How To Beat Guangzhi In Black Myth: Wukong
As you can see in the above video by YouTube creator Esoterickk , the AoE attacks from the Wandering Wight can be chained from any of its basic physical strikes. This makes the boss hard to predict, so stay patient and wait until the boss is recovering at the end of its attack chains. As long as you don't waste your Immobilize and heavy attack chances, you should be able to take this boss down eventua
Not only does this increase your resistance to fire , but it will also remove the fire debuff that Guangzhi's weapon is excellent at applying. They don't cost that much Will to purchase, but just be aware that you'll only be able to buy six of them .
Heading left from the Wandering Wight's location will lead you to another Yaoguai Chief optional boss named Guangzhi. Defeat Guangzhi to gain a transformation , an ability that allows you to turn into the beaten boss for a limited time. While fighting in this alternate form, you don't take damage to your main health bar, but instead only have your transformation timer reduced as you get
Without a plan, the Wandering Wight will be nearly impossible to beat with your base stats, skills, and equipment. You need to at least craft some gear using Sparks gathered from enemies to give yourself higher defenses while fighting this boss. There are other secrets in the extensive map areas of Black Myth: Wukong that you can also investigate to gain advantages against the Wi
A degree of preference factors into every player's choice, but for the most part, **Performance mode is the best option for Black Myth: Wukong ** . That's due to the simple fact that it is an action RPG, and takes inspiration from Soulslike games . Players will have to pay careful attention to enemy movement, ensuring that they get out of the way in a timely manner. This is much easier at the higher, more consistent frame rates provided by Performance mode. On this setting, stuttering is a lot less likely, which means players will less frequently miss cues for incoming attacks. The combat will also feel more fluid and satisfying, and the overall gameplay will benefit from
Try to explore many of the areas of the forest to see what items you can get before facing the Wandering Wight. Defeating the basic enemies here, who reset when you return to a Shrine, will help you earn Sparks to level up. Just open the "Self-Advance" tab when resting at a Shrine to improve your stats or make abilities stronger by spending Sparks you get from farming enemies close to where the Wight resi
Medicines are not to be confused with drinks, consumables, or your Healing Gourd used to recover health during fights. While those items could cure poison in Black Myth: Wukong or help you recover from other ailments, medicines provide stat boosts . There are two types of medicines - normal Medicine which gives you temporary stat increases, and Celestial Medicine which makes those improvements perman
This acts as a buffer to avoid taking damage from the Wandering Wight, while also giving you a chance to deal higher damage as Guangzhi. It's also a good idea to have the spell Immobilize unlocked before fighting the Wight. This spell may consume a lot of mana at the early stages of Black Myth: Wukong , but it gives you a chance to freeze the Wight for a short time during the bat
Guangzhi is one of these bosses, a wolfman who's quick on his feet and even quicker with his spear. His weapon is also doused in fire , making him pretty tricky to deal with so early in the SLG game Walkthrough. We're here to help cool things down though, and you'll have Guangzhi down faster than you can say "good boy."
Similar to Spirits, players can also use Transformations, although there are fewer options within this category of Black Myth: Wukong . In Chapter 1, players will only gain one Transformation and another in Chapter 2. Red Tides transforms you into a Wolf Guai , allowing you to inflict Scorch Bane on the enemy with every att
It's also worth keeping in mind that you have an extremely powerful tool in Immobilize . It's given to you right at the start of the game and will be your best friend throughout, so make sure to use it as often as you can against Guangzhi , preferably just after he's finished a long attacking combo. With all this in mind, you should have Guangzhi looking like a puppy pretty soon.
Guangzhi has quite a lot of moves at close range and at distance, with most of his distant attacks designed to narrow the gap between both of you with speed . His close-range attacks are pretty tricky to deal with, and include multiple swings for you to dodge.
The Wandering Wight also leaves behind a purple flame tied to the transformation mechanic in Black Myth: Wukong . However, you need to progress further into Chapter 1 to unlock the Gourd that allows you to transform into the Wight for a short time. This transformation gives you a powerful attack that can stagger any enemies and raise your base defense during intense fig
- 이전글What Your Customers Really Think About Your Best Online Poker Nwt? 25.09.09
- 다음글You'll Never Be Able To Figure Out This Latest Headphones's Tricks 25.09.09
