Bomba de baño de CBD > 자유게시판
작성자 Anja Michaels
댓글 0건 조회 35회 작성일 25-04-06 01:42
Aceite de Oliva, Bicarbonato S\u00f3dico, \u00c1cido C\u00edtrico, Sal de Epsom, Aceite de Jojoba, Hamamelis, Aloe Vera, Romero, Flor de Cerezo, Mandarina, Extracto de C\u00e1\u00f1amo Cannabidiol (CBD*).
<\/p>
","variation_id":7534987,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/D","has_lab_report":true},{"attributes":{"attribute_pa_aromas-de-bombas-de-bano":"rose-scent"},"availability_html":"
969 disponibles
Aceite de Oliva, Bicarbonato S\u00f3dico, \u00c1cido C\u00edtrico, Sal de Epsom, Aceite de Jojoba, Hamamelis, Aloe Vera, Romero, Naranja Dulce, Pachul\u00ed, Ylang Ylang, Lavanda, Extracto de C\u00e1\u00f1amo Cannabidiol (CBD*).
<\/p>
","variation_id":7534988,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/D","has_lab_report":true},{"attributes":{"attribute_pa_aromas-de-bombas-de-bano":"lavanda"},"availability_html":"
989 disponibles
Aceite de Oliva, Bicarbonato S\u00f3dico, \u00c1cido C\u00edtrico, Sal de Epsom, Aceite de Jojoba, Hamamelis, Aloe Vera, Romero, Lavanda, Menta, Mandarina, Extracto de C\u00e1\u00f1amo Cannabidiol (CBD*).
<\/p>
","variation_id":7534989,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/D","has_lab_report":true},{"attributes":{"attribute_pa_aromas-de-bombas-de-bano":"eucalipto"},"availability_html":"
990 disponibles
Aceite de Oliva, Bicarbonato S\u00f3dico, \u00c1cido C\u00edtrico, Sal de Epsom, Aceite de Jojoba, Hamamelis, Aloe Vera, Romero, Eucalipto, Mandarina, Hierba de Lim\u00f3n, Extracto de C\u00e1\u00f1amo Cannabidiol (CBD*).
<\/p>
","variation_id":7534990,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/D","has_lab_report":true},{"attributes":{"attribute_pa_aromas-de-bombas-de-bano":"esencias-citricas"},"availability_html":"
940 disponibles
Aceite de Oliva, Bicarbonato S\u00f3dico, \u00c1cido C\u00edtrico, Sal de Epsom, Aceite de Jojoba, Hamamelis, Aloe Vera, Romero, Cedro, Hierba Lim\u00f3n, Mandarina, Naranja Dulce, Extracto de C\u00e1\u00f1amo Cannabidiol (CBD*).
<\/p>
","variation_id":7534991,"variation_is_active":true,"variation_is_visible":true,"weight":"","weight_html":"N\/D","has_lab_report":true}]">
Baño caliente: comprobado, aromaterapia: comprobado, CBD: ¡comprobado! Las bombas de baño con CBD te ofrecen un paquete de lujo para la relajación, ¡formuladas para proporcionarte la noche de tranquilidad que te mereces!
Nuestras bombas de baño artesanales están elaboradas con sales de epsom, conocidas por ayudar a aliviar la tensión muscular, y hamamelis para la inflamación. Esta mezcla para el baño se completa con 150 gramos de CBD puro aislado y una fragancia natural y celestial, disponible en cinco relajantes aromas.
JustCBD ofrece ahora la mejor bomba de baño de aceite de CBD para ayudar a hombres y mujeres a relajarse en casa. Combinando un baño relajante con 150mg de potente aceite de CBD, nuestra bomba de baño de CBD tiene beneficios tanto físicos como emocionales. Pruebe cada una de las recetas de bombas de baño de CBD, que incluyen aromas de rosa, lavanda, eucalipto, cítricos y cereza dulce. Tu cuerpo y tu mente se sentirán completamente relajados en un abrir y cerrar de ojos.
Descripción
Tenga cuidado al entrar y salir de la bañera.
