Should i use CBD Products on my Skin?
Should I Use CBD Products on My Skin? If you've walked down the drugstore aisle recently, you might have noticed a new acronym popping up on the labels of many skincare products: CBD. CBD, which stands for cbd products cannabidiol, is a chemical compound derived from the cannabis plant. CBD oils, lotions, and creams are readily available in many states as over-the-counter beauty products and the market for CBD is growing fast. Dr. Nima Gharavi, dermatologist and skin cancer surgeon at the Cedars-Sinai Cosmetic Dermatology Program, says CBD may play a role in hydrating the skin and have anti-inflammatory effects, so using a product that contains cbd hemp extract might help with treating dry skin or certain inflammatory skin disorders. While the effect of CBD on your skin is unclear, there's a lot of interest in CBD research, Dr. Gharavi says. If CBD can produce the same anti-inflammatory effect as a steroid without the potentially negative side effects, then the use of CBD could be an encouraging new method to treat these skin conditions. Read: Collagen for Your Skin: Healthy or Hype? Are CBD products safe for your skin? Dr. Gharavi says there's likely little harm that can come from applying a CBD beauty product to your skin.
CBD (cannabidiol) and THC (tetrahydrocannabinol) are the two major compounds found in the cannabis plant. Each has unique properties, potential health benefits, and side effects. The following article covers CBD and THC, their effects, their legal status, and their safety considerations. CBD and THC are known as cannabinoids. They have very similar chemical structures and activate the same receptors within the body’s endocannabinoid system. Despite their similarity in structure, CBD and Highline Wellness CBD deals THC exert entirely different effects. The most significant difference between these two compounds is that THC is psychoactive. This means it can affect how the brain works. THC activates the body’s "reward" pathways to produce the "high" that’s associated with marijuana use. It does this by activating a cannabinoid receptor called CB1. When THC activates this type of receptor, things like movement, body temperature, and brain function are affected. In contrast, CBD is not considered psychoactive. It does not cause euphoria or a "high," even at large doses.
Much of the research on CBD and THC is preclinical, meaning it’s been studied in animal models. Large-scale human trials are necessary to determine if CBD or THC can help treat most of these conditions. Though it does act on cannabinoid receptors, CBD mainly affects other receptors, including serotonin receptors. It may help counteract some of the negative effects of THC, including serious side effects like psychosis. CBD has many purported therapeutic properties. Pain. Overall, there isn’t enough evidence that CBD by itself helps with pain. Some research has shown that high doses can improve neuropathy (nerve pain), though more data is necessary. Anxiety. So far, the results are mixed. Some studies show that Highline Wellness CBD deals can improve symptoms of social anxiety disorder and post-traumatic stress disorder (PTSD), while others show no effect. Seizures. Epidiolex, a purified CBD oil, is approved by the Food and Highline Wellness CBD deals Drug Administration (FDA) for some hard-to-treat types of childhood epilepsy.
Brain protection. Animal studies have shown that CBD may have benefits for those who have Alzheimer’s disease or Parkinson’s disease, but human clinical trials are necessary to verify these effects. Effects on animals may or may not translate into benefits for humans. THC is the psychoactive ingredient from the marijuana plant. The possession and use of marijuana and THC-containing products are not legal in all U.S. THC is effective for increasing appetite and for nausea and vomiting related to cancer chemotherapy. Pain. Prescription THC products have been shown to improve neuropathy and quality of life. Spasticity (muscle tightness). Sativex (nabiximols), a mouth spray that combines THC and cbd gummies, is approved for spasticity in Europe. PTSD. A very small trial found that Cesamet reduced nightmares in 10 military personnel with PTSD. Irritable bowel syndrome (IBS). Smoking THC was found to improve symptoms of IBS, but benefits may be only short-lived. People who used THC long-term were more likely to ultimately require surgery for IBS.
- 이전글10 Quick Tips On Order Fakes Online 25.09.24
- 다음글Ten Quick Etiquette Points To Consider Business Lunches 25.09.24
