Honkai: Star Rail - Hidden Achievements In Amphoreus > 자유게시판
작성자 Kennith Warfe
댓글 0건 조회 2회 작성일 25-09-08 18:18
27. At the same level, walk to the middle of the room for a stone control platform to control the Hand of Zagreus . Find 3 Coins of Whimsy to unlock a hidden treasure chest. At the same time, use the mechanical hand to punch a breakable box in the center of the lowest level and pick up a triangle stone before putting it down on the left scale. Lastly, place the Hand of Zagreus as a bridge on the third floor before disengag
An open bath can be seen south of Civilian Bathhouse and there is an activity that allows players to get the Memory Crystal Shard in Honkai: Star Rail for free. Go on top of the elevated stage and there will be an option to listen to the water lyre. After the first try, Trailblazers will get one crystal sh
A unique drink called Ambrosia can be obtained from Bacchus in the Court of Season for free. Random incidents will occur after players drink it and select the dialogue option provided by the game. Drink Ambrosia for the first time and players will get a crystal shard. If Trailblazers managed to trigger all special intoxication incidents, they can unlock many achievements, such as 'We Sit on the Ground,' 'The Bro Sleeping On the Top Bunk​​​​​​,' and 'Moonlight in a Bott
This is a pretty easy hidden achievement to get, as all you need to do is listen in on people’s conversations in Amphoreus. NPCs whose names are tagged in white are those whose conversations can be listened to. This is the achievement you’ll get the first time you hear t
This achievement can be obtained from the Golden Scapegoat mini-game, and you can only get it if you fall into the thorns beneath you . Simply find any Golden Scapegoat mini-game and jump off the edge of the platform to trigger
Go to the bottom floor, cross the illuminated bridge, and reach the center of the room to purify the black tide . Afterward, go upstairs again to control the Miracle Orb and make the light shine on the right bri
You’ll need to head straight down the corridor to your right to the location given and find a nymph bug located on the floor . Head up the stairs towards the Golden Scapegoat puzzle and then walk across the bridge. Once the bridge falls, it’ll hit the nymph bug , and you’ll receive the achievem
When memosprite's turn starts, the wearer and the memosprite each gain 1 stack of "Commemoration." Each stack increases DMG dealt by 12% , stacking up to 4 time(s). "Commemoration" is removed from the wearer and the memosprite when the memosprite disappe
The hidden achievements available in Amphoreus are rather out-of-the-box and some of the most random in the game. While there are achievements that can be obtained through quests, these are more exploration-based. Here's a rundown on all the hidden achievements in Amphoreus and what needs to be done to unlock t
Notably, Victory In a Blink is also the only entirely F2P Remembrance light cone as of version 3.0, which can be acquired without relying on gacha pulls. However, unlike Ice Trailblazer , who benefits significantly from this light cone, Aglaea has better 4-star options that provide more relevant buffs for her damage output. Thus, while viable as a placeholder, players should consider switching to superior alternatives when availa
That being said, since Garmentmaker attacks frequently, reaching the max stacks should not be a major issue in most encounters. While Reminiscence is far from ideal compared to higher rarity light cones, it can still be a passable choice for those who lack access to better opti
14 through 16. Next, warp to Archive of Prophecies Space Anchor and turn around for a Prophecy Tablet puzzle after arrival. This puzzle will unlock a gate in the middle of the room and you can get the next two treasure chests and a Golden Scapegoat puz
The bundle itself includes two different styles of Anime game Beginner guide, with the first being a 3D Dungeon-Crawler, and the other two being Top-Down RPGs (both having turn-based combat systems). While these three classic titles belong to the same broader universe, they all follow different storylines and characters, so each experience offers something unique. Perhaps the best part about Shining Force Classics is that the developers have kept faithful to the originals with only minor improvements added — like a better save system, leaderboards, and controller supp
While Victory In a Blink's second effect cannot be utilized when equipped on Aglaea—since Garmentmaker doesn’t target allies with abilities—it can still serve as a decent stat stick thanks to its Crit DMG boost. This makes it a passable option for players lacking stronger alternati
Next, head to any area and find a Hand of Zagreus . You only need to interact with the mechanism and then use the Hand of Zagreus to collect a coin. You can break some obstacles to do this and then fly into the coin to grab it. You’ll receive the achievement immediately af
You need to head to a checkpoint that hails the Dromas. There are two main ones in ‘Eternal Holy City’ Okhema , but the easiest one to reach is right beside the Palace of Parting Space Anchor . After teleporting there, simply look to your left to find the shack with a bell . Then, ring the bell 5 times . On the fifth time, you’ll get the achievem
