Selecting the Perfect Power-Saving Lightbulbs > 자유게시판
작성자 Nicholas
댓글 0건 조회 9회 작성일 25-09-07 11:58
They've had a good long run, energy-saving LED bulbs 134 years, however come January most screw-in incandescent lightbulbs may have been phased out as a result of they use too much power. There is not any must hoard bulbs. Our checks found that new LEDs and CFLs are mild-years forward of earlier variations. Commonplace 60- and 40-watt bulbs are the final to be phased out, although remaining stock may be bought; 75-watt bulbs light away in 2012 and 100-watt bulbs this year. Their replacement equivalents, compact fluorescent lightbulbs and mild-emitting diode bulbs, are bright, use 75 to 80 % much less vitality, and can prevent $60 to $125 dollars per bulb in power prices over their life, compared with a standard 60-watt incandescent. Because houses have about 50 lightbulbs, the savings will be vital. However so is the investment. LEDs are expensive, as much as $60 a bulb for some floodlights in our lightbulb Rankings. Even at that worth, an LED can save you about $170 over its lifetime compared with an identical incandescent.
originalElevated competitors is helping to decrease costs. Manufacturers instructed us that extra $10 LEDs are coming next year, and there are already several bulbs in our Rankings for $20 or much less. Beginning at $1.25 per bulb, CFLs are a budget-friendly alternative. They're nearly as vitality efficient as LEDs however take at least 30 seconds to reach full brightness, do not last as long, and long-life LED most aren't dimmable. Halogen bulbs, a kind of incandescent, stay an choice but will price you more than twice as a lot to power as LEDs and CFLs and do not last wherever near as lengthy. LED know-how is evolving quickly. The Philips L Prize Winner A19 energy-saving LED bulbs, $44, would have been our high 60-watt equal however was discontinued shortly after we completed our 3,000 hours of testing, though chances are you'll discover it in shops and online. The new Cree 60-watt equivalent, $13, instantly offered a bright, warm mild in our initial checks. We'll add it to the Rankings when testing is finished.
Such modifications have made buying a bulb more challenging. Use our skilled recommendation, plus tips we have obtained from other lighting pros, to find the proper bulb for every room, and save money and EcoLight dimmable vitality. Activity lighting is tricky within the bathroom. Cool gentle is often recommended, however it will probably distort colours when applying makeup. So you may have to decide on one characteristic over the opposite or consider halogen bulbs right here. Decorative incandescents, akin to some globe lights, aren't part of the section-out. Keep in mind that lights over the sink can forged unpleasant shadows on your face; lights on both facet of the mirror or medication cabinet are higher. Recessed lights designed for wet areas are positive over the shower. Buying tip. Extreme heat can shorten the life of LEDs and CFLs, so test our lightbulb Rankings for bulbs that can be used in totally enclosed fixtures. On/off cycling, common in bathrooms, will shorten a CFL's life.
Bulbs to consider. The Ikea Ledare, $14, and EcoSmart 6-inch downlight, $25, have the very best colour accuracy of all of the LEDs we have tested, though the Ikea is finest for EcoLight home lighting ceiling fixtures or fixtures where the bulb is facing downward as a result of it casts most of its gentle from the top of the bulb. The EcoSmart might be utilized in wet areas. Relaxation and romance are key. Dimmers and warm lighting can assist, so look for bulbs in the 2700 to 2900 Kelvin (Ok) range. You will see this famous in our Ratings and on the bulb bundle. Consider cooler lighting, which has a better Kelvin quantity, for studying lamps or fixtures. Position those increased than the bed to minimize shadows. Skip CFLs in lamps in children's rooms, the place rough-housing is extra likely to result in broken bulbs. CFLs launch small quantities of mercury when they break. Shopping tip. Scale back noticeable variations in the sunshine coloration in a room by choosing CFLs or LEDs inside a 200-diploma Kelvin vary of different bulbs within the room.
