How To Beat Guangzhi In Black Myth: Wukong > 자유게시판
작성자 Geri
댓글 0건 조회 2회 작성일 25-09-12 18:25
In short, the majority of settings that differ in the default Performance/Quality mode profiles are minor details . Players will be able to enjoy the same high render distance, visual smoothing, texture quality, and post-processing effects on either profile. They may, however, notice some dips in quality when looking at vegetation - sparser blades of grass, or blurrier leaves on trees, for example. Lighting will look less realistic overall, and the visual effects created by the Destined One's magical attacks may not look quite so impressive. Even so, the profiles are, for the most part, pretty simi
Continue descending the wooden pathway until you reach a large body of shallow water, where the boss fight occurs. Whiteclad Noble stands in front of a large temple waiting to face you, which will automatically trigger a short cutscene before the fight sta
Now that you can zip around the arena just as deftly as Guangzhi, and you're stocked with some appropriate medicines, we can finally start trying to take him down. Guangzhi's arena is relatively small in comparison to the quick moves he has, and you'll often find yourself back against the wall if you dodge around with no real purpose .
Black Myth: Wukong 's Performance and Quality modes work much like other games that have instituted similar functions: Performance mode displays the game at a slightly lower overall quality, but runs more consistently at a higher frame rate, while Quality mode displays the game at the maximum possible graphical settings (or close to them), but at a potentially lower frame rate . The recommended specs for PC are as foll
You'll come across Xu Dog for the first time in Chapter 2 near the Village Entrance Keeper's Shrine in Sandgate Village . From this point, drop from the wooden bridge to your right to the gorge below to find Xu Dog in a cave with foxes painted near its entrance. Talking to the NPC for the first time will start their questline, which is tied to the crafting of basic medici
Once you take down Lang-Li-Guhh-Baw, you'll receive the Evil Repelling Medicament formula that Xu Dog was looking for. R eturn to Xu Dog to unlock the ability to craft regular Medicine at Keeper's Shrines throughout the game. The materials vary for each Medicine you want to craft, but you have to find recipes for each item first by either finding them in the world or buying them from Xu
Guangzhi is one of these bosses, a wolfman who's quick on his feet and even quicker with his spear. His weapon is also doused in fire , making him pretty tricky to deal with so early in the game. We're here to help cool things down though, and you'll have Guangzhi down faster than you can say "good boy."
Heading left from the Wandering Wight's location will lead you to another Yaoguai Chief optional boss named Guangzhi. Defeat Guangzhi to gain a transformation , an ability that allows you to turn into the beaten boss for a limited time. While fighting in this alternate form, you don't take damage to your main health bar, but instead only have your transformation timer reduced as you get
This acts as a buffer to avoid taking damage from the Wandering Wight, while also giving you a chance to deal higher damage as Guangzhi. It's also a good idea to have the spell Immobilize unlocked before fighting the Wight. This spell may consume a lot of mana at the early stages of Black Myth: Wukong , but it gives you a chance to freeze the Wight for a short time during the bat
When you enter a Keeper's Shrine, select the "Make Medicines" option to start crafting. As you gain more formulas, you'll be able to make more medicines using the various plant life you harvest during your travels. For example, the Evil Repelling Medicament, the first formula you learn, can greatly increase your damage reduction for a long duration when you make it using a Licorice and Jade Lotus pl
While using your Gourd will be your primary source of healing, some consumable items you can bring along may save your life during the boss fight against White Clad Noble. As he doesn't deal any elemental-based damage, the best consumable to bring is the Evil Repelling Medicament, an Uncommon Alleviating Medicine that significantly increases Damage Reduction pop over to this web-site a long durat
This is an excellent choice for Whiteclad Noble, who has high mobility. While Crash is also a great option, which moderately increases the damage dealt to enemies that are Immobilized, Stagnation allows you to deal more overall damage throughout the boss fi
Most of these attacks are very quick, but rhythmic . A lot of work to beat Guangzhi is all about recognizing the move that's about to come out, and then dodging rhythmically through his attacks , which will then leave him open to your own.
But again, some players may prefer to use Quality mode anyway, even if it results in a slightly lower frame rate. The game is perfectly playable, if a little jumpier, on this setting. Ultimately, it all comes down to the player's preference of how to play _Black Myth: Wukong