Sólo para uso externo. No exceda la cantidad sugerida. Este producto está destinado a adultos sanos mayores de 18 años. MANTENER FUERA DEL ALCANCE DE LOS NIÑOS. El consumo de cannabidiol (CBD) durante el embarazo, la lactancia, la medicación o en caso de padecer alguna enfermedad puede ser perjudicial. Consulte a un profesional sanitario antes de usarlo. Suspenda su uso inmediatamente si se produce alguna reacción adversa y consulte a su médico. La FDA no ha evaluado la seguridad o eficacia de este producto. No existe una metodología estandarizada para verificar el contenido de CBD. Los resultados de nuestros informes de pruebas de productos de laboratorio de terceros, en los que basamos la cantidad de CBD, side effects bad day están disponibles para usted en nuestro sitio web y escaneando el código QR en el paquete, pero los resultados de las pruebas pueden variar según el laboratorio individual y / o método de prueba. La cantidad de mg / CBD puede variar según el artículo y el envase. Este producto contiene un total de delta-9 THC que no supera el 0,3%. Las pruebas de drogas varían en sensibilidad y puede dar positivo por THC al tomar productos de CBD. Este producto puede presentar variaciones naturales de color. Puede causar somnolencia.
Estas afirmaciones no han sido evaluadas por la Food and Drug Administration. Este producto no está destinado a diagnosticar, tratar, curar o prevenir ninguna enfermedad.
Información adicional
Cereza dulce, Esencias Cítricas, Eucalipto, Lavanda, Rosas
FAQ
Sí, las bombas de baño de CBD son una forma segura y relajante de disfrutar del CBD (y de tu noche).
Las bombas de baño de CBD son fragantes pasteles de CBD y sales de Epsom, que se disuelven en un baño caliente para crear un baño extra relajante.
El CBD no está recomendado para mujeres embarazadas, ya que los efectos a largo plazo del CBD sobre el desarrollo fetal e infantil aún no se conocen en su totalidad.
Las bombas de baño de CBD son una forma eficaz de relajarse y desconectar, al combinar los beneficios calmantes del agua caliente y el CBD.
Sí, el CBD puede ser absorbido transdérmicamente por los receptores CB1 y CB2, creando un efecto localizado.
Las bombas de baño de CBD vienen en diferentes potencias, pero las nuestras vienen en una dosis especialmente alta de 150mg.
No, las bombas de baño de CBD no deberían hacer que suspendas un control antidroga.
Las bombas de baño de CBD no son exactamente un producto de CBD para el día a día, pero son perfectas para esas noches (o mañanas, o tardes) en las que necesitas un poco de descompresión.
Las bombas de baño de CBD son cada vez más populares, pero todavía pueden ser difíciles de encontrar en algunas zonas. Por suerte, siempre se pueden encontrar en línea en sitios de confianza.
Para sacar el máximo partido a tu bombas de baño de CBD, todo lo que necesitas es un baño caliente y humeante. Introduce la bomba de baño o déjala correr bajo el grifo mientras se disuelve, y observa cómo burbujea y libera sus poderes calmantes.
Productos relacionados
Loción corporal de CBD
Aceite de masaje
3406 SW 26th Terrace C1
Fort Lauderdale, FL 33312
Este producto no debe ser utilizado ni vendido a personas menores de 18 años. Este producto sólo debe utilizarse según las indicaciones de la etiqueta. No debe utilizarse en caso de embarazo o lactancia. Consulte con un médico antes de usarlo si tiene una condición médica grave o usa medicamentos recetados. Se debe buscar el consejo de un médico antes de usar este y cualquier otro suplemento. Todas las marcas comerciales y derechos de autor son propiedad de sus respectivos dueños y no están afiliados ni respaldan este producto. Estas declaraciones no han sido evaluadas por la FDA. Este producto no está destinado a diagnosticar, tratar, curar o prevenir ninguna enfermedad. Al utilizar este sitio, usted está de acuerdo en seguir la Política de Privacidad y todos los Términos y Condiciones impress en este sitio. Nulo donde esté prohibido por la ley. Nuestros productos contienen menos d 0,3% de THC.
