Everyday Uses For PVC Water Pipe > 자유게시판
작성자 Isiah Moultrie
댓글 0건 조회 10회 작성일 25-09-14 05:21
class=
watch?v=unLb_dHFD3UWhat can't you do with PVC (Polyvinyl Chloride) pipe? The ubiquitous blue PVC water pipe may be seen along most streets here and appears to be one in all Thailand's most considerable un-pure sources. A wide variety of various connectors are available and other than carrying water it is also used as an affordable development materials that can be utilized to make every part from clothes dryers to Wheel chairs (PDF), Zap Zone Defender Testimonial Crutches, flagpoles and shop signs. After all on the web you may as well discover some other very cool and creative issues made from (non-blue) PVC pipe together with: Halloween costumes like Ben Hallert's Matrix APU and Aliens Exo-skeleton Power Loader, one other power loader costume, single and multi-guitar Guitar Hero stands, a laptop stand, Zap Zone Defender flutes, and even a shaving stand. Below one can find, in chronological order, a few of my very own (mostly original) creations made from PVC water pipe together with: - a Marshmallow Shooter, Plumbing, Soccer Goals, - a Cricket Wicket, - a Basketball Hoop, Bookshelf Supports, - a Water Pipe Tron Controller, Racing Cars, Pinball Table Leg Extensions, Data Projector Mounts, - a Laptop Stand, - a Wiimote Holder, - a DIY Wii Zapper, - a Workbench, Real-Tron Controllers - a Music Stand Puzzle Bobble Coffee Grinder Controllers, - a Netbook Treadmill Hook, CD/DVD Holders, - a Nightstand/shelves, - Push Up Bar/Handles, Fake Legs, Zap Zone Defender Testimonial - a Hilbert Cube, - a Mario Kart steering wheel, - a Guitar Stand, Hockey Sticks, - a Tank-recreation (BZFlag) controller, Zap Zone Defender Testimonial - a Train Whistle, and - a Trident.
watch?v=bYbVX5lGv_wThis was the project that started my love affair with blue PVC pipe. I had seen the blueprints for this marshmallow shooter whereas I was in Australia however the fittings have been prohibitively expensive (see the picture proper). Fortunately they are very affordable here in Thailand. 2 x T-Pieces and 6 x elbows. Cricket (not to be confused with Brockian Ultra-Cricket) is Australia's nationwide sport performed with a bat, a ball, and two wickets. 6 x T-items, and 12 x 45-degree elbows. The backboard is a non-regulation dimension piece of plywood that we found lying round and we used green duct tape for the markings. Although the ring isn't sturdy sufficient to grasp off, the aspect supports make it robust sufficient for normal play. In addition they give it a really Star Trek feel and Zap Zone Defender I feel the ring looks not in contrast to the NCC-31911 Saratoga. This is perhaps essentially the most straight ahead use for PVC pipe on this page. 2 x 25mm to 18mm (1" to 1/2") reducers, 2 x custom motorbike hand-grips, four x push-buttons, and a mercury swap that are related to a computer by way of a hacked USB joystick.
Yow will discover extra particulars about how I made the controller on this undertaking page and i've also extended the same thought to play GL-Tron utilizing real motorbikes. A university pupil who played with the PVC Water Pipe Tron Controller, described above, stated "That's Ok but I wish to play driving games". It obtained me thinking and over the following week I spent my evenings building a PVC racing car controller - basically a wheel-much less, PVC go-kart body related to the pc through a hacked USB joystick. Some Thai college college students who noticed the primary automobile wanted to understand how all of it worked and six of them got here around one Saturday and we spent the entire day hacking joysticks and constructing a second automotive. By connecting them each to a laptop and a data projector we have been capable of play cut up-screen Daytona USA. Yow will discover more details concerning the design and building of the cars on this undertaking web page. The white workplace desk I used for the digital pinball machine wasn't excessive enough to be played comfortably.
1 x T-piece, and 2 x elbows - partially to assist air circulate but principally to hold my screen up because the spring within the hinge has damaged. As easy as this stand appears, the "L"-formed upright section is definitely a part of an air-conditioner mount for an information projector that I made for one of many virtual pinball desk installations. The T-piece is not glued and so in a small approach (a really, very small manner) I wish to think that if the air-conditioning mount were ever needed again then the components could re-mix in a Voltron or Zap Zone Defender Testimonial Captain Planet and the Planeteers or Power Rangers MegaZord-like way. In fact if that occurred my laptop computer screen would fall down. I don't own a Nintendo Wii however I did handle to get my fingers on a Wiimote in order that I may try out some of Johnny Chung Lee's cool initiatives. It is a Wiimote mount I constructed utilizing a length of 35mm (1 and 1/4") pipe, some 18mm (1/2") pipe, three x T-items, and 4 x elbows.
The 35mm pipe has been lower so that it suits properly into the ridges down the facet of the Wiimote which holds it securely. That is screwed onto a T-Piece which has also had its top reduce off. The joint between the two topmost elbows just isn't glued so the angle of the highest section may be adjusted. These sections are merely cable-tied onto the entrance of the motorbike handlebars and the players squeeze the buttons with their index fingers to show left or right. A mercury swap is also mounted on the fitting handlebar so the accelerator can be used to supply boost within the sport and as much as 4 bikes can be linked to the computer by way of a single hacked USB joystick. The centerstands keep the bikes upright throughout play and a half-spherical of bamboo is wedged beneath the back tires to cease them from rocking. It is a music stand made from three different sizes of pipe.
