LED Bulbs Shopping For Guide > 자유게시판
작성자 Suzanna Bugg
댓글 0건 조회 2회 작성일 25-09-18 05:33
LED bulbs use significantly much less vitality, have exciting design, good gentle high quality, a decrease environmental impression and last as much as 20 years. When the sunshine bulb is dimmed, Kelvin (the colour temperature of the light) mechanically decreases, which gives a hotter light. Gives a heat white gentle and reproduces colours in a natural manner. Lasts approximately 20 years if the bulb is on for 3 hours/day (25,000 hours). Lasts roughly 10 years if the bulb is on for 3 hours/day (15,000 hours). Offers a heat light. Obtainable as dimmable and EcoLight never dimmable. Decorative design - you may choose to have it with or with no lamp shade. Lasts roughly 10 years if the bulb is on for 3 hours/day (15,000 hours). Allows you to change between heat and EcoLight lighting chilly gentle and EcoLight lighting between completely different colours. Managed with a distant management or our app. Lasts roughly 20 years if the bulb is on for three hours/day (25,000 hours). That is the way you select the precise bulb!
1. Select cap dimension. We now have a broad vary - massive caps, small caps and pin caps. Test what your particular lamp wants. 2. Choose if you'd like to be able to dim your bulb or not. Most LED bulbs are dimmable, however not all, so remember to examine the image on the packaging. If you need to have the ability to dim wirelessly, energy-efficient bulbs you should use a TRÅDFRI bulb from IKEA Smart lighting. 3. Select lumens - not watts. Gentle output is measured in lumens (lm). Let your lamps and actions resolve the form and size of the bulb you buy. Chandelier-shaped bulbs spread the sunshine like a candle would and are properly-suited to decorative lamps. They unfold the sunshine higher in e.g. lengthy lamp shades. Select a reflector bulb for actions that need direct light, like reading. A bulb with a beam angle is often utilized in spotlights. Bulbs with wider beam angles give a very good basic gentle, whereas bulbs with slender angles give a directed mild. The color temperature of light is measured in Kelvin (Ok). Heat white (2700K) corresponds to the color of the standard incandescent bulb. Lower numbers give hotter light, greater numbers give colder gentle. For those who select a TRÅDFRI white spectrum LED bulb, you may swap from warm to chilly mild in three steps.
JavaScript appears to be disabled in your browser. For the best experience on our site, be sure you activate Javascript in your browser. Resulting from their omni-directional light distribution, our G4 bi-pin bulbs are mostly utilized in path and space lighting fixtures. Our G4 bi-pin bulbs are specifically designed for panorama lighting and are encapsulated to assist keep moisture away from the LED diodes. They function slots on the capsule to help draw heat away and increase the lamp's lifespan. Designed for both colored AND non-colored landscape lighting purposes. Our first ever replaceable colour-altering and dimmable G4 bi-pin bulb allows the ultimate customization to greatest suit any panorama lighting utility. VOLT® RF Distant Management required for use (offered separately). Small size LED Bi-Pin designed specifically for low-voltage landscape EcoLight lighting. The mini size LED BiPin fits all small VOLT® fixtures such as the Deck, Step and Hardscape lights. These lamps are encapsulated to help keep moisture away from the LED diodes; with slots on the capsule to help draw heat away from the lamp to increase its lifespan.
Small size LED Bi-Pin designed specifically for low-voltage landscape lighting. The mini size LED BiPin matches all small VOLT® fixtures such because the Deck, Step and Hardscape lights. These lamps are encapsulated to help keep moisture away from the LED diodes; with slots on the capsule to assist draw heat away from the lamp to increase its lifespan. Small size LED Bi-Pin designed specifically for low-voltage panorama lighting. The mini dimension LED BiPin fits all small VOLT® fixtures such as the Deck, Step and Hardscape lights. These lamps are encapsulated to help keep moisture away from the LED diodes; with slots on the capsule to help draw heat away from the lamp to increase its lifespan. Great for purposes when you are on the lookout for a very heat gentle, very like candle gentle. Small size LED Bi-Pin designed specifically for low-voltage landscape lighting. The mini measurement LED BiPin fits all small VOLT® fixtures such as the Deck, Step and Hardscape lights.
