Frequently Asked Questions > 자유게시판
작성자 Alejandrina
댓글 0건 조회 9회 작성일 25-09-14 18:11
41ayxPRlQUL.jpgA bug zapper attracts mild sensitive insects using an Ultraviolet (UVA) lengthy wave globe. As gentle delicate insects fly towards the globe, they pass via an electrified killing grid, Zap Zone Defender zapping them on entry. Cats, dogs and birds don’t usually react to the sounds of a bug zapper however if your pet reacts negatively; switch off your bug zapper and ZapZone Defender relocate it away from your pet. Bug zapper grids have a high voltage, but a low current. Any contact with the grid will end result with an electric shock, like that of an electric fence or a automobile battery. The shock will harm however isn’t harmful for ZapZone Defender people in good well being. The design and security options of outer cage prevents any entry to the electrified grid on every bug zapper model. Yes, all out of doors bug zappers are weatherproof and will be put in and operated outdoors however keep the plug and socket undercover.
stinger-bug-zappers-electronic-repellents-tz15v2-64_400_compressed.jpgOnly the Insect Control station and Secta Rid business zappers are not suitable for outside use. Our range of bug zappers is constructed from flame retardant plastic or steel. If for Zap Zone Defender any purpose they ignite, they may routinely extinguish and melt, however won't burn. It is a requirement of Australian Safety Standards. The most effective and Zap Zone Defender Testimonial efficient method to run a bug zapper is to leave it on 24/7. By doing this, you assist break down the insect breeding cycle. Alternatively, run your bug zapper from dusk to daybreak. Only indoor bug zappers are provided with catch trays (Bug Sentinel, Home Insect Control Station and SectaRid commercial bug zappers). Outdoor models will not be provided with catch trays. 71475 (RB20) on the shelf. U form and Edison screw globes have a 5-digit catalogue number beginning with a "7" on the plastic rim of the globe. For substitute straight globes with 2 pins either side, ZapZone Defender the catalogue number is situated on the bug zapper rating label.
Insect Control Station & Bug Sentinel: Rating label is underneath the bug zapper base. Yard Guard/ Stinger/ Mozzie Attack / Bug Destroyer/ Mosquito Trap: Rating label is positioned inside the cage and under the hood. Bug Vac: Rating label is on the again of the bug zapper. SectaRid items: Rating label is on the aspect of the bug zapper. Replace a bug zapper globe when the bulb is turning black at the ends, is flickering, stopped illuminating or appears dull. The best location for an outdoor bug zapper is away out of your dining / seating space. For added info, discuss with the set up ideas in the bug zapper handbook. We counsel that a bug zapper be situated not less than 2 metres away from where you sit (if doable) and not less than 1.5 metres excessive, ZapZone Defender areas resembling an awning or the outside of a balcony are ideal. Don't position the bug zapper above a dining table, above a pool or above a heat supply.
Other Stinger and Yard Guard fashions will function indoors, however clean the zapper and it’s resting floor regularly stopping the construct up of dead bugs. Dead bugs are brittle and will catch fireplace. Catch trays for outside models will not be accessible. Insect Control Station & Bug Sentinel: Rating label is under the bug zapper base. Yard Guard/ Stinger/ Mozzie Attack / Bug Destroyer/ Mosquito Trap: Rating label is located inside the cage and below the hood. Bug Vac: Rating label is on the again of the bug zapper. SectaRid units: Rating label is on the facet of the bug zapper. Replace a bug zapper globe when the bulb is turning black at the ends, is flickering, stopped illuminating or appears dull. Which insect killer is finest for my household? Stinger 20W / Stinger 40 / Mozzie Attack Plus/ Bug Blaster/ Bug Destroyer: are suitable for suburban blocks, apartments, townhouses, areas without giant insect infestation.
20 watt is most suited to a ½ acre block. Forty watt is most suited to a bigger suburban block. Yard Guard Bug Vac / Yard Guard Mosquito Trap: are appropriate for suburban, semi rural or rural applications, areas with giant and smaller insect infestations. Stinger Solar Bug Zapper: is suitable for suburban areas with out entry to mains energy. Bug sentinel can also be used outdoors, protects over eighty Square metre space. Yard Guard Bug Vac / Yard Guard Mosquito Trap: are suitable for suburban, semi rural or Zap Zone Defender rural functions, areas with giant and smaller insect infestations. Stinger Bug Sentinel/ Home Insect Control Station: Suitable for Indoor use. Bug sentinel may also be used outdoors, protects over 80 Square metre area. Sectarid SR20 Design/ Décor/ Luralite: are appropriate to be used in homes, commercial kitchens, eating places, cafes, waerehouse and industrial use, supermarkets. Sectarid SR20C, SR20SS, ZapZone Defender SR40A SR40SS, SZ40: are suitable to be used in homes, warehouses, schools and industrial settings.
