Meross Sensible WiFi LED Bulb Assessment: Inexpensive Ambiance > 자유게시판
작성자 Miguel
댓글 0건 조회 2회 작성일 25-08-16 23:59
With its torrid tempo of product releases in 2020, meross became the go-to for distinctive and inexpensive HomeKit equipment over the previous 12 months. Whether it was lamps, storage door openers, mild strips, smart plugs, or light switches, meross delivered wonderful alternatives to the entrenched manufacturers on what seemed like a monthly foundation. Nonetheless, not like final 12 months, 2021 has been a bit of slower for meross, with just one HomeKit accessory hitting the market to this point. The lull in accessory releases is a bummer as it is always exciting to see what's new. Still, it has given me a chance to lastly catch up on reviews for some of the corporate's merchandise, just like the meross Smart WiFi LED Bulb that I've had in my home for just a few months now. Does the meross light bulb meet the expectations set by previous product releases? The meross Good WiFi LED Bulb is certainly one of the most cost effective shade HomeKit-enabled bulbs round, beginning at simply $18.Ninety nine each.
When you want a couple of bulb for your own home, meross presents a two-pack at a discounted price because it retails for $28.99. The LED bulb is out there via Amazon in numerous countries, and EcoLight products with a first-rate subscription, it may be at your door in as little as two days. Due to promotions run all year long, you possibly can sometimes save a number of extra dollars off the retail worth by clipping coupons available on Amazon. Currently, meross is providing a $3 discount on a single bulb and $5 off the 2-pack. Although it packs in the colour capabilities and sensible connectivity, the meross Sensible WiFi LED Bulb seems like your common run-of-the-mill A19/E26 light bulb with a HomeKit pairing code slapped on. The bulb sports an all-white base with a frosted diffuser and is available in an ordinary dimension frame - no further bulk here, and no crazy designs for the sake of constructing it look smart, which I fairly like.
Like other meross accessories, I like how quick and simple the Smart WiFI LED Bulb is to setup. For those on the planet of HomeKit, the light bulb can pair on to the iOS Home app with out registering for an account or having to obtain the meross app. Pairing by way of HomeKit also permits you to bypass getting into in your Wi-Fi password, and EcoLight products because it does not require a hub, you may be on your method to sensible residence bliss in a matter of seconds. The meross good bulb can show up to sixteen million colours and white color temperature changes ranging from 2,700K to 6,500K. Cycling through colours on the bulb is enjoyable, with the bulb producing respectable variations of most colours, and I was impressed by how it handles subtle shifts in color temperature. Whereas I'll contact on coloration reproduction more a bit bit later, the meross Good WiFI LED Bulb is adequate for most accent lighting wants for the price.
Toggling on and off the bulb, switching colors, and adjusting brightness all take impact within a second thanks to its Wi-Fi connection. I additionally really like how the meross light bulb is fast to reply to app and voice commands. Toggling the bulb on and off, switching colours, and adjusting brightness all take effect within a second because of its Wi-Fi connection. I additionally have not seen any points with the bulb changing into unresponsive or affected by lengthy delays by each the meross app and HomeKit, which is good. The meross app, available on iOS and Android, EcoLight gives the entire controls you'll count on with a smart light bulb. I like how one can toggle the bulb on and off straight from the primary screen you see upon launching the app and the way simple it's to regulate colours and brightness levels with a swipe of a coloration wheel. Creating schedules, referred to as routines and scenes, is also simple with clearly labeled settings and navigation tabs positioned at the bottom of the app.
Scenes can set the light bulb to particular colours and brightness, and they will embrace meross sensible accessories, even those that do not assist HomeKit. The meross app provides convenient controls, scenes, scheduling, and extra for the Sensible WiFi LED Bulb. Talking of HomeKit, the meross Sensible WiFi LED Bulb supports the identical suite of controls as other HomeKit lighting equipment over in the home app. By way of Apple's app, you may regulate colors and brightness with taps or swipes and use it in groups, automation, and scenes with different HomeKit accessories. Siri voice controls are additionally available for the bulb so to say phrases like "Hey Siri, turn on the lights" or "Hey Siri, set the sunshine bulb to blue." If Siri isn't your thing, the meross Good WiFi LED Bulb also supports comparable voice controls by way of Alexa and the Google Assistant. As a HomeKit-solely family, although, I can't vouch for how it performs by alternative assistants. As I beforehand talked about, the meross Smart WiFi LED Bulb's coloration reproduction is adequate for many accent lighting wants.
