Divinity: Original Sin 2 - Conjurer Class Guide (Tips & Tricks) > 자유게시판
작성자 Wayne
댓글 0건 조회 2회 작성일 25-09-09 04:09
Spider Legs (2 Polymorph): Fire off webs that prevent enemies from moving and grants you Haste if you step in them. The webs can also spread fire already laid out by yourself or an ally. A great control ability, but cannot be used at the same time as Spread Your Wi
Any of these lines would make a great secondary skill line option depending on the playstyle that is wanted. Depending on the race of the character may also change the decision. If the Conjurer wants a third skill line, choosing another element may be the best option. Other Conjurer combinations could be Hydrosophist and Necromancy for a support role, Geomancy and Warfare for a tanking role, Pyrokinetic and Huntsman for a ranged role, or Aerotheurge and Scoundrel for a stealthy r
Epic Encounters: Origins is arguably the most ambitious, comprehensive overhaul mod one can find for Divinity: Original Sin 2 . The number of changes here is staggering, ranging from balance tweaks to the addition of new progression systems. Covering all of them would warrant an article on its
Thankfully, players can opt for the 8 AP mod instead, increasing this limit quite a bit and allowing them to be less stingy about using up their AP during every turn. While some people may argue that the SLG Game Maps itself has an option for the same, enabling that form of 8 AP leads to achievements being disabled, which may not be ideal for some players who want to enjoy the best of both wor
Xhaxh’s Staff of Parasitic Decay (Poison Staff): a possible reward for slaying Xhaxh during the quest A Taste of Freedom , started inside Mordus’ basement in Reaper’s Coast. Boosts Memory and Necroman
**Divinity Original Sin 2 ** has received constant updates over the past three years. This started small with updates to crafting , and over time Larian Studios rolled out brand new free quests and high-level equipment . Among one of these "Gift Bag" updates, was Sourceror Secrets that introduced quality of life changes and even new abilities to help build characte
The base Battlemage during character creation (or if you recruit a companion) is 1 Strength, 1 Intelligence, 1 Constitution, 1 Warfare, 1 Aerotheurge, 1 Persuasion; Battering Ram, Shocking Touch, Blinding Radiance skills and the Comeback Kid Talent. While Air damage is serviceable, you can cause much more destruction by beginning with Fire damage and adding in other elements la
Kvyn’s Hands (Gloves): possible loot inside the Doctor’s basement. However, getting these may lockout Lord Ruaney unique items. Has a Finesse and Thievery penalty, but a Strength boost and gives innate Tentacle L
Melee attacks deal bonus fire damage to burning enemies, poison to poisoned targets, and physical damage to bleeding targets. This talent is only helpful if someone already has the Torturer talent, as it allows them to bypass enemy armor to apply burning, poisoned, or bleed. In that case, it can be good for melee characters that are backed by Necromancy, Pyrokinetic, or Geomancer. Another aspect to remember is that Intelligence-based fighters can wield staff weapons to deal fire and poison damage in me
Mass Cleanse Wounds - Heal the player character and allies within a radius, creating puddles of water beneath them. Also removes Necrofire, Burning, Diseased, Decaying Touch, Poisoned, Bleeding, Suffocation, and Acid status effe
Circle of Suns (Ring): decide to kill Sadha inside the Arx Lizard Consulate (this may cause Red Prince to go hostile if he isn’t a main character). Gives a nice boost to Pyrokinetic and the Flaming Skin skill for f
Still, it can be somewhat immersion-breaking that these merchants have none of the items they were peddling to players before their death. This changes with the advent of the Full Loot mod, which ensures that merchants who have been struck down die with all their wares in their possession, allowing players to loot their bodies and obtain every single item without too much of a f
As noted before, Strength should be your primary attribute. Every few levels defer a bit to Memory for more skill slots, Wits to improve crit rate and initiative, or Constitution to meet shield requirements. Note that each point in Polymorph will also give an extra attribute point to spend. Warfare will increase your raw Physical attacks. You should also grab whatever combat abilities to meet skill requirements, like Scoundrel and Necroman
Divinity: Original Sin 2 allows for a wide range of builds that are all viable for all but the hardest content. Well, everything except for Necromancy. This school of magic is pitifully weak when compared to other archety
The default Metamorph build is 2 Strength, 2 Finesse, 1 Two-Handed, 1 Polymorph, 1 Persuasion; Chicken Claw, Tentacle Lash, Bullhorns skills and Opportunist Talent. This is what recruited companions will have, but your main character can tweak this to be a bit better. You can also retrain your allies once getting to a Magic Mirror for respec
