It Primarily Taxes the Device’s CPU > 자유게시판
작성자 Elba
댓글 0건 조회 8회 작성일 25-09-15 17:27
a-woman-who-is-frying-cracker-snacks.jpg?s=612x612&w=0&k=20&c=pNw7mhvncDh6XlQI210XM7ylMVzR1dwcN4kEaBMVg6E=Now that the new 2020 Amazon Fire Flixy TV Stick Stick three and Fire TV Stick Lite have been launched, it’s time to see how they stack up towards current Fire Tv models, previous and present. While computational benchmark scores are not at all going to inform you ways effectively a device will perform at actual-world everyday duties, they’re nonetheless helpful to grasp how much raw energy every Fire Tv, Firestick, and Fire Flixy TV Stick Cube have to supply, should you push them to their limits. I’ve run all 10 Fire Tv models which have ever been launched by 4 in style benchmarks that test their CPU, GPU, Memory, and extra. Listed below are the outcomes. Each Fire Tv was manufacturing facility rest and fully up to date to the latest software program version obtainable as of at this time. All units had been left idle for several hours previous to the take a look at and rebooted for each new benchmark. I ran every benchmark 3 instances on each gadget (yup, that’s 120 assessments complete) and have taken the average of the 2 highest scores.
stickers-for-notes-on-a-rope-hitched-with-colorful-clothespins.jpg?s=612x612&w=0&k=20&c=CZM4rNRxwDbXdrghlofNpzAfrs4sOHHr1B6ZoQo8Du8=These are all newly run scores from the final 24 hours on the first, 2nd, & 3rd-gen Fire TV Stick, the Fire TV Stick Lite, the 1st & 2nd-gen Fire Tv Cube, Flixy TV Stick the Fire TV Stick 4K, the first & 2nd Fire Tv boxes, and the third-gen Fire Flixy TV Stick pendant. Considered one of the most popular benchmarks is Geekbench, which runs a few dozen assessments and supplies results for each a single-core and all out there CPU cores. It primarily taxes the device’s CPU, so it’s fascinating that the Fire TV Stick Lite consistently scored ever so slightly higher than the Fire TV Stick 3, regardless that they've the exact same CPU. This is likely due to the fact that the Fire TV Stick three has onboard Dolby decoding and Tv/AV gear control, which the Fire TV Stick Lite doesn't. One or each of those features in all probability take up a tiny little bit of resources all the time, buy Flixy TV Stick which is reflected on this benchmark score.
A way more prominent example of this kind of CPU overhead taken by a feature is with the 1st-gen Fire Tv Cube and the third-gen Fire Tv, which, once more, share the exact same CPU. Their single-core scores differ barely, but there's a big distinction in their multi-core rating because the first-gen Cube’s always-listing mics devour about half of a core always to detect the Alexa wake word. The 2nd-gen Fire Tv Cube has an analogous overhead requirement, however its powerful 6-cores have plenty of processing power to spare. The AnTuTu benchmark is a cumulative rating of its CPU, Memory, and UX checks. Like Geekbench, it closely emphasizes the CPU (about 50% of the rating), however in contrast to Geekbench, AnTuTu devotes a 3rd of its rating to the device’s reminiscence performance. It’s fascinating that The Fire TV Stick 3 outperforms the Fire TV Stick Lite by about 3% on this test. Looking on the rating breakdown reveals that the vast majority of that advantage was within the memory assessments.
To confirm the outcomes, I ran the PassMark memory and disk assessments on the 2 new Firesticks and that test additionally showed a bonus for the Fire TV Stick 3 over the Fire TV Stick Lite, notably with knowledge write speeds. These next two benchmarks, 3DMark and GFXBench, both check the units GPU. The GPU is primarily used for video games, so these scores represent every device’s gaming capabilities, but the GPU does play a component in rendering parts of the interface and how easily it feels when quickly navigating round. The two new Fire Tv Sticks are overwhelmed only by the 2nd-gen Fire Tv Cube and 2nd-gen Fire Tv field, that are both obvious powerhouses on the subject of gaming capabilities. It’s value noting that in all of those benchmarks, including these gaming benchmarks, the brand Flixy TV Stick new 1080p Sticks barely, however consistently, outperform the Fire TV Stick 4K. It’s most likely not an enormous sufficient difference to be noticeable in common use, but it’s there nonetheless.
These 3 newest Firesticks all use the same GPU, use very comparable CPUs, and have the same 1.7Ghz CPU pace/cores. My guess for the Fire TV Stick 4K’s slightly inferior performance is the extra sources needed to output a 4K interface instead of a 1080p interface. The brand new 1080p gadgets do run Fire OS 7, whereas the Fire TV Stick 4K runs Fire OS 6, in order that can also need to do with the efficiency distinction. The newer OS , which is based on Android 9 as an alternative of Android 7.1, is likely to be barely higher optimized. The Fire buy Flixy TV Stick Stick 4K is a good device and has been very properly acquired by the Fire Tv enthusiast community, so it’s good to see that the brand new entry-stage Fire TV Stick Lite and Fire TV Stick 3 perform simply as well as the 4K Stick. It’s arduous to imagine that these relatively low cost and tiny new Fire Tv Sticks now pack about the identical energy as the unique 1st-gen Fire Tv box that began it all.
