Department Of Energy (2025-02-09). Portable Heaters > 자유게시판
작성자 Jerold
댓글 0건 조회 5회 작성일 25-09-21 17:17
b38662bb-44a9-49f5-a788-352a4bbdafbaAn area heater is a device used to heat a single, small- to medium-sized space. This kind of heater might be contrasted with central heating, which distributes heat to multiple areas. All space heaters switch heat to their setting by way of some combination of the three elementary modes of heat transfer: convection, radiation, and conduction. Typically heaters are designed with both convection or radiation as the only dominant mode. Convective area heaters utilize convection to transfer heat from the power source to a space. These heaters typically both depend on natural or forced convection. Natural convection is a phenomenon the place temperature variations in an setting generate fluid flow. Forced convection heaters utilize a gadget like a fan to generate air circulate and spread heat at a quick tempo. Sometimes known as "fan heaters," these are sometimes cheap however lack in efficiency and versatility. Radiant house heaters transfer heat on to bodies in entrance of them utilizing thermal radiation.
Thermal radiation is a course of by which objects at a high temperature emit heat in the type of electromagnetic waves. These heaters are sometimes designed such that the frequency of the emitted waves are within the infrared part of the electromagnetic spectrum. The materials used in radiant heaters can differ. Halogen heaters have tungsten filaments in sealed quartz envelopes, mounted in entrance of a metal reflector in a plastic case. They function at a better temperature than nichrome-wire heaters however not as excessive as incandescent gentle bulbs, radiating primarily in the infrared spectrum. They convert as much as 86 percent of their enter energy to radiant vitality, losing the remainder to conductive and convective heat. Oil heaters switch heat by convection and radiation. They'll silently heat bigger rooms, however take longer to heat up. Like infrared models, they lack a fan, but circulate heat in keeping with a room's air patterns, which is why it might take longer for a consumer to discern a distinction in temperature.
By the mid-2010s, some greater-end models included more exact controls. The ability source utilized in a radiant heater will depend on the assets that are available. Most house heaters are either powered by electricity or combustion. Electric area heaters convert electricity into heat by way of the strategy of Joule heating. The principle component of these heaters known as the heating aspect. Heating components are available many various geometries and kinds and could be utilized in both convective or radiant space heaters. Combustion area heaters convert chemical vitality into heat through combustion of a gasoline. These heaters often don't require electricity to function and may due to this fact be used off-the-grid. Fire, burns, and carbon monoxide poisoning are the main risks of space heaters. About 25,000 fires are brought on by area heaters within the United States annually, leading to about 300 deaths. Roughly 6,000 hospital emergency division visits annually within the US are attributable to area heaters, mainly from burns. Improper use can enhance the danger of hearth and burns.
Plugging house heaters immediately into a wall outlet and never an extension cord (apart from heavy responsibility extension cords (14-gauge wire or bigger) or relocatable energy tap, as they will overheat and trigger fires. Inspecting plugs and cords periodically for cracks or harm, and changing them if needed. Keeping flammable materials, similar to paper, plastics, curtains, furniture, and bedding, at the least 3 toes (0.91 m) away from the heater. Turning off the alpha heater reviews when the final adult leaves the room or goes to sleep and holding kids and pets three ft away from the heater. Placing heaters on a flat, exhausting, nonflammable surface. Avoiding using heaters close to flammable supplies such as paint or gasoline. Installing smoke alarms and carbon monoxide detectors nearby. No one type of heater is safer than any other type. The danger of fire and burns can vary, alpha heater discount depending on mannequin and manufacturer. 1995 by the UL standards. Additional information on portable-alpha heater discount safety may be found on the Department of Energy's Energy Efficiency website.
New York City legislation regulates the security of area heaters. Space heaters for sale in the city should have a thermostat to regulate temperature, an computerized shut-off feature if the heater tips over or overheats, and must be certified and labeled by a nationally permitted organization or laboratory. The U.S. Environmental Protection Agency has evaluated a number of house heaters, however none have obtained its Energy Star label. Tedeschi, Bob (2015-02-25). "Space Heater Reviews". The new York Times. QBIC Heating. "What Are Oil-Filled Radiators?". United States Department of Energy. National Fire Protection Agency. Missouri Department of Natural Resources. New Fix-it-yourself Manual. Pleasantville, NY: The Reader's Digest Association. Underwriters Laboratories (2000-06-21). "UL 1278, Standard for Movable and Wall- or Ceiling-Hung Electric Room Heaters". Underwriters Laboratories (2009-08-31). "UL 1042, Electric Baseboard Heating Equipment". General Services Administration (1977-09-13). "W-H-193D, Heater, Space, Electric (Portable)". Department of Energy (2011-02-09). "Portable Heaters". Environmental Protection Agency. "Space Heaters".
