How To Craft Medicine In Black Myth: Wukong
Try to explore many of the areas of the forest to see what items you can get before facing the Wandering Wight. Defeating the basic enemies here, who reset when you return to a Shrine, will help you earn Sparks to level up. Just open the "Self-Advance" tab when resting at a Shrine to improve your stats or make abilities stronger by spending Sparks you get from farming enemies close to where the Wight resi
While using your Gourd will be your primary source of healing, some consumable items you can bring along may save your life during the boss fight against White Clad Noble. As he doesn't deal any elemental-based damage, the best consumable to bring is the Evil Repelling Medicament, an Uncommon Alleviating Medicine that significantly increases Damage Reduction over a long durat
When you enter Whiteclad Noble's second phase, triggered by another cutscene, his health bar will go back to full , and he will transform into his true form, which appears to be a water-based Naga. While most of his attacks don't seem to change inherently, they appear to have further reach, and his mobility improves, using the water to his advant
As per usual, better specs are always preferred, but these recommended settings should be more than sufficient to run the game at either Performance or Quality mode . The game may also run on systems with lower specs, but at the cost of certain graphical settings - for instance, setting the majority of the options to Medium instead of H
Make sure to follow the pathway towards the back of the boss arena to interact with the Bell before returning to the marsh, where you can progress into the cave to continue chapter 1 in **Black Myth: Wukong
During and between many of these attacks, Whiteclad Noble rapidly moves around the arena , which can be a little overwhelming, given his speed. This can disorientate you if you don't watch carefully, allowing him to hit you from many different sides and ang
Defeating the Wandering Wight rewards you with 1,049 XP, 700 Will , 3 Yarn , and several other small items. Among the items you get is the * *Blood of the Iron Bull rare crafting material , alongside a special curio called Cat's Eye Beads . This curio increases your critical hit chance , which could be useful against the other bosses you'll have to face throughout Chapte
Now that you can zip around the arena just as deftly as Guangzhi, and you're stocked with some appropriate medicines, we can finally start trying to take him down. Guangzhi's arena is relatively small in comparison to the quick moves he has, and you'll often find yourself back against the wall if you dodge around with no real purpose .
While you will only have the Immobalize Mysticism in Black Myth: Wukong , you can choose to give it some enhancements through its skill tree. Immozalize is a control spell which freezes the enemy in place , allowing you to deal damage for a short duration until they break free from
Black Myth: Wukong 's Performance and Quality modes work much like other games that have instituted similar functions: Performance mode displays the SLG game Tips at a slightly lower overall quality, but runs more consistently at a higher frame rate, while Quality mode displays the game at the maximum possible graphical settings (or close to them), but at a potentially lower frame rate . The recommended specs for PC are as foll
Guangzhi is definitely at his strongest and most unpredictable when you're up close and personal . His attacks that are trickier to dodge and quick almost always come out when you're next to him, and his attacks from further away are very clearly telegraphed .
Most of these attacks are very quick, but rhythmic . A lot of work to beat Guangzhi is all about recognizing the move that's about to come out, and then dodging rhythmically through his attacks , which will then leave him open to your own.
The Wandering Wight also leaves behind a purple flame tied to the transformation mechanic in Black Myth: Wukong . However, you need to progress further into Chapter 1 to unlock the Gourd that allows you to transform into the Wight for a short time. This transformation gives you a powerful attack that can stagger any enemies and raise your base defense during intense fig
The Wandering Wight blocks a path in the very first area of the Black Wind Mountain region you explore after the game's prologue. As you start from the Outside the Forest Keeper's Shrine, you could run into the Wight as you venture deeper into the Forest of Wolves. A few basic enemies can be fought along the way to this boss, but try not to engage with too many foes so you can start the fight with full hea
You can also make yourself harder to hit by investing some Sparks in the skill tree . Guangzhi is very quick, and you'll be dodging around a lot, so acquiring the skill that makes your dodges use less stamina , or increasing your stamina in general, is a good idea. Improving your health is always helpful too.
- 이전글Get Manageable Steps to Repair Amazon Fire Stick Black Screen - Shoffysmile’s Diary 25.09.12
- 다음글What You Should Be Focusing On Improving Locksmith Near Me For Car 25.09.12
