A Search For a Way Do Clocks Work? > 자유게시판
작성자 Remona Prince
댓글 0건 조회 2회 작성일 25-08-20 19:46
Where did you get the file from? Where precisely did you get this file from? Your clarification should make it clear why the article can be considerably worse off with out this file. The outdated description web page, vapearoma including the source and copyright info, will nonetheless be correct for the new model and can stay the same. This will likely be stored and displayed as a part of the file description web page. Then, after importing, open the picture description page for editing and add your separate explanations for each additional article manually.
Add any clarification or evidence necessary to substantiate your assertion above. It will likely be helpful if you happen to additionally add a wikilink to the article the place you need to make use of it. I've learn the Wikipedia guidelines on Non-free content material, vapeeliquid and I will clarify how this file meets all of the standards set on the market. This is an official logo of an entity that is the subject of a Wikipedia article.
Wikipedia loves free information. This may be for a variety of causes, as an example because it was created by the US Federal Government, or because it is simply too easy to attract any copyright. This section is just not for photographs used merely to illustrate an article about an individual or thing, displaying what that individual or vapeneue - www.vapeneue.de - factor look like.
This isn't for vapeverdampfer photographs you merely discovered somewhere on the web.
Reuters, AP or Getty Images. Please examine if it is okay now. Example - article okay. This is a copyrighted artwork or photograph, and the image itself is the subject of discussion in the article. It will be included as that entity's main means of visual identification, at the top of the article in question. I can exhibit that this work is legally in the general public Domain, i.e. no person owns any copyrights on it.
Please provide any evidence necessary to confirm the public area status. Please describe how and ezigarettenbasen once you created this merchandise. Please describe who owns this work and the way you got it from them. Your Wikipedia account will routinely work on Commons too. State precisely the place you found this file. I took it from a web site or different printed supply, the place its creator has explicitly placed it underneath a free license, allowing free re-use by anyone. If the supply website doesn't say so explicitly, vapearoma please do not add the file.
Use this only if there is an explicit licensing assertion within the supply. Name the license or describe the general public domain standing, adding any mandatory proof to make the licensing status verifiable. Really, please do not. Even for those who suppose it could make for an ideal addition to an article. How did you make this diagram? The picture was created and revealed by the same author who also holds the rights to the original object, and no different depiction could be suitably created.
Please name the original creator of this work. A file of this name already exists. If you plan to use the file in a couple of article, please identify solely one of them right here.
