5 Killer Quora Answers To Item Upgrading > 자유게시판
작성자 Raquel
댓글 0건 조회 21회 작성일 25-04-05 18:32
Path of Exile Item Upgrading
In Path of Exile, item upgrading is among the Best item upgrade ways to improve your equipment without relying on large-ticket drops or trade. This article will teach you how to upgrade your gear.
Upgrades to equipment provide a bonus on the item's stats. This bonus scales based on the rarity and level of the upgrade component.
Components
Upgrade components are the things that make your weapons and armor better. You can locate them through destroying enemies, buying them from karma vendors, or finding them in items-spheres. You can also get them from equipment containing the components or through high-end salvage kits like Black Lion Salvage Kit and Ascended Salvage Tool. Contrary to other products upgrades aren't destroyed when they are removed from an item.
Upgrade components are mostly used to upgrade an item however, they can also be used for other reasons. They can be used to boost the level or experience gained from upgrading existing equipment or weapons. They can be made for additional benefits. A glyph that has been crafted can increase the chance of upgrading its target while a boost upgrade increases the attack or defense attributes of weapons.
You can attach an upgrade template to an item by selecting it from the edition GUI. This will display the list of upgrade components that the item can be upgraded to. Alternatively, you can make use of the workbench to choose an upgrade template. In either case the item will be upgraded after enough upgrade components have been collected.
Each component has its own experience multiplier. This determines the amount of experience an item gains when upgraded using the component. Organic components, for example, have a higher multiplier of experience than mechanical components. It is recommended to upgrade the organic components first, until you reach the next rank in the weapon or equipment and then switch to the mechanical upgrades.
In addition to the experience multiplier, each item also has a maximum number of upgrades it can receive. The number of items that can be upgraded is determined by their upgradeable rank and the kind of upgrade they are able to receive. For instance, the most expensive possible weapon upgrade is a weapon of tier 10. However, the most commonly used weapon upgrades are an tier 6 weapon as well as an armor upgrade of tier 5.
Sets
A set is a collection of items that share the same bonus. Each item in the set can be upgraded at least once, and each upgrade boosts the amount of bonuses that are guaranteed. When you first upgrade an item or set piece will give it an increase of +1 to its primary stat. After subsequent upgrades, the primary stats will be boosted a bit more (for instance, +1 to 12+/13+/14+), and each time you upgrade the item it will have one of its additional stats is boosted randomly.
Upgrades can also boost the base damage of a weapon. This may be important for certain builds. However, weapons can't be upgraded to have a greater maximum defense roll than their normal base. Upgrading can be a good method to increase the value of certain sets and unique items, however it's important to remember that they're not necessarily superior to a high-level runeword in any build.
If you're upgrading an item that has a bonus, the item can be rerolled a single time and the guarantee will reset back to zero. Rerolling will cost the same amount of power dice as bringing an item up, but the upgraded item will come with various bonuses. Upgrades can be made by visiting the NPC [Armorthe ] Boboko in Central Flarine. To upgrade an item, you'll require a power die of each kind (Dice 4 or 6 drop from monsters 21+ and Giants; Dice 7 drops from bosses) and the appropriate amount of Minerals and Erons. These can be purchased with Gold at the crafting table, or in the Ultra Collection. The NPC will also provide a special reward for each completed tier of the upgrade process. This reward can be rerolled once, and the reroll will use the same materials used in the original item.
Rerolling
A player is able to roll any item they have acquired in the game if they have enough tokens. If an item is rerolled, it will be replaced with a level 1 version in another set. Reroll tokens can be purchased at the store for a small sum of in-game currency. They are not refundable. The new upgraded item will still come with the extra bonuses of the original one however, its stats will differ as well.
In addition to rerolling objects, players can also alter the identification of any item upgrades by interfacing with an upgrader NPC. This will change the identity from an armored weapon to a weapon, or vice versa, while retaining its base stats and required attributes. The change will be permanent and will affect all characters who own the gear.
Players can also boost the level of their item on any equipped equipment by obtaining upgrade components and communicating with the upgrader NPC of the item. The cost will differ based on the upgrade track, the item type, and the number of crests. In the case of weapons, each step up will add an additional five percent to the damage.
Upgrades can boost the power of an item, however they can also reduce the quality of an item. It is therefore important to keep both in check. Certain items might not be worth upgrading, while others will need to be upgraded in order to reach their potential. A player may want to upgrade the breakpoint armor by adding an interesting modification ( percent block chance or FHR) in order to see what else it can become.
The primary reason people play rerolls in Genshin Impact, or in any gacha-based game, is because they are trying to get a specific weapon or character that they aren't able to obtain. These items are time-consuming and costly to obtain, and the RNG doesn't always play nice. The only alternatives are to spend money or grind for a long time. Rerolling is a very popular option in Genshin Impact.
Leveling
When upgrading an item, you can level up the weapon or armor. However, this feature does absolutely nothing in the current game. I believe it was intended to to give some value to rare items, but since gear in general drops fairly quickly and is only upgraded one level up it is likely that you will replace the item before it becomes old enough. It's not worth it to level items that have gem sockets since the value of the gem will be greater than the increase in ilvl with the upgrade.
If you click on the upgrade option on an item, you'll be presented with a small window displaying the upgrade template for the item level upgrade and the cost of crest and Valorstone to increase the level of the item. The cost will differ between weapons and armor as well, with the former typically costing more than the latter. The upgrade template lists the stats that can be added to an upgraded item along with its current ilvl.
The crest and Valorstone costs are calculated by analyzing the item's current ilvl and the upgrade template. The ilvl will also be reduced by the upgrade template's reduction percentage of lvl. For example an upgrade of 8% will reduce the weapon's ilvl by 8 to 8percent.
The item will get upgrades to other stats like critical strike damage, PvE damage, and block, parry, and dodge rating in addition to the base level. These increases are dependent on the upgrade template.
In the upgrade template, you can determine the amount of damage or defense that the item will suffer when it is upgraded. This is listed below the cost as well as the upgrade percentages. All weapons and armor, except practice equipment, get these stats once they've been leveled up. The value of these additional stats will be determined by the market, with a perfectly rolled piece of armor or weapon able to command much higher trade values than non-upp'd versions. This is also true for other armor pieces such as circlets or Tiaras.
