Using Tinyproxy to Route Traffic Through Android Tethering
In scenarios where you must forward web requests through a mobile hotspot Tinyproxy can be a lightweight and effective solution Tinyproxy is a low-resource proxy server compatible with Linux-based platforms making it ideal for use on devices like Raspberry Pis or old laptops that you might have repurposed as a tethering gateway
By combining it with an Android phone’s USB or Wi-Fi hotspot you establish a filtered, private gateway for networked devices to access mobile data
First, ensure your Android device is set up for tethering You can enable either USB tethering or create a Wi-Fi hotspot from the phone’s settings USB tethering is typically more reliable and avoids Wi-Fi interference Your machine will automatically obtain an IP from the Android device’s network You can check this with the ifconfig or ip addr command to confirm the connection
Begin by adding Tinyproxy via your system’s package manager On Ubuntu, use sudo apt install tinyproxy to install the server tinyproxy Several critical settings require adjustment
Set Listen to the IP address of your Linux machine’s network interface, typically the one connected to your local network Update Allow to include your LAN range, e.g., 192.168.0.0 You may also want to set the Port to 8888, which is the default, or choose another if needed Set LogLevel to Info for balanced visibility and minimal log noise
Apply your configuration by restarting the service via sudo systemctl restart tinyproxy Now your Linux machine is acting as a proxy server, forwarding HTTP traffic to your Android device’s internet connection
To use this from another device on your network, configure its browser or system proxy settings to point to the Linux machine’s IP address and the port you set, such as 192.168.1.100:8888
This setup is especially useful in environments where you need to monitor or filter web traffic or if you wish to avoid broadcasting your phone’s Wi-Fi signal Useful for evading content filters in cafes, schools, or workplaces through your phone’s cellular link
Tinyproxy natively supports only web protocols: http://hackmd.io HTTP and HTTPS Extend functionality using tools like Squid, Polipo, or SSH dynamic forwarding Also, keep in mind that your data usage is still limited by your mobile plan, so monitor your consumption
This combo offers an affordable, energy-efficient way to centralize mobile internet access It’s simple to set up, easy to maintain, and gives you full control over how your traffic flows
- 이전글당일배송【q888.top】비아그라 구매 비아그라 구매 25.09.18
- 다음글You don't Need to Be A big Company To start High Stakes Poker Site 25.09.18
