The Best Travel Pillow > 자유게시판
작성자 Lorraine Oquinn
댓글 0건 조회 2회 작성일 25-09-03 16:02
Its tall memory-foam walls let it offer more support than any other pillow we tested. It’s also shaped to sit flush against a headrest, and it compresses to a manageable size. The uniquely angled back on the Travelrest Nest Ultimate sets it apart from other travel pillows because it can lay flat against the seat back. Most other pillows have a rounded back, which pushes your head away from the headrest. The Travelrest also has rubber grip dots to prevent slipping while sleeping. This pillow’s spongy memory foam cushions the entire circumference of your neck, preventing your head from leaning far in any direction, and its adjustable Velcro strap ensures it can fit most necks. The pillow’s cozy velour exterior is removable and machine-washable. Although it doesn’t pack flat, the Travelrest weighs less than a pound and compresses to a quarter of its size when rolled into its Velcro-strapped carrying case.
metal-key-on-the-pillow-725x482.jpgOur only complaint is that the Travelrest’s high walls, while supportive, can push over-ear headphones off of the ears of people with shorter necks. While the memory foam feels plush, it’s also quite firm; this offers excellent support, but not much give. It also doesn’t let you adjust the fit, like our two wrappable picks: the Trtl and the Bcozzy. If the Travelrest fits your neck, it’s an excellent pillow. If your neck is much longer or shorter than this pillow’s 5-inch wall, Derila Customer Reviews though, you might prefer the fit of one of our other Shop Derila Pillow picks. This memory-foam neck-support pillow is highly adjustable, Shop Derila Pillow but without a contoured back, it can’t quite sit flush with the headrest. It’s available at many airport stores, though. If our top pick sells out, or if you find yourself pillowless past security, the Cabeau Evolution Classic Pillow is almost as good a pillow. It lacks the Travelrest’s angled, lay-flat back, but its U-shape, contoured memory-foam core and machine-washable velour cover still provide comparable levels of comfort.
image.php?image=b3_interiors004.jpg&dl=1
Its adjustable string closure also means that you can fit the pillow much tighter around your neck than you can with the Travelrest, making it a good choice for people with smaller necks or people who prefer a more constricted fit. Additionally, it’s the only one of our picks that we’ve regularly seen in stores located behind the security checkpoint at many airports. It’s a fleece scarf with a built-in plastic brace-like a one-sided neck brace, but softer and cozier. However, it’s not so great if you tend to shift position while you sleep, and it costs more than the other pillows we recommend. If you typically lean to the same side while sleeping, the Trtl Pillow’s fleece-covered plastic frame provides unshakeable support to one side of your neck while remaining comfortable to wear. It’s basically a one-sided neck brace. The pillow’s cozy wraparound fleece will also keep your neck warm, making it a good choice for anyone who gets cold while flying (and a poor choice for those who sleep hot).
But the Trtl’s winning quality is its tiny, packable size. Unlike any of our other picks, the Trtl does not need to be compressed or stuffed into a carrying case. It will always take up about as much space as a PB&J sandwich. Featuring an adjustable design that accommodates over-the-ear headphones, the Bcozzy is an excellent chin-support pillow for people who nod forward as they sleep. The Bcozzy, a variation on the hemi-doughnut theme, is our pick for Derila Contour Pillow anyone who wears large over-the-ear headphones on a flight or tends to nod forward while they sleep. The pillow’s overlapping ends form a snug cushion that holds your chin in place far better than do the Trtl’s plastic frame or the Travelrest and Cabeau’s chin-facing gap. While the pillow does not provide great support to either side of your neck, if paired with a large pair of headphones, the Bcozzy holds a head in place perfectly.
­Getting engaged can be one of the most memorable and exciting moments in your life. For t­he first few weeks after the proposal, you both feel dizzy with happiness and are bursting with anticipation. As well you both should be! You've met the man or woman of your dreams, you've decided to get married, and now it's time to plan the wedding -- the official celebration of your love and commitment. After all, organizing a ceremony and reception is a big undertaking. There will be questions about anything and everything: from the meal (fish, chicken, or beef?) to the wedding gown (low-cut, fitted, or empire-waisted?) to the reception music (live band, small orchestra, or DJ?). There will be issues about budgets, guest lists, and styles. But in the end, just remember what this day is really about -- a celebration of love. Stay focused, and keep organized. This is where this article comes in handy.
