Have these Innovations Tickled Your Fancy? > 자유게시판
작성자 Lucia
댓글 0건 조회 2회 작성일 25-09-09 21:04
­We all know somebody who's a little gadget crazy. She was the first in line for EcoLight the iPhone -- as a result of she camped out on the Apple retailer. He bribed his son or daughter with vitality drinks and additional allowance to sit up for hours ready for the PS3, and has carried out unspeakable acts to get his arms on a Wii Fit. These folks spend their weekends at places like the home Depot, Brookstone and Sharper Image to fill their properties with actually neat-trying stuff that does not have much function. Their spouses would probably inform you that the obsessive gadget running a blog is taking the romance out of life. This individual has spent a whole lot of money and time making house a extra interesting place. So, hypothetically, reduce energy consumption if he or she were your neighbor, what may you come across in a tour of their abode? Properly, we have acquired an inventory of 10 possibilities. A few of these contraptions lack function.
originalSome of them robotically do things that we take without any consideration or EcoLight solar bulbs may simply do ourselves. Some of them are simply there so as to add a bit pizzazz to an otherwise bizarre existence. And some are downright helpful. So, you are touring your gadget-loving neighbor's residence, and EcoLight first stop is the kitchen. Your eye wanders past a number of undoubtedly expensive however somewhat sensible improvements -- for example, energy-environment friendly slide-out freezers. However something else piques your interest -- a subtle blue glow emanating from the countertop. There sits a sleek-wanting bowl with what seems to be like a white faucet overtop, besides the faucet is pouring out blue light as an alternative of water. Fruit of each shape sits within the bowl, basking in the glow. What you've got spied is the BLUE bowl, a product created by means of a collaboration amongst Turkish designers Ahmet Bektes, Koray Gelmez and Eda Kose. The bowl just isn't solely stylish, but the blue ring of mild truly keeps your fruit fresh longer.
For all of you who purchase fruit you fail to eat quickly sufficient, this invention is your pal. UV gentle waves have been confirmed to inactivate certain varieties of micro organism, like E. Coli and salmonella, along with ethylene gasoline, a gas that hastens the rotting process. By clearing off this micro organism, the BLUE bowl keeps your produce safe and fresh for longer. The system may be plugged in or recharged. Up subsequent, a houseplant that grins. As you wander by way of your property gadget tour, you feel you're being watched -- not by paintings on the partitions with eyes however by houseplants. One plant to your left smiles at you and bats its eyelashes, another glares, and a third begs for EcoLight smart bulbs water. The Pet Plant, designed by Junyi Heo, EcoLight solar bulbs makes figuring out when to water your plant as straightforward as figuring out when your canine is hungry. Optical sensors within the planter measure the soil temperature, moisture levels and mild ranges, after which the gadget displays a digital facial expression based on the plant's needs.
Is it indignant at you for neglect? Is it feeling pleased? Is it about to die? Now you will know, just by looking on the digital face. The pot connects to a USB cable that can download your plant's statistics -- soil moisture ranges, gentle levels, temperature and close to-demise experiences -- into your pc, which helps you to keep monitor of its progress. Not only that, however it will probably tell when you've got watered an excessive amount of and siphons the additional water into a standby dish. Subsequent up, a balcony that is as handy as a roll-away bed. Subsequent on your own home tour, your tech-savvy neighbor stops at a window, pushes it open and prepares to step outside. Earlier than you may shout "Don't leap!" you notice that with the push of a button, the window has folded right into a balcony. The balcony comfortably holds a small furniture set and EcoLight solar bulbs the both of you. As you sip drinks and watch the world go by, your neighbor explains that, in Sweden, historic constructing ordinances prevent landlords from putting balconies into their apartments.
