Why Adding A Ghost 2 Immobiliser Reviews To Your Life Will Make All The Impact > 자유게시판
Why Adding A Ghost 2 Immobiliser Reviews To Your Life Will Make All Th…
작성자 Rosalie
댓글 0건 조회 27회 작성일 25-04-01 02:12
Ghost 2 Immobiliser
ghost autowatch immobiliser is an electronic security system that wirelessly protects your car against key-cloning and hacking. It connects to the ECU unit through the CAN data network. It is silent and isn't recognized by thieves.
It is only disarmed by pressing a specific button sequence (like PIN codes) that you've programmed using the buttons in your vehicle, such as those on the steering wheel or centre console.
Make sure you're protected from theft
With car ghost immobiliser theft increasing and cars being stolen in mere seconds, it is important that car owners consider the additional security measures available to them. Immobilisers are one of the most effective and most established ways to protect your vehicle. Ghost immobilisers are a great option as they are small, hidden within the wires of your vehicle and don't emit radio frequency signals. They are therefore not traceable, and can be installed without having an impact on the CAN bus system of your vehicle.
Unlike other immobilisers that rely on keypad inputs, tags or the exact sequence of buttons to disarm them the ghost immobiliser that is located near me is only disabled by the pin code set up by us at the time of installation. This unique disarm sequence uses the buttons that are already in your vehicle such as the ones on your steering wheel, doors or centre console to prevent anyone from starting their engine and driving away your vehicle. This makes it impossible for thieves to clone your key or use jamming/spoofing devices which can disable the standard immobilisers.
Not only will a ghost immobiliser prevent your car from being driven and parked, it also prevents the car ghost immobiliser from being taken for parts. This is a growing problem in the UK due to the increasing popularity of these cars. It can happen within minutes. Ghost immobilisers from TTW can be easily programmed to shield your vehicle from these types of attacks.
Installing our Ghost 2 immobiliser will stop your vehicle from being stolen at a service station, or even if your car is being driven in the garage by employees. The Ghost can be set to Service/Valet Mode, which only allows you, the consumer to use a specific button combination.
If you would like to find out more about our ghost immobilisers, or want to have a free quote, contact us now. We'll be happy to assist you and give you peace of mind that your vehicle is secured at all times.
There is no LED or key fob to indicate its location
Secure your vehicle from the latest types of theft by using this non-detectable immobiliser that integrates into your cars CAN data network. Ghost is unlike other CAN-immobilisers made by aftermarket vendors that depend on key fobs or LED indicators to work. Instead, it uses the buttons found on the standard factory controls, like the ones on the steering wheel or doors. This generates a secret code that needs to be entered in order to start your vehicle, which makes it untraceable for thieves.
The developers of the CAN-BUS immobiliser have also added additional security methods in to prevent the device from being compromised or bypassed. It also has CAN-BUS blocking and a physical immobiliser cut, which means that even if your keys were stolen, the criminal cannot take off with your joy and pride.
Installing the CAN-BUS in your vehicle is a straightforward and fast procedure that takes just 30 minutes. We will send a member of the team to your location to arrange an appointment and time that works for you. After your vehicle has been fitted, you will be given a registration number and unique security codes for your mobile and the app will make it easy to use and ensure you are always in charge of your car's security.
The system is available to most modern vehicles, but if you have a specialist or antique car, be sure to contact us to determine if it's compatible. The Ghost Immobiliser 2, including installation costs APS449 and your vehicle will also be added to the International Security Register if installed by one of our approved installers. If you have any questions do not hesitate to get in touch with our friendly team. We'd love to hear from you.
Easy To Setup And Programming
Immobilisers are a feature of numerous modern vehicles to stop theft or hot-wiring. Immobilisers are more effective than physical deterrents such as steering wheel locks and wheel clamps since they are integrated into the vehicle.
The unit connects directly to the CAN data network of your vehicle and prevents it from starting until you enter a unique code. The unit is completely sealed and so small it can be placed almost anywhere in your car without the requirement for additional wiring. It doesn't emit radio frequency signals, which means it isn't recognized by scanners or code-grabbing equipment.
Ghost utilizes your vehicle's current buttons on the steering wheel as well as the door panels and central console to create a customised disarm sequence (like PIN codes) that needs to be entered in order to authorize the startup of your vehicle. The pin code sequence can be changed depending on the need and is based on between four and twenty button presses. You can also place your car in Service/Valet mode so that it is able to be operated but the vehicle is not able to start or drive. This will ensure that your car is safe when you bring it in for valet parking or service and also that the mechanic cannot access your pin code to disable your system.
You can make use of our app to create temporary pins for your ghost immobiliser birmingham device in the event that you are going to be away from your vehicle for a prolonged period of time such as a holiday or work trip. You can manually enter your pin while driving the vehicle.
Our CAN bus immobiliser may also be connected to an electronic remote key fob or tracker (Brand dependant) which will have precedence over the ghost system. This can be a great way to increase security in the event that your vehicle gets stolen or you lose your keys.
Contact us today to find out what we can do to protect your vehicle from key cloning and hacking. We offer our services throughout the UK as well as at our own installation center in Derby.
Service/Valet Mode
Modern automobiles have sophisticated stop/start eco systems that require just the proper inputs to function correctly like battery voltage and temperature, engine temperatures and what electrical systems are in operation. Sometimes these can cause problems and are often difficult to determine if it is Ghost related or not. This is especially true if your vehicle has recently been cleaned or valet-parked. If this is the case, you can go into the ghost service mode, which allows the vehicle to be driven and start up without the need for a pin. This is helpful if your car immobiliser ghost's being maintained by an independent garage or valet-parked.
To enter service mode simply press the service button five times. The indicator will flash twice when the service mode is selected. It is possible to exit service mode at anytime by entering a PIN number. When you exit the service mode, the Ghost immobiliser is restored to normal operation.
It is a discrete system that communicates with the vehicle ECU through the CAN data circuit. It connects directly to the original buttons of the vehicle and does not rely on radio frequency signals like other immobilisers. This makes it virtually impossible for any other device to bypass or hack or jam devices that use spoof codes to mimic the original key fob have no impact on this system.
It is a TASSA-certified anti-theft device that complies with the highest protection standards. It also has an exclusive vehicle marking system that connects to the international security register that is a requirement for insurance companies.
The ghost vehicle immobiliser immobiliser is a tiny device that is easily hidden within the wiring of your vehicle's factory. This makes it almost impossible for thieves to steal. It is a closed unit that is so small it can be placed in different areas of the vehicle, such as under the dashboard or on the steering wheel.
The system makes use of the buttons already present within your vehicle (such as those on your steering wheel, door panels or centre console) to enable you to create a unique and changeable disarm sequence that can be up to 20 presses in length that must be entered prior to when your vehicle starts. It is able to be entered by anyone with your unique pin code. it is safe and secure for you and your family, colleagues, or friends to use.311170119_2306394586188303_2849487588620745484_nlow.jpg
