Ultimate Sideloading Guide for Amazon Fire tv & Fire TV Stick > 자유게시판
작성자 Dong
댓글 0건 조회 8회 작성일 25-09-12 19:53
fire-tv-stick-4k-max.png?auto=webp&fit=crop&height=1200&width=1200This information will show you the easiest ways to put in, a.ok.a. "sideload," 3rd-occasion apps on the Amazon Fire Tv and Fire TV Stick. APKs instantly onto a 1st-gen Fire Tv, 2nd-gen Fire Tv, 1st-gen Fire TV Stick, watch movies online or 2nd-gen Fire TV Stick. You do not need to make use of a pc at all and can sideload apps with simply your remote controller. This is the best technique on the web page as lengthy as the APK you need to install is downloadable somewhere on-line. If you’re questioning, sure, this methodology works to install Kodi, as do all of the methods on this page. Simplest and best method. No exterior machine vital. Can all be finished with simply the Fire Tv remote. Works for all Fire Flixy TV Stick & Fire Flixy TV Stick Stick fashions. This method makes use of an app referred to as ES File Explorer (installable directly from the Fire Tv Appstore) to download and set up APKs instantly onto a 1st-gen Fire Tv, 1st-gen Fire TV Stick, or 2nd-gen Fire TV Stick.
48912897437_83601dd960_b.jpgYou do not need to use a pc in any respect and may sideload apps with just your distant controller. The one caveat is, the APK file have to be easily downloadable by a website. No external device obligatory. Can all be carried out with just the Fire Tv distant. Works for all Fire Tv & Fire TV Stick models. Slow if sideloading many APKs at once. Tedious to navigate some websites with Fire Flixy TV Stick remote. This technique makes use of an app known as Total Commander (installable immediately from the Fire Tv Appstore) to put in APK files saved on a USB drive. This technique works for watch movies online the 1st-gen and 2nd-gen Fire Tv, but doesn't work for the Fire TV Stick as a result of it doesn't have a typical USB port. You solely want a pc to switch the APK recordsdata you need installed onto the USB drive. Then you are able to do the whole lot else instantly on the Fire Tv with out the necessity of a pc or ADB.
class=
This method is good if you would like to install many APKs directly or very large APKs because you don’t need to look forward to each to be transferred to the Fire Tv. Fastest method to put in many APKs without delay. Fastest approach to put in very large APKs. Requires a USB drive. Only works for 1st and 2nd-gen Fire Tv. Doesn't work for Fire TV Stick. That is the basic methodology that makes use of the Android Debug Bridge (ADB). ADB is a small utility used to remotely perform tasks on Android units. ADB could be very helpful and is used in practically all guides on this site. While this is not the easiest or quickest approach to sideload APKs onto a 1st-gen Fire Tv, 2nd-gen Fire Tv, or Fire TV Stick, it's the advisable methodology since it prepares you and your computer for all other guides and mods. No need to work together with Fire Tv after initial setup.
Installs APKs remotely from a pc. Prepares you for different guides by having you install and grow to be familiar with ADB. Works for all Fire Tv models: 1st-gen, watch movies online 2nd-gen, and Stick. First set up takes longer as a consequence of ADB setup. Transferring APK to Fire Tv is gradual. Command-line interface could also be intimidating. This methodology makes use of adbFire, which is a person-pleasant pc utility made particularly for the Fire Tv. Functionally, adbFire is equivalent to using the ADB command-line. One downside to adbFire is that if you happen to encounter an issue, there’s generally no method to know what went unsuitable as a result of adbFire hides the command-line messages with the intention to current a easier interface. No must work together with Fire Tv after preliminary setup. Installs APKs remotely from a pc. Fire can perform many other tasks. Works for all Fire Tv fashions: 1st-gen, 2nd-gen, and Stick. Sometimes no indication of errors if something fails. Transferring APK to Fire Tv is slow. This is the traditional methodology that uses the Android Debug Bridge (ADB).
ADB is a small utility used to remotely carry out tasks on Android units. ADB could be very helpful and is used in almost all guides on this site. While this isn't the best or fastest way to sideload APKs onto a 1st-gen Fire Flixy TV Stick, 2nd-gen Fire Tv, or Fire TV Stick, it's the advisable methodology because it prepares you and your computer for all other guides and mods. No must work together with Fire Tv after initial setup. Installs APKs remotely from a computer. Prepares you for other guides by having you set up and become accustomed to ADB. Works for all Fire Tv models: 1st-gen, watch movies online 2nd-gen, and Stick. First install takes longer attributable to ADB setup. Transferring APK to Fire Tv is sluggish. Command-line interface may be intimidating. This method uses adbFire, which is a consumer-pleasant computer utility made specifically for the Fire Tv. Functionally, adbFire is equivalent to using the ADB command-line. One downside to adbFire is that should you encounter an issue, there’s generally no technique to know what went flawed as a result of adbFire hides the command-line messages with the intention to present a easier interface. No have to interact with Fire Tv after preliminary setup. Installs APKs remotely from a computer. Fire can carry out many different tasks. Works for all Fire Tv models: Flixy TV Stick 1st-gen, 2nd-gen, watch movies online and Stick. Sometimes no indication of errors if something fails. Transferring APK to Fire Tv is slow. In case you have an Android cellphone or pill, you should use an app referred to as AGK Fire to sideload apps onto a fire Tv. The big advantage of AGK Fire is it could switch any app put in in your Android device to the Fire Tv. This means which you could simply install many apps in the Google Play retailer to your Fire Tv.
