Should you Eat before or after a Workout? > 자유게시판
작성자 Sophie
댓글 0건 조회 2회 작성일 25-09-24 10:07
A well-planned workout begins and ends the same way: with eating the right foods. Advertising on our site helps support our mission. We do not endorse non-Cleveland Clinic products or services. How you fuel and refuel before and after exercise helps determine the actual fitness-building benefit of the session. That’s true whether you’re lifting weights, running miles or swimming laps, alpha surge male ingredients too. So how can you maximize the effort that goes into spilling every drop of sweat? Let’s find out with sports dietitian Kate Patton, MEd, RD, CCSD, LD. One question comes up repeatedly when it comes to food and workouts: Alpha Surge Male testimonials Is it better to eat before or after a training session? That’s a tough one to answer, alpha surge male ingredients and here’s why: They’re both important, says Patton. Munching before exercising provides your body with the energy it needs to power through the session. Chowing down afterward helps with recovery. Not just any old fuel will do, though.
It’s important to put the right stuff in your tummy tank. Foods rich in carbohydrates and protein provide the nutritional building blocks your hard-working body needs. "Carbs supply the energy to carry you through your workout," says Patton. Together, they form a mighty one-two punch that would gain a CrossFit instructor’s approval. Timing, though, is key. You wouldn’t start a road trip without gassing up the car, alpha surge male ingredients right? The same principle applies to preparing your body for exercise. "You don’t want to start on empty," says Patton. Your plate should feature carbohydrates and alpha surge male ingredients a moderate amount of lean protein. Limit fats and fiber, which digest more slowly and can upset your stomach while bouncing around during a workout. The closer you get to exercise time, the less you want to gobble down to avoid belly issues during the activity, says Patton. Think more along the lines of a snack than an actual meal.
"Everybody is different, though," says Patton. What about early morning exercise? If you’re waking up and alpha surge male muscle builder alpha surge male performance support alpha surge male vitality formula alpha surge male vitality formula formula working out, alpha surge male ingredients loading up with a meal a few hours ahead of time isn’t exactly an option. Unless you want to set your alarm clock for 2 a.m., of course… "When you wake up, your blood sugar is at your lowest," says Patton. Consider the intensity of your workout, too. If it’s an easy-going, 30-minute session, you may be able to get away with skipping a pre-workout snack. "But if you’re going for an hour or more, you really should get something to eat," says Patton. Working out on an empty stomach also could cost you what you’re trying to build - namely, muscle. It’s beneficial to have some protein, the building blocks of muscle, in your system while training If you want to grow and strengthen muscles. Stamina may also be an issue if your body is running low on fuel, meaning your workout could quickly turn into a dud.
"You’re better off to eat," says Patton. "It doesn’t have to be much. Let’s get that pre-workout menu set. Turkey-and-Swiss-cheese sandwich with an apple and low-fat chocolate milk. A PB&J sandwich with banana slices and low-fat milk. Low-fat Greek yogurt with berries plus a small salad topped with chicken. Focus on hydration, too, consuming at least 16 to 20 ounces of additional fluid in preparation for the sweating that awaits, says Patton. Closer to go time, grab a quick bite to give your body an extra lift. A handful of pretzels. You just put your body through a lot and depleted its power reserves. Now, it’s time to restore that energy supply, says Patton. Look to grab a quick, protein-packed snack 15 minutes to an hour after your workout to begin refueling. Starting the process right away can help ward off muscle soreness, tightness and cramping. It’s important to rehydrate and replace lost electrolytes, too.
In that case, look for a liquid food option such as a protein drink or chocolate milk. Just don’t skip getting something into your system. "If you don’t eat and drink after working out, you may start to feel fatigued or alpha surge male ingredients even hangry," says Patton. That quick bite should be followed a few hours later by a nutritious meal chock-full of carbs and protein. Consider it the final rep, mile or lap of your earlier workout. Almonds washed down with chocolate milk. Greek yogurt topped with granola and blueberries. String cheese and pretzels. Apples and peanut butter. Make sure to rehydrate ASAP, too. A sports drink that replenishes lost electrolytes is ideal. Your next meal a few hours after training also should be packed with proteins and carbs, says Patton. Egg-and-cheese-filled tortilla wrap with a fruit-topped yogurt parfait. Stir fry with chicken, brown rice and vegetables. A bowl filled with chicken, brown rice, black beans, cheese, lettuce and salsa. If you’re into endurance-based activities like running, cycling or swimming, your diet should lean more heavily on carbs to supply a longer-lasting energy source. The rule of thumb is about 4 grams of carbohydrates for every gram of protein per meal, says Patton. But protein should fill up more of your plate if you’re focused on muscle-building strength training, such as powerlifting. On that plan, it’s about 2 grams of carbs for every gram of protein.
