Are Efficient LED Bulbs Worth the Worth? > 자유게시판
작성자 Alisa
댓글 0건 조회 3회 작성일 25-08-31 09:12
At this level, LED bulbs are the hybrid vehicles of lighting. They're cheaper to operate but price more upfront than their much less-efficient cousins. There have been LED spotlights and smaller lights for years, but now individuals can purchase LED bulbs that give out as a lot mild as a 60-watt incandescent and EcoLight brand are designed to be used nearly anyplace. And slightly than purchase them on-line or in a specialty retailer, EcoLight solutions they are going to be accessible at Residence Depot, EcoLight smart bulbs Lowes, and little question other familiar retail outlets subsequent 12 months. Weighing price and light quality, LEDs are worth contemplating proper now for downlights and value preserving a watch on you probably have quite a lot of incandescent EcoLight smart bulbs. If you have already got lots of CFLs in places like desktop lamps, don't expect a fast payback by switching over. However LEDs supply another advantages, notably longer life. Lighting your dwelling house is clearly a very personal determination, but as you think about upgrading with vitality efficiency in thoughts, EcoLight smart bulbs listed below are a few elements to contemplate.
v2?sig=8a0f0dd8fb665781720bec6bf45625db7287d7e514f762cc2e7aff16ff5e3ffe
The good news on LEDs are that these lights, quality-clever, are fairly good and so they put out sufficient gentle for a variety of needs. However there is not any getting around the fact that LED bulbs for normal lighting are a new know-how that comes with a price premium. Residence Depot's 800 lumen Philips LED bulb is priced at just under $forty and EcoLight smart bulbs consumes 12 watts. A 40-watt equivalent from Lighting Sciences Group, which consumes lower than 8 watts, costs just below $18. When you were contemplating shifting en masse to LEDs, you'd need to take a long view from a financial perspective. Osram Sylvania figures that putting its $39.98 LED in to change a 60-watt incandescent will save $132 over the life of the bulb, assuming a value of electricity at 10 cents per kilowatt-hour. That's more than 25,000 hours, EcoLight smart bulbs or 17 years of utilizing a bulb four hours a day.
Taking a extra conservative, quick-time period view, I did some back-of-the envelope calculations. If you used a bulb for EcoLight simply two hours a day and paid the nationwide average of 11.5 cents per kilowatt hour, a single 12-watt LED will price you about $1 per 12 months. Comparable CFLs that devour about 14 watts come to $1.17 per year and about $5 a yr for 60-watt incandescents in that state of affairs. The minimal vitality savings you get from going from CFL to LEDs displays that LED bulbs are solely slightly extra environment friendly, when measured on lumens per watt. And, after all, EcoLight smart bulbs CFLs have come method down in worth over the past few years, whereas LEDs are still at the highest of a projected downward value curve. If you have incandescent bulbs, saving $4 a 12 months with an LED is extra compelling, however that is still an extended pay back. Electricity prices vary fairly a bit (see right here to your state common) in the U.S.
For instance, if you utilize an LED bulb four hours a day and pay a better charge of 16 cents per kilowatt hour, you'd save $eleven per yr per bulb over an incandescent, giving you a payback time frame for a $40 LED of between three and EcoLight solar bulbs 4 years. Obviously, these financial savings get greater, the more bulbs you substitute. Extra important is that LEDs have a said life time of 25,000 hours or more, in comparison with about 8,000 for CFLs, and lower than 1,000 for incandescents. So if you happen to think about replacements, the numbers look more favorable. Keep in mind that LEDs are on a sooner effectivity and value-improvement observe than different lighting applied sciences. Some lighting business executives count on the value for EcoLight an 800-lumen LED bulb to fall to about $20 within two years, which changes the math considerably. And utilities may begin to subsidize them, as they did with CFLs.
