Divinity: Original Sin 2 - Metamorph Class Guide (Tips & Tricks)
Apotheosis (5 Polymorph): All other Source skills cost 0 Source for three turns. If you have the AP reserves to use other Source skills, this can be very SLG game Building guide breaking. This can allow you to instantly use other skills like Skin Graft, Thick of the Fight, Dome of Protection (Custom Character), Demonic Stare (Red Prince), or Time W
The starting class Metamorph showcases the Polymorph line of magic. While Larian Studios provides a simple first-level build, characters can be improved by adjusting start parameters and investing in an array of combat ski
Worm Tremor - Sends worms out of the ground in an area to attach to every character without magical armor. Deals 50% earth damage to characters initially and 30% poison damage for the two subsequent rounds where they are entang
Medusa Head (2 Polymorph): Deals Earth damage around you and will cause Petrify on enemies with no Magical armor. Nice if other party members deal Magic damage, but might not be as useful if the team focuses on Physical damage. Also cannot be used with Bullho
For your first three skills consider Battle Stomp for area damage (it will deal elemental damage if you wield a staff, but will not Knock Down if the target has Physical armor). Take two of the three: Ignition to light enemies aflame, Searing Daggers to create Fire surfaces, and Haste to improve your AP regeneration. You will also have All In if you wield a two-handed weapon, or Staff of Magus ranged attack with an elemental staff. For the first Talent, Torturer will let you inflict Burn status even if enemies have Magical armor, or Opportunist to get free attacks on moving targ
As a Battlemage, you will be dealing with some mix between Physical and Magic damage. It would be better to just prioritize one: either heavily invest in two-handed Strength weapons and Warfare or Intelligence staves and Pyrokinetic . Either way, being on the frontlines means that it would be good to wear Strength-based armor. Consider starting with 1 Strength (mostly for future gear requirements), 2 Intelligence, 1 Warfare, 1 Pyrokinetic, and Civil Ability matching your character (Barter for Ifan, Loremaster for Sebille, et
The default Metamorph build is 2 Strength, 2 Finesse, 1 Two-Handed, 1 Polymorph, 1 Persuasion; Chicken Claw, Tentacle Lash, Bullhorns skills and Opportunist Talent. This is what recruited companions will have, but your main character can tweak this to be a bit better. You can also retrain your allies once getting to a Magic Mirror for respec
Conjurer, one of the many pre-made classes in **Divinity: Original Sin II , ** is a summoning-based class . Being one of only a couple of classes based in only one skill line, the Conjurer can be built in several different ways. Set-up to be more of a supporting class, here is the best way to build a Conju
Specializing in Aerotheurgy will give access to Electric Infusion, Cursed Electric Infusion in the Summoning skill line. Aerotheurgy uses the power of air and storms to build up the player. This skill line works well for a stealthy supporting role. To the best effect with Summoning, abilities like Favorable Winds, Blinding Radiance, Erratic Wisp, Blessed Smoke Cloud, Teleportation, Nether Swap, Apportation, and Chain Lightn
**Divinity Original Sin 2 ** has received constant updates over the past three years. This started small with updates to crafting , and over time Larian Studios rolled out brand new free quests and high-level equipment . Among one of these "Gift Bag" updates, was Sourceror Secrets that introduced quality of life changes and even new abilities to help build characte
Spread Your Wings (2 Polymorph): Allows you to fly nearby points. Keep in mind that if you try to fly over death fog (and aren’t Undead) you might still wind up dying. Good for movement, but cannot use Spider Legs at the same t
For Talents, go for The Pawn to increase movement, Savage Sortilege for criticals (most of Polymorph are actually spells), and Living Armor for extra protection versus Magic damage. If you are using Gift Bags, consider Indomitable and Gladiator for more defenses. Bigger and Better and All Skilled Up are great for when you have spare Talent poi
For new Talents aim for Executioner to regain AP, Hothead for critical hit rate, and Elemental Affinity to reduce AP costs; if you are using more spells than pure melee also get Savage Sortilege to gain magic criticals. With Gift Bags, Sadist will deal Fire damage on Burning targ
For base skills, Tentacle Lash will be your primary damage attack that can also prevent enemies from using their own abilities. Bullhorns are great for movement more than actual damage. Last, consider either Battle Stomp or Bouncing Shield from Warfare depending on your weaponry. You will also have access to All In when using a two-handed weapon, Shields Up with a shield, Flurry with an off-hand weapon, and Sucker Punch when using a single one-handed weapon. Opportunist is good to stop enemy movement, but also consider Hothead for higher damage out
- 이전글What's The Job Market For Aluminium Windows Doors Professionals Like? 25.09.09
- 다음글Five Killer Quora Answers On Cheap Locksmith For Car Keys Near Me 25.09.09
