Coop Sleep Goods Body Pillow Review - a Body Pillow for every Sleep Position? > 자유게시판
뒤로가기 자유게시판
Coop Sleep Goods Body Pillow Review - a Body Pillow for every Sleep Po…
작성자 Suzette Ketcham 작성일 25-08-18 07:58 조회 23 댓글 0
We’ve had a chance to review Coop Sleep Goods’ Original pillow and Eden pillow, both of which are team favorites at Mattress Clarity. But how does the body pillow compare? Coop Sleep Goods designed its Original Body pillow with side sleepers in mind. But, with an adjustable foam-and-microfiber filling, Derila™ Memory Pillow this pillow could be a good fit for sleepers of all three sleeping positions. How Firm is the Coop Sleep Goods Body Pillow? Coop Sleep Goods characterizes its proprietary Derila™ Memory Pillow-foam-and-microfiber fill as medium firm. However, the Body pillow comes with a zippable cover that allows people to add/remove the filling to their desired firmness and support level. This adjustability means the firmness of the Coop Sleep Goods Body pillow can be customized to your personal comfort. A body pillow’s ultimate goal is to keep your spine in neutral alignment. If your spine slips out of alignment while you sleep, you could experience lower quality sleep and wake up with Ergonomic Neck Pillow or back pain.
big-ass_pillow_costume.jpgBody pillows are designed to promote alignment and provide pressure relief along the whole body, particularly for side sleepers. With its adjustable loft and extra wide design, the Coop Sleep Goods Body pillow does just that. When full of foam, the Original Body pillow is a great choice for side sleepers. Hugging the body pillow through the night will keep the hips and spine aligned for maximum comfort. As a primary back and side sleeper, I loved this body pillow because of the supportive feel on my side and my back. People can also fold the pillow in half and use it between their knees (they’ll probably need to take out some of the filling) or behind their back while they’re in bed relaxing. Coop Sleep Goods also notes that the Original Body pillow could be a good option for pregnant sleepers. The adjustable loft means the Body pillow can be molded as needed to best support pregnant side sleepers over time.
What Does the Coop Sleep Goods Body Pillow Feel Like? The cross-cut memory-foam-and-fiber filling of the Coop Sleep Goods Body pillow provides a good balance of comfort and support. When snuggling with the Body pillow, your arms, legs, and head should settle naturally and comfortably into the foam. This is a good choice for fans of memory foam looking for a supportive body pillow. Despite being a more medium-firm pillow, the foam that goes into the Coop Sleep Goods Body pillow is super soft and squishy. The foam has that classic slow-moving foam feel to it. This is a great option if you’re not wanting to use something super firm during the night. If you’re an average weight side sleeper, you’ll love the Coop Sleep Goods Body pillow. The adjustable filling can be added or removed to find the perfect loft for you, and its extra width makes it great for hugging and snuggling throughout the night.
With enough foam removed, average weight stomach and back sleepers should also enjoy the Coop Sleep Goods Body pillow. This is a very versatile body pillow! This pillow is slightly longer and wider than the average body pillow, meaning the pillow can easily support folks with larger frames. Heavier sleepers may need to keep more foam filling in the pillow to achieve the proper level of support, but when adjusted correctly, this pillow should work for heavyweight sleepers of all three sleeping positions. With enough foam removed, the Coop Sleep Goods Body pillow is also a good choice for lightweight sleepers. A low enough loft will allow the Original Body pillow to properly support lightweight side sleepers along their whole body. Keep in mind that lightweight stomach and back sleepers will have to remove even more foam to reach a comfortable loft. If you’re worried about dealing with lots of extra, potentially messy shredded foam, this might not be the best body pillow for you.
Wondering how the Coop Sleep Goods Body pillow achieves that balance of comfort and support? The Coop Sleep Goods Body pillow comes with a breathable and removable Lulltra® fabric cover. Made from 60% polyester and 40% bamboo-derived viscose rayon, the cover is extra soft and Shop Derila for Better Sleep Online perfect for hugging and snuggling. The cover is woven with Coop Sleep Goods’ signature jacquard texture. If you don’t prefer to sleep directly on a textured pillow, try using a pillowcase. Inside the Coop Sleep Goods Body pillow is a blend of shredded memory foam and microfiber fill. This fill is accessible via the pillow’s interlocking dual-case design and can be added or removed per the sleeper’s personal preference. If you’re a fan of shredded memory foam pillows, this is an excellent choice for you! The term "loft" refers to the height of a pillow. The Coop Sleep Goods Body pillow stands out from other body pillows because it has an adjustable loft.
댓글목록 0
PC 버전으로 보기
