Best Divinity: Original Sin 2 Mods > 자유게시판
작성자 Lorna Winkler
댓글 0건 조회 2회 작성일 25-09-09 19:48
Characters gain talent points at level 1, 3, 8, 13, 18, 23, 28, and 33. Divinity Original Sin 2 is programmed for more points at higher levels, but due to the limited amount of experience points, it is likely most parties will complete the game at level 22
Divinity: Original Sin 2 is a game that is pretty loot-driven, with inventory management being a downright pain to deal with at times. Still, it's all worth it when players find a particularly useful piece of loot that helps them deal with enemies that could usually give them a tough time otherw
Worm Tremor - Sends worms out of the ground in an area to attach to every character without magical armor. Deals 50% earth damage to characters initially and 30% poison damage for the two subsequent rounds where they are entang
For base skills, Tentacle Lash will be your primary damage attack that can also prevent enemies from using their own abilities. Bullhorns are great for movement more than actual damage. Last, consider either Battle Stomp or Bouncing Shield from Warfare depending on your weaponry. You will also have access to All In when using a two-handed weapon, Shields Up with a shield, Flurry with an off-hand weapon, and Sucker Punch when using a single one-handed weapon. Opportunist is good to stop enemy movement, but also consider Hothead for higher damage out
Specializing as a Hydrosophist will give the Conjurer the Water Infusion and Ice Infusion Summoner abilities. The Hydrosophist uses the power of water and ice to deal damage and heal allies. This specialization would make the Conjurer a full support and healing character. The best Hydrosophist abilities to take for the Conjurer are Rain, Restoration, Cryotherapy, Healing Tears, Cryogenic Stasis, Mass Cleanse Wounds, Vampiric Hunger Aura, Deep Freeze, and Ice Brea
Corpse Explosion (1 Necromancer, 1 Pyrokinetic): detonate a corpse to deal high Physical damage. You won’t be as powerful as an Intelligence-based mage, but your Warfare investment will make this reasonably str
Any of these lines would make a great secondary skill line option depending on the playstyle that is wanted. Depending on the race of the character may also change the decision. If the Conjurer wants a third skill line, choosing another element may be the best option. Other Conjurer combinations could be Hydrosophist and Necromancy for a support role, Geomancy and Warfare for a tanking role, Pyrokinetic and Huntsman for a ranged role, or Aerotheurge and Scoundrel for a stealthy r
Divinity: Original Sin 2 allows for a wide range of builds that are all viable for all but the hardest content. Well, everything except for Necromancy. This school of magic is pitifully weak when compared to other archety
Whenever someone uses a Source Skill, you have a 1/5 chance of gaining Source; it requires being level 6. This talent is best used once your party can hold three Source Points, likely near the end of Reaper’s Coast around level 15 or 16. The party should have some kind of synergy when using Source Skills of the same damage type, like Arrow Storm and Grasp of the Starved, which are both physical attacks. Greedy Soul is less useful for reactionary and healing Source powers you might not use as of
Thankfully, players can opt for the 8 AP mod instead, increasing this limit quite a bit and allowing them to be less stingy about using up their AP during every turn. While some people may argue that the Slg Game Resource Management itself has an option for the same, enabling that form of 8 AP leads to achievements being disabled, which may not be ideal for some players who want to enjoy the best of both wor
Melee attacks deal bonus fire damage to burning enemies, poison to poisoned targets, and physical damage to bleeding targets. This talent is only helpful if someone already has the Torturer talent, as it allows them to bypass enemy armor to apply burning, poisoned, or bleed. In that case, it can be good for melee characters that are backed by Necromancy, Pyrokinetic, or Geomancer. Another aspect to remember is that Intelligence-based fighters can wield staff weapons to deal fire and poison damage in me
Finally, specializing in Pyrokinetics will give the Conjurer the Fire Infusion and Necrofire Infusion Summoning abilities. The Pyrokinetic uses fire and necrofire to damage their enemies. Taking this skill line will make the Conjurer more of an active fighter who is ranged. The best Pyrokinetic abilities to use for the Conjurer are Ignition, Peace of Mind, Bleed Fire, Corpse Explosion, Sabotage, Throw Explosive Trap, Sparkswing, Summon Fire Slug, and Meteor Sho
The base Battlemage during character creation (or if you recruit a companion) is 1 Strength, 1 Intelligence, 1 Constitution, 1 Warfare, 1 Aerotheurge, 1 Persuasion; Battering Ram, Shocking Touch, Blinding Radiance skills and the Comeback Kid Talent. While Air damage is serviceable, you can cause much more destruction by beginning with Fire damage and adding in other elements la
