatch ghost-ii is a discrete and efficient anti-theft solution that can be fitted in all vehicles. It connects to the CAN (Controller Area Network) of your vehicle, and functions through the ECU (Engine Control Unit) which is silent and undetectable. It doesn't communicate with any diagnostic tools, nor does it use radio signals. This means it is in no way able to be altered by hackers who might try to add new keys or even replace the ECU.
No LED indicators
Autowatch Ghost II immobiliser is the ultimate vehicle security device designed to stop key cloning, hacking and car theft. The device is discrete and utilizes the factory buttons on your vehicle (steering wheels doors, door panels, and central consoles) to generate a unique PIN push sequence. You must enter this code before you are able to start the car. It isn't visible to thieves, and it has no LED indicators to indicate its location or presence. It also comes with an immobilisation feature that can be triggered by the vehicle's engine stall system built into it providing you with an additional degree of security.
It is connected to the CAN data network, which means it cannot be detected by diagnostics, and does not transmit radio frequency signals. This means that thieves can't use sophisticated RF scanning, code-grabbing or other techniques to detect the Ghost. This makes it virtually undetectable to a thief and it can be placed almost anywhere in the vehicle.
The device is directly connected to the CAN network, which means thieves are unable to hear the click of a traditional immobiliser. It isn't able to be removed. the thief must cut wires to bypass it. The Shadow also has an internal relay which can be used to back up the ghost car immobiliser-II when it's disconnected or tampered.
This extra layer of security serves as a deterrent to criminals. If a thief tries to disconnect the Ghost-II it will trigger the engine stall function, which will stop the thief from reinstalling the Ghost-II or using other methods to start the vehicle. Additionally, the Shadow will also disable your vehicle's engine ignition if the original key or fob is used to to start it.
This is an extremely effective anti-theft system that offers an excellent level of protection for your Range Rover Sport. We recommend that this system is fitted to all Range Rover Sport models, as it will make them much harder to steal.
No installation marks
Unlike older immobiliser systems which can be detected by diagnostics and code-grabbing technology the ghost 2 immobiliser review ii immobiliser works in a different manner. It does not require additional wires, is water-proof and uses your vehicle's existing buttons to generate a unique PIN code for your vehicle which you must enter before your engine can start. There are no LED indicators to indicate that the device is activated or has been installed, and since it relies on the vehicle's data network there is no chance of the system being compromised in any way.
The device isn't detected by diagnostics and it isn't able to steal your vehicle's key or copy it. This is a revolutionary security option for modern cars that stops key-cloning and theft of vehicles from happening.
It is also a TASSA insurance-approved device that could help lower the cost of ghost immobiliser (previous) of your car insurance. Most insurance companies will classify this as an anti-theft device that is likely to decrease the chances of having your car stolen. They may also offer discounts for the installation of it on your vehicle.
Our expert installation team will handle the entire installation for you. They will ensure that the installation is completed to the highest standards that are possible. We will demonstrate the system and answer your questions. We will then hand over the owner's manual, installation certification and an Ghost 2 emergency card.
cropped-KeyLab-1-152x69.pngWe have recently been granted the status of a TASSA approved installation company which means that we are able to discretely mark your vehicle with QR codes that are linked to data stored on a secure TASSA database. If your vehicle is ever taken by the police, you'll be able immediately identify it as its owner. This will speed up the process of returning your car to you. Our service comes with a guarantee for the lifetime of the product, so you can drive in peace knowing that your investment will be protected.
