How To Beat Guangzhi In Black Myth: Wukong > 자유게시판
작성자 Shellie
댓글 0건 조회 2회 작성일 25-09-10 02:54
cHJpdmF0ZS9sci9pbWFnZXMvd2Vic2l0ZS8yMDIyLTExL2ZsNTUwOTY5MzE3OC1pbWFnZS5qcGc.jpgMedicines are not to be confused with drinks, consumables, or your Healing Gourd used to recover health during fights. While those items could cure poison in Black Myth: Wukong or help you recover from other ailments, medicines provide stat boosts . There are two types of medicines - normal Medicine which gives you temporary stat increases, and Celestial Medicine which makes those improvements perman
His combos often change, making him one of the more unpredictable bosses , which adds an extra challenge to the boss fight. Sometimes, he'll do a double swing and a lunge, while at other times, this number changes and ends with a swing rather than a lunge. It is, therefore, important not to allow yourself to get caught, as if you do, it will be difficult to evade the attacks to fol
During and between many of these attacks, Whiteclad Noble rapidly moves around the arena , which can be a little overwhelming, given his speed. This can disorientate you if you don't watch carefully, allowing him to hit you from many different sides and ang
Heading left from the Wandering Wight's location will lead you to another Yaoguai Chief optional boss named Guangzhi. Defeat Guangzhi to gain a transformation , an ability that allows you to turn into the beaten boss for a limited time. While fighting in this alternate form, you don't take damage to your main health bar, but instead only have your transformation timer reduced as you get
Now that you can zip around the arena just as deftly as Guangzhi, and you're stocked with some appropriate medicines, we can finally start trying to take him down. Guangzhi's arena is relatively small in comparison to the quick moves he has, and you'll often find yourself back against the wall if you dodge around with no real purpose .
You can also make yourself harder to hit by investing some Sparks in the skill tree . Guangzhi is very quick, and you'll be dodging around a lot, so acquiring the skill that makes your dodges use less stamina , or increasing your stamina in general, is a good idea. Improving your health is always helpful too.
Try to explore many of the areas of the forest to see what items you can get before facing the Wandering Wight. Defeating the basic enemies here, who reset when you return to a Shrine, will help you earn Sparks to level up. Just open the "Self-Advance" tab when resting at a Shrine to improve your stats or make abilities stronger by spending Sparks you get from farming enemies close to where the Wight resi
The Wandering Wight also leaves behind a purple flame tied to the transformation mechanic in Black Myth: Wukong . However, you need to progress further into Chapter 1 to unlock the Gourd that allows you to transform into the Wight for a short time. This transformation gives you a powerful attack that can stagger any enemies and raise your base defense during intense fig
While many of the base settings in both presets are similar, the Performance preset cranks the quality down across several categories to allow for a smoother experience . The following table compares each graphical setting that's affected by the two pres
Xu Dog asks you to defeat the frog Lang-Li-Guhh-Baw , a boss who has swallowed his medicinal formulas. This enemy is almost a carbon copy of Baw-Li-Guhh-Lang, a similarly amphibian boss from Chapter 1 from the Bamboo Grove area. Unlike the Whiteclad Noble in Black Myth: Wukong or other humanoid bosses, the Lang-Li-Guhh-Baw has a bestial move set that may be easier to pred
Make sure to follow the pathway towards the back of the boss arena to interact with the Bell before returning to the marsh, where you can progress into the cave to continue chapter 1 in **Black Myth: Wukong
Guangzhi is one of these bosses, a wolfman who's quick on his feet and even quicker with his spear. His weapon is also doused in fire , making him pretty tricky to deal with so early in the game. We're here to help cool things down though, and you'll have Guangzhi down faster than you can say "good boy."
With that in mind, Guangzhi is much less threatening at a distance , and while he does have some moves that can hit hard if you fail to dodge through them, they're much easier to see coming. A lot of these attacks also leave Guangzhi wide open to a full light combo , which will stagger him and give you some respite.
There are a couple of things you can do before stepping into Guangzhi's arena to make things considerably easier for yourself. Firstly, if you head to the area's nearby shrine, you can purchase yourself some Body-Cooling Powder with some of your Will.
Black Myth: Wukong has a dizzying number of boss fights for you to tackle, with three in the game's first hour alone. With the lack of tools at your disposal, and the fact you're still getting used to your squishy monkey body, these bosses can pack a punch if you go in unprepared.
It's also worth keeping in mind that you have an extremely powerful tool in Immobilize . It's given to you right at the start of the SLG game beginner guide and will be your best friend throughout, so make sure to use it as often as you can against Guangzhi , preferably just after he's finished a long attacking combo. With all this in mind, you should have Guangzhi looking like a puppy pretty soon.
