The 10 Most Scariest Things About Treatment For ADD > 자유게시판
작성자 Earnestine Boll…
댓글 0건 조회 31회 작성일 25-04-05 15:16
treatment for add best online adhd treatment in adults [just click the following post] For ADHD
The most common treatments for adding are medication and psychosocial therapy (psychotherapy). The medications contain stimulants such as methylphenidate, amphetamine, and Atomoxetine. They may also be non-stimulants like clonidine or Guanfacine.
coe-2023.pngStimulant medication are not recommended for patients with active substance abuse problems but they are an option for those who are in stable recovery. Combination therapy with antidepressants, especially SSRIs, is a different option.
Stimulants
Stimulants boost the levels of dopamine and norepinephrine that are released between brain synapses. This improves concentration and reduces the intensity of impulses and hyperactivity. Most doctors that treat adhd in adults prescribe medication from the stimulant class to treat ADHD. They might prescribe methylphenidate (Concerta or Ritalin) or amphetamines. Both are similar medications. The type prescribed will depend on a individual's biochemistry and how well they respond to the medicine. It may take up to seven days for full effects of a medication to become evident. Improvements in concentration, improved memory, better sleep and less the tendency to be impulsive are all indications that the medication is working.
Medications in this class can cause side effects, such as decreased appetite and trouble sleeping, and may raise blood pressure and heart rate. People suffering from medical conditions, such as heart disease or high blood pressure should not use them. Stimulants have a high potential for abuse and are tightly controlled drugs. Only paediatricians, psychiatrists or neurologists, and in certain situations, general practitioners may prescribe them. You can find them in the form of tablets, pills, patches that go on the skin or in liquids.
Children and adolescents who are dependent on stimulants are often afflicted by weight loss and appetite problems. They may also experience disorders when the dosage is too high. If this happens, the doctor may reduce the dosage to avoid the drug from causing worsening of symptoms.
About 70-80 percent of adults and children with adhd diagnosis and treatment are treated with stimulant medication. The majority of children and adolescents report that their symptoms get better when treated. This is especially true for those who have parents, teachers, or caregivers who report improvement.
Early use of stimulants can reduce the risk of substance use disorders later in the course of. Wilens Katusic, Wilens colleagues81,82 and Biederman, et al83, found that stimulant therapy reduces the risk of substance use disorders during the adolescent years. However the protective effect diminishes as we enter early adulthood.
