This Is The Ultimate Guide To Item Upgrade > 자유게시판
작성자 Salina
댓글 0건 조회 22회 작성일 25-04-10 02:22
WoW Upgrades - The Item Upgrader
Upgrades will give you a boosts in specific stats. Each upgrade item boosts the level of the item upgrading by +3. A random extra substat is also added to every upgrade.
The upgraded gear is usually more valuable, unless the item is not required by nature (like FB sorc shields) or has a large variance in stats (like Eth Titan weapons). The latter see less value from upgrading due to the need to roll for a perfect version.
Recycle Points
The item upgrader lets players upgrade their gear by offering the currency to an NPC. Upgrades can be applied to any type of armor or weapon. However, the item used for the upgrade item will be consumed forever and will not be able to be used again. Upgrades can also be used to create enhancements.
The upgrader can be found in every major city, and can be visited anytime to upgrade your equipment. It is recommended to visit the upgrader once every few weeks, to keep your equipment up to date.
Upgrades will cost more depending on the item level, however, they are always less expensive than purchasing new gear. For instance, upgrading a Benthic chest piece to 385 ilvl will cost 20 recycle points while buying a similar item upgrading from another player will costs 105.
Valorstones
Upgrades are items that can be used to purchase weapons, armor, tools, and accessory upgrades. They can be purchased by players from NPCs that sell upgrades to items in exchange for different currencies, and can also be found in random treasure lists. Once purchased, an upgrade is able to be applied to any weapon, tool or armor. The button will display the item's next level of upgrade, when there are enough materials.
The cost of upgrading varies based on the slot of the item and the current item level. For instance weapons cost more than gloves, bracers, or bracers. Each step costs 15 Flightstones and a variety of crests, with certain upgrades offering discounts to reduce the cost of the Flightstones or crests used. After an item has been upgraded to a certain amount it is able to be downgraded and sold to the upgrader at a lower cost.
Item upgraders can be found at many locations on the main island and some outposts. The NPCs provide both an upgrade coupon as well as the possibility of obtaining a new recipe. The upgrade discount increases as more items are upgraded. It can be increased if players complete certain achievements or complete quests.
Contrary to Cromwell in Baldur's Gate II, there is no upgrader for items available in the beginning of Icewind Dale. Instead, the NPCs that can be used to upgrade items must be acquired through a variety of means which is both an improvement as well as a disadvantage.
In Season 3, the upgrade system was tweaked a bit, with some new features added. After an upgrade has been completed to a specific level for an armor slot upgrading other items to the same item level, will cost less. This is true regardless of whether the items come from an entirely different set of gear.
The discount is available to all accounts. In the same way, the amount of Harbinger Crests required for upgrades is also reduced and is not available until players have reached certain milestones in their achievement.
Crests
When it comes to upgrading equipment in WoW players have a few choices. Flightstones are an option that is accessible to all players for upgrading. Crests are more special, and are used during specific Item Level upgrade level upgrades. Crests are a key element of the Dragonflight gear progression system, which was introduced in 10.1 and are available in 4 ranks.
The first thing to remember is that Crests are only available to equipment that is with a certain rank. Each rank comes with distinct upgrade paths. The easiest and most straightforward upgrade costs 15 crests. The most complex upgrade requires up to 20 crests, contingent on the type of equipment that is being upgraded.
Players can earn crests by working through content at the appropriate level. This could mean doing outdoor activities or taking on dungeons and raids of all difficulty levels to obtain lower-tier gear or Mythicbosses of raids or dungeons with heroic difficulty for gear in the endgame. Crests can be exchanged at an upgrader NPC, like Cuzolth in Dornogal or Vaskarn in Valdrakken, for the appropriate upgrade paths and steps.
Utilizing these new currencies isn't that difficult however, the system introduces some modifications to the upgrade process. When a piece of equipment reaches the highest level of upgrade for any rank (Explorer or Adventurer) it will no longer require Flightstones. This change lets players upgrade their gear to the highest possible ilvl for all their characters instead of relying on seasonal loot.
Another important change is that crests have one usage, so it's important to make use of them in a responsible manner. For instance it's a good idea to make use of all your Whelpling-rank crests with the best gear you have available and keep Drake and Wyrm crests to use for the next set of upgrades you're planning to create. This is especially true for items such as trinkets and rings that take up multiple slots. The discount for the entire account will only be applicable if all the slots on the character are filled with high-quality gear.
