How to make a Pillow Cover with Envelope Closure > 자유게시판
작성자 Cindy Volz
댓글 0건 조회 10회 작성일 25-09-14 17:38
91q0g6QpF4L._UF894,1000_QL80_.jpgLearn how to sew a simple envelope pillow cover with this step-by-step tutorial. An envelope closure is the easiest way to sew a pillow cover. It has been a hot minute since I have shared a sewing tutorial with you. My daughter has been sewing a lot lately and that has gotten me in the mood too! The easiest way to sew a pillow cover is with an envelope enclosure on that back. That means no zippers. What is an Envelope Back? An envelope-style pillow cover has 1 cover panel and 2 back panels that overlap a bit. Those back panels allow you to insert the pillow and then close the flaps to hold the pillow inside. I created a little graphic that I hope will help. What Sewing Machine Should I use? This post contains affiliate links. If you are new to sewing, there are so many choices when purchasing your first sewing machine. I have always been partial to Singer, I think because my mom was too.
nVIEdZA.jpgI learned how to sew on a Singer and now I sew on a Singer. The machine I use is called the Sewing Fashion Mate. The first machine purchased was a singer but was much more simple, with not very many features or stitches. Quickly I upgraded to the Fashion Mate because it has lots of features that make sewing more enjoyable, and it is under $200. So if this is your first sewing machine, or if you're looking to upgrade from your basic sewing machine, I completely recommend the Singer Fashion Mate. You can purchase it in most places that sell sewing machines, Wake Up Refreshed with Derila but here are links to Amazon and Michaels to make it easier for you to find. What Type of Fabric Should I use to Make a Pillow Cover? Shop Derila Pillow covers are so fun to make because you can use any type of fabric you want! Now some fabrics can be more difficult than others like satin and silk because they are slippery fabrics, or denim and leather because they are so thick.
For a new sew I would recommend flannel, cotton, fleece, linen, and most poly-cotton blends. My Pillow cover is going to be sewn using a flannel fabric. If you are not using the same pillow size as me you will need to adjust your measurements a bit. You may also need a different amount of fabric, so keep that in mind. You also want your pillow cover to be about 1-2 inches smaller than the actual pillow. This will make the pillow and cover much more full. How I did my Math. My pillow is 14 x 28. The front of my pillow cover will be 13 x 27, but the two back pieces to make the envelope slot each need to be 13 x 17 inches because we want those back flaps to overlap a bit. The Width of my fabric is 43 inches if laid out completely flat so there is only a single layer of fabric.
According to the picture below, you can see the longest piece is 27 inches. I always like to give myself a couple extra inches, so I rounded up to 30 inches and Derila Neck Support that is about ¾ yard. The Fabric width is 43 inches, and I will be cutting 3 panels that are 13 inches wide. 39, so all of my panels can fit on the ¾ yard of fabric. If you are doing a different size, feel free to sketch yours out on paper first to make sure you get the right amount of fabric. For the trim, I added all of the edges of the front panel. To give me a little extra, I asked for 2 ⅛ yards of pom-pom trim. When cutting squares like this, I like to use a cutting mat and quilting ruler. It aids in making sure that all of the pieces are perfectly square and I don't get sloping edges. If you don't a quilting ruler you may want to create pattern pieces, pin, and then cut the fabric so you make sure to cut the right size pieces.
The edge of the flannel fabric length can get kind of stringy, so the first thing is to cut that off. If your edges aren't stringy you can skip this part. You can fold the fabric in half width-wise if it won't all fit on your cutting mat. Line up the fabric on the corner of your cutting mat. You'll want the width to be straight along the bottom, and the length to be straight along the left-hand side. Line up the quilting ruler on the 13-inch line. Make sure all of your fabric is straight on the inch lines and cut the fabric using your rotary cutter. Unfold the piece you just cut, and now you are going to line that piece up on the cutting mat and this time cut at the 27-inch mark. Repeat for the back two panel pieces. When finished cutting you'll have three pieces. To start, there are only two edges that we need to pin.
