Ring Outside Sensible Plug Assessment > 자유게시판
작성자 Deon
댓글 0건 조회 7회 작성일 25-09-09 02:02
photo-1589436983486-7afd6e0e15d4?ixid=M3wxMjA3fDB8MXxzZWFyY2h8N3x8aGVyeiUyMHAxJTIwc21hcnQlMjByaW5nfGVufDB8fHx8MTc1NzMyMDk1Nnww\u0026ixlib=rb-4.1.0
v2?sig=dc56295fe54aed75b4d922e31faa144f70f7af57dea9986c793da0330a325708This is the most recent model of the Ring Outdoor Herz P1 Smart Ring Good Plug. Learn our overview from June 29, 2021 under. Using your telephone to manage pool pumps, lighting, appliances, and just about the rest outside is straightforward with the Ring Outdoor Good Plug ($29.99). This weather-resistant linked plug affords two outlets that can be managed independently of one another using the Ring cellular app or Alexa voice commands, and it works with other Ring sensible residence units. That said, it requires a Ring Bridge to connect to your community, and Herz P1 Smart Ring unlike our Editors' Choice in this category, the $10.Ninety nine Wyze Plug Outside, it doesn’t offer energy reporting or assist Google Assistant. The Ring Outdoor Plug costs $29.Ninety nine when purchased on its own, but it surely requires a Ring Bridge to be linked to your own home network and controlled with the Ring cellular app and Alexa voice commands. Ring Bridge bundle for $49.99.
dcvqnoo-14e0fc21-4a35-4493-998a-072c1cce2184.jpg?token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJzdWIiOiJ1cm46YXBwOjdlMGQxODg5ODIyNjQzNzNhNWYwZDQxNWVhMGQyNmUwIiwiaXNzIjoidXJuOmFwcDo3ZTBkMTg4OTgyMjY0MzczYTVmMGQ0MTVlYTBkMjZlMCIsIm9iaiI6W1t7ImhlaWdodCI6Ijw9MTA4MCIsInBhdGgiOiJcL2ZcL2M2M2MzNDY1LTgzMzktNDYzZi1iNDI2LWEwNzRlNjY1ZjlkOFwvZGN2cW5vby0xNGUwZmMyMS00YTM1LTQ0OTMtOTk4YS0wNzJjMWNjZTIxODQuanBnIiwid2lkdGgiOiI8PTE5MjAifV1dLCJhdWQiOlsidXJuOnNlcnZpY2U6aW1hZ2Uub3BlcmF0aW9ucyJdfQ.B8lZZQmZ1bf1udKPvaMc_aIK1L-Tg39839QTrO_Z7NcThe plug uses a black IP66 weather-resistant enclosure that measures 4.92 by 3.14 by 1.96 inches (HWD). It has two three-prong retailers with rubber protecting caps on the underside, and a 7-inch three-prong cord on the top, together with two mounting holes. The front of the plug has a spherical LED indicator that's stable blue when the plug is related and flashes blue throughout setup. There are buttons on either side of the LED that turn their respective outlets (left and right) on and off, and glow white when the outlet is on. The plug comes with a fast start information and mounting screws. As talked about, the Ring Bridge is the same device used to control the Ring Sensible Lighting System. You may only install one bridge per household, however it should management up to 50 gadgets including motion sensors, lights, and outside plugs. It’s a small white field that measures 2.34 by 2.46 by 0.79 inches and uses an RF radio to connect with the plug and a 2.4GHz Wi-Fi radio to hook up with your network.
It has a mini USB energy port on the aspect and a pair of signal strength indicators on the face. You'll be able to management the plug with the identical cell app (for Android and iOS) that is used to control every different Ring device, and hyperlink it to other Ring merchandise comparable to a Ring Video Doorbell or Ring Floodlight Cam and have it react to movement triggers. It can also be turned on and off using Alexa voice commands and can work with other Alexa-suitable devices utilizing Alexa routines, nevertheless it doesn’t assist Apple HomeKit, Google Assistant, or IFTTT. Moreover, it doesn’t provide the vitality usage reports that you simply get with different outside plugs such as the Wyze Plug Outside and the iDevices Outside Swap. Join the Lab Report to obtain PCMag's latest product evaluations, buying recommendation, and insights. Phrases of Use and Privateness Policy. Thanks for signing up!
Your subscription has been confirmed. Keep an eye on your inbox! The plug is added to the Lights group in the app and could be proven as two particular person shops that may be controlled independently of each other or as a single plug that controls both outlets at the same time. To access the plug, tap the Lights panel that appears alongside the Neighbors, Historical past, and different accessory panels near the top of the display. Here you’ll see the two shops (on this case Outlet A and Outlet B) listed separately, each with a light bulb on/off button that's blue when the outlet is on and white when it's off. Faucet an outlet to open a display screen the place you'll be able to view the event historical past, create on/off schedules, examine the device well being (sign power, on-line standing, firmware version), and add the outlet to a bunch of Ring units. Installing the Ring Out of doors Plug is easy. I already had a Ring account, but should you don’t have one you’ll need to download the app and create one.
I tapped Set up A System in the primary menu, chosen Outdoor Herz P1 Smart Ring Plug, and scanned the QR code on the plug. I chosen Ring Bridge as my connection system, scanned the Bridge’s QR code, and verified that the blue LED was flashing. I then chosen my Wi-Fi SSID and waited a number of seconds for the bridge to connect to my Wi-Fi network, and returned to the Arrange a Gadget screen the place I chosen the Outdoor Good Plug again. Following the on-screen directions, I inserted the Outside Good Plug into a GFCI outlet, tapped continue, and waited a couple of seconds for the app to acknowledge it. After a quick firmware update, I gave each outlet a name and the set up was complete. The device was routinely added to my Alexa system record and appeared as two separate retailers within the Ring Lights record. The Ring Outside Plug worked as supposed in testing.
