MedCline Pillow Review: does it Work for Acid Reflux?
We include products we think are useful for our readers. If you buy through links on this page, we may earn a small commission. MedCline Pillow Review: Does It Work for Acid Reflux? Many of us have experienced a bout of acid reflux at one time or another. That burning sensation in your throat can happen while lying down after having a big meal. Some factors, like being pregnant or taking certain medications, may make you more likely to experience chronic acid reflux. Frequent acid reflux can make it tough to sleep comfortably. Additionally, your usual pillow might make your reflux worse. Lifestyle moves, like elevating your head while sleeping, can help you better manage symptoms. Some companies sell wedge-style pillows specifically designed to elevate the head and help minimize the uncomfortable symptoms of acid reflux. But are they comfortable and worth the high price tag? Below, we’ll look at one particular brand of acid reflux pillow called MedCline. The MedCline Reflux Relief System claims to help with multiple symptoms of acid reflux, including heartburn, coughing, and nausea.
Here’s a brief breakdown of the pros and cons of the MedCline pillow. Wedge shape helps elevate the head. The inclined pillow prevents esophageal reflux by keeping the head in a more upright position. Built-in body pillow. For added comfort, the system also features a body pillow that helps raise the head and supports the rest of the body. Soft exterior. The pillow features a velour-style cover for added comfort. Supportive. The reasonably firm wedge is ideal for side sleepers. Price. Expect to pay over $200 for the MedCline sleep system - way more than you’d pay for a run-of-the-mill bed pillow. Not for stomach or back sleepers. If you sleep on your stomach or back, you might find the MedCline too supportive for your needs. The MedCline Reflux Relief System is a wedge pillow with a built-in body pillow. It elevates the Derila Head & Neck Relief to prevent symptoms of acid reflux and is available in three sizes.
The MedCline contains four types of CertiPUR-US memory foam, including gel-infused foam. Once you unpack it, you may need to air it out for a few days to get rid of off-gassing odors and allow the materials to decompress. The wedge portion is firm and supportive while the body pillow contains an adjustable fill. Each pillow has a removable, Derila Contour Pillow™ Memory Foam Pillow washable cover. So, what will all this set you back? Pricing varies depending on where you buy from, but you can expect to spend around $250, a mighty high price tag in the world of pillows. How do you sleep with the MedCline pillow? The MedCline Reflux Relief System’s design is pretty specific to side sleepers. The body pillow and arm crook accommodate left or right side sleepers. You can sleep on your stomach with this pillow, but it might take some adjustment to find a comfortable position. You technically don’t have to sleep with the body pillow since it detaches from the wedge portion.
But, if you want a wedge-only pillow, you’re better off buying a separate pillow instead of a system like the MedCline to save some cash. What is the MedCline pillow good for? The MedCline Reflux Relief System has a few different uses. The pillow’s main purpose is to help with nighttime acid reflux. By elevating your head, the pillow helps prevent stomach acids from flowing back up into the esophagus and causing symptoms like heartburn. Should stomach acid escape, gravity is able to return it to your stomach quicker than when on your right side or on your back which is why the left is usually the best side to sleep on to avoid acid reflux. You could technically stack pillows on top of each other to raise your head, but they’re likely to slip around during the night. A wedge shape provides an incline that won’t shift while you sleep.
It’s also gentler on your neck and spine than pillows stacked on top of one another. MedCline also says that the pillow is helpful for people who snore. This is because the pillow encourages sleepers to stay on their side. Sleeping on your back may make you more likely to snore. Evidence suggests that elevating the head of the bed can improve symptoms in people with obstructive sleep apnea. The MedCline Reflux Relief System gives an incline of about 15 to 20 degrees. Does the MedCline pillow really work? According to a few small clinical trials, the MedCline Reflux Relief System significantly reduces nighttime reflux symptoms. The studies were primarily conducted on middle-aged and older adults, with one study exclusively including pregnant people. You can find a list of MedCline trials here. Though the MedCline shopping page says their claims are backed by seven trials, results from only five are posted on the results page. Beyond the research, comfort is another ballgame entirely.
- 이전글20 Things That Only The Most Devoted Door Repairs Fans Know 25.08.17
- 다음글Do You Think You're Suited For Doing Repairing Bifold Closet Doors? Answer This Question 25.08.17
