How to Read Satta King Charts Like a Pro: A Beginner’s Guide to Patter…
In this article, you'll learn what Satta charts are, how to read them correctly, and how to find the hidden clues that top players use to make informed decisions. Whether you're new to charts or looking to sharpen your skills, this guide will help turn raw data into real strategy.
What Is a Satta King Chart?
A Satta chart is a record of past winning numbers, usually organized by:
Market name (Desawar, Gali, Faridabad, etc.)
Date of result
Winning number (sometimes with time)
Example:
Date Desawar Gali Faridabad Ghaziabad
July 1 83 17 29 38
July 2 47 92 63 74
July 3 29 38 83 47
Players use this information to look for repeating numbers, mirror patterns, and cycle behaviors.
Why Are Charts Important?
Charts help you:
✅ Track hot and cold numbers
✅ Identify patterns (mirrors, endings, repeats)
✅ Follow cross-market trends
✅ Avoid blind guessing
✅ Build your own logic system
In short, charts turn you from a random guesser into a data-driven player.
Step-by-Step: How to Read Satta Charts
✅ Step 1: Study 7 to 15 Days of Results
Start by collecting a chart of the last 7–15 days. You can find these on most result websites or build one manually using a spreadsheet.
✅ Step 2: Look for Repeated Numbers
Some numbers show up more than once in a short period. These are called repeaters.
Example:
83 hits on July 1 in Desawar
83 hits again on July 3 in Faridabad
This tells you 83 is in active rotation. That increases its value in future guesses.
✅ Step 3: Identify Ending Digit Trends
Track which ending digits (last digit of the result) are appearing often.
If you see 83, 63, 93, and 13 — that’s a strong ending 3 trend.
Guessing numbers that end in 3 (like 33, 43, SattaKing.in 73) becomes a logical next step.
✅ Step 4: Spot Mirror Patterns
Mirrors are numbers that reverse or reflect each other, like:
29 and 92
38 and 83
47 and 74
If 92 hits today, 29 may follow soon in another market.
Mirrors often rotate between markets within 2–3 days.
✅ Step 5: Track Market Influence
Some markets affect each other’s outcomes.
Day Desawar Gali
Mon 83 —
Tue 29 83
Wed 47 29
This shows a Desawar → Gali influence. Gali repeats Desawar numbers a day later.
Use this to predict the Gali number from Desawar’s recent result.
How to Build a Chart Tracker
If you're serious about chart work, maintain a personal log with these columns:
Date Market Result Ending Mirror Repeat Count Gap Days
Jul 1 Desawar 83 3 38 1 0
Jul 2 Desawar 47 7 74 2 1
This helps you spot trends quickly and build a strong database for analysis.
Bonus Tip: Cross-Chart Mapping
Try combining all markets into one visual to see how numbers bounce between markets.
Example:
Number Desawar Gali Faridabad Ghaziabad
83 ✅ — ✅ —
47 ✅ ✅ — ✅
This shows 47 is strong across 3 markets — a great guess candidate.
Chart-Based Guessing Strategy (Sample)
Pick Top 3 Most Repeated Numbers in last 7 days
Find Ending Digit Trends
Overlay Mirror Matches
Choose 1–2 Numbers based on strongest overlap
Avoid Any Number That Just Hit Yesterday (unless repeating behavior is strong)
Mistakes to Avoid
❌ Relying on Single-Day Patterns
One-day trends don’t mean much. Look for 3–5 day cycles.
❌ Guessing Without Cross-Market Comparison
You miss half the picture if you only study one market.
❌ Ignoring Gap Days
If a number hasn’t hit in 15+ days, it might be due soon. Include gaps in your analysis.
❌ Overcomplicating the Logic
Stick to 2–3 core patterns (ending + mirror + repeat). Too many variables = confusion.
- 이전글Are You Really Doing Sufficient High Stakes Poker Site? 25.08.23
- 다음글Betovis: A Comprehensive Overview of the Online Betting Platform and Access 25.08.23
