Treatlife Good Wi-Fi Shade LED Bulb Evaluation > 자유게시판
작성자 Cory
댓글 0건 조회 2회 작성일 25-09-04 08:23
The costs of smart light energy-efficient bulbs have been coming down steadily, with many good white-solely options in the $10 vary. The Treatlife Smart Wi-Fi Shade Bulb is on the market on its own for $12.99, or EcoLight beneath $10 when purchased in a pack of two or 4, making it essentially the most inexpensive color bulb we’ve examined-not to say more reasonably priced than many of the white-solely bulbs on the market. It provides wealthy colors and adjustable whites, as well as support for Amazon Alexa and Google Assistant voice commands. It lacks help for IFTTT applets that allow it to be triggered by third-get together smart dwelling devices equivalent to cameras and motion sensors, and it doesn’t support Apple’s HomeKit dwelling automation platform, but you'll should spend around twice as much for a bulb that does. The Treatlife bulb is accessible on its own for $12.99, in a pack of two for $19.99 ($10 each), or in a pack of 4 for $35.99 ($9 every). It's an A19 shaped LED with an E26 base that will fit most commonplace lighting fixtures.
It measures 2.Three inches in diameter, energy-efficient bulbs is 4.5 inches lengthy, and puts out 810 lumens, which is roughly equivalent to 60 watts. The bulb is dimmable and may produce 16 million colours, and it has a wide tunable white temperature vary of 1,200K to 9,600K. It additionally has a constructed-in Wi-Fi radio, EcoLight brand which implies it doesn’t require a hub. You'll be able to management the bulb with the same Smart Life cellular app (for EcoLight bulbs Android and iOS) used to manage different Treatlife gadgets, akin to its Sensible Plug. You too can management it using Alexa and Google voice commands, however it doesn’t assist Apple’s HomeKit platform or work with IFTTT applets that permit it to work together with third-get together good devices. It also lacks the facility usage studies that you just get with the TP-Hyperlink Kasa Filament Smart Bulb KL50. The app opens to a My Household screen with panels for EcoLight home lighting all your installed Treatlife devices.
The bulb panel displays the name of the bulb and has buttons for Energy, Brightness, and Coloration Temperature. Tapping the Brightness button launches a slider for raising and decreasing the brightness degree, and tapping the Color EcoLight Temperature button opens a slider that permits you to alter white temperature ranges. Tapping the bulb icon opens a Dimmer screen the place you may select one of four white temperature presets, or use the white colour wheel to select a custom temperature. Swipe to the precise to open a Coloration screen with blue, inexperienced, orange, and pink presets, in addition to a shade wheel that permits you to create a customized light coloration. At the bottom of the screen are buttons for On/Off, Dimmer, Scene, Music, and Extra buttons. The Dimmer button takes you to the above-talked about Dimmer display, and the Scene button takes you to a screen where you'll be able to choose from preset mild settings together with Night (reddish-orange), Read (vivid white), Working (cool white), Leisure (heat white), Gentle (inexperienced), Colorful (changing greens, blues, yellows, and reds), Dazzling (changing pink, green, blue), and Gorgeous (fades from blue to yellow to inexperienced).
Faucet the Music button to have the app access your phone’s microphone and change the bulb’s coloration in time to any music that is being performed, and tap the Extra button to create on/off schedules and to use the countdown timer. Sign up for the Lab Report back to receive PCMag's latest product critiques, shopping for recommendation, and insights. Terms of Use and Privacy Policy. Thanks for signing up! Your subscription has been confirmed. Keep an eye fixed on your inbox! There are a few buttons at the underside edge of the My Family display screen. The Smart button opens a display the place you'll be able to create Tap-to-Run controls that allow you to do things like change colors or switch to a specific white temperature setting with the touch of a button. You can have these buttons appear at the highest of the My Family screen for fast and easy accessibility. You can even create automations to have the bulb react to weather situations and when your location changes, and you may have it turn off at sunrise and on at sunset, or react to different Treatlife devices.
