How To Find (& Beat) The Wandering Wight In Black Myth: Wukong > 자유게시판
작성자 Antonetta Dove
댓글 0건 조회 2회 작성일 25-09-12 08:57
Black Myth: Wukong 's Performance and Quality modes work much like other games that have instituted similar functions: Performance mode displays the game at a slightly lower overall quality, but runs more consistently at a higher frame rate, while Quality mode displays the game at the maximum possible graphical settings (or close to them), but at a potentially lower frame rate . The recommended specs for PC are as foll
If you happen to get the "Cannot absorb spirits without guidance" message near the Wight's corpse, simply return when you get the right Gourd. Those who beat the Wandering Wight in **Black Myth: Wukong ** will find the body of the boss still in the area, with the flame of its spirit ready to aid you in battles to c
For those who are still unsure, **Black Myth: Wukong offers a benchmark tool that allows them to determine which settings are best for their individual system's specs ** . The Wukong benchmark is available for free via Steam , and tests a PC's capability by rendering a scene from the game and evaluating its performance. This will return a recommended group of settings for the full SLG game patch notes, and ultimately, a judgment about whether a PC is capable of running the game. Players can use this benchmark ahead of downloading the game to determine which settings work best for t
Without a plan, the Wandering Wight will be nearly impossible to beat with your base stats, skills, and equipment. You need to at least craft some gear using Sparks gathered from enemies to give yourself higher defenses while fighting this boss. There are other secrets in the extensive map areas of Black Myth: Wukong that you can also investigate to gain advantages against the Wi
Another consumable worth considering is the Fortifying Medicament, another Alleviating Medicine that enhances the Tenacity of certain staff abilities . Using this will make your Stances and attacks less susceptible to interruptions for a short duration, which is extremely useful given that Whiteclad Noble can stagger players immens
One of the best strategies for beating the Wandering Wight is to land heavy attacks against the boss whenever you can. Although you have to time these as the boss recovers from its attacks, striking the boss with a heavy attack from Smash stance will stagger it for a short time. This does consume a Focus Point, so you'll have to build up light attacks to be able to do this move ag
Try to explore many of the areas of the forest to see what items you can get before facing the Wandering Wight. Defeating the basic enemies here, who reset when you return to a Shrine, will help you earn Sparks to level up. Just open the "Self-Advance" tab when resting at a Shrine to improve your stats or make abilities stronger by spending Sparks you get from farming enemies close to where the Wight resi
When you finish Xu Dog's request, he leaves to find a furnace deeper within some nearby caves, disappearing from you for the next few hours. You should run into him again in the cellar under the Crouching Tiger Temple seen in a later section of Chapter 2. Progress through the story naturally to come across this location as you reach new areas in Black Myth: Wukong 's extensive region m
For any boss battle in Black Myth: Wukong , selecting your Stance is integral to preparing for your combat strategy. When going against Whiteclad Noble, the Pillar Stance is the most effective way to level up, as it allows you to perch on top of your staff before using your Heavy Attack to strike enemies from ab
This acts as a buffer to avoid taking damage from the Wandering Wight, while also giving you a chance to deal higher damage as Guangzhi. It's also a good idea to have the spell Immobilize unlocked before fighting the Wight. This spell may consume a lot of mana at the early stages of Black Myth: Wukong , but it gives you a chance to freeze the Wight for a short time during the bat
With that in mind, Guangzhi is much less threatening at a distance , and while he does have some moves that can hit hard if you fail to dodge through them, they're much easier to see coming. A lot of these attacks also leave Guangzhi wide open to a full light combo , which will stagger him and give you some respite.
Heading left from the Wandering Wight's location will lead you to another Yaoguai Chief optional boss named Guangzhi. Defeat Guangzhi to gain a transformation , an ability that allows you to turn into the beaten boss for a limited time. While fighting in this alternate form, you don't take damage to your main health bar, but instead only have your transformation timer reduced as you get
Black Myth: Wukong has a dizzying number of boss fights for you to tackle, with three in the game's first hour alone. With the lack of tools at your disposal, and the fact you're still getting used to your squishy monkey body, these bosses can pack a punch if you go in unprepared.
Talking to Xu Dog again **unlocks the option to "Make Medicines - Celestial Medicines" when interacting with the NPC ** . You can't make Celestial Medicines at a Keeper's Shrine like regular ones, as the furnace Xu Dog found is the only device that can properly make them. You won't have to defeat any bosses this time, but you'll have to search for new and rarer materi
