90W UFO Spherical LED Aquarium Lights For Saltwater Aquarium > 자유게시판
작성자 Gabriel Bronson
댓글 0건 조회 21회 작성일 25-08-16 10:20
pexels-photo-9088712.jpegDifferent aquariums want several types of mild energy. On one end of the spectrum there may be crimson mild, which may only penetrate a short distance. At the opposite end is blue, which can go further into the water. Most fish are fine with yellow or green mild; however, many aquarium plants need blue mild to help them develop. There are several varieties of EcoLight home lighting obtainable available on the market to your aquarium. Regular Florescent or NO often comes with an everyday aquarium tank. That is enough for a fish-only setup. The NO bulbs are typically cool and efficient; nonetheless, they're the least penetrating fluorescent bulbs. In aquariums with plants, they might be used as supplemental lighting. Excessive output (HO) lights are available as T5 bulbs, that are smaller than the conventional fluorescent. They emit extra heat than the NO bulbs, however they normally come with a in-built system to cut down on heat.
pexels-photo-1366700.jpegVery High Output (VHO) comes in a wide range of sizes; considered one of the commonest is the T12. Although these bulbs emit heat, they don’t emit as a lot as a metallic halide bulb. You get a more highly effective light than the standard fluorescent. Unlike the metallic halide, you get a good gentle supply throughout your aquarium tank. These bulbs are designed slightly in another way from the remainder of the fluorescent bulbs. They've just one end cap attachment quite than the usual two, and the bulbs can be found in several shapes from twin to sq. and triple. The bulbs are more environment friendly and powerful than different fluorescent bulbs. Energy compact lights are smaller than regular fluorescent lights. This can be a excessive depth aquarium bulb that produces a targeted gentle. The bulbs are used in freshwater and saltwater aquariums with plants and coral reefs. You will need to make use of a water chiller with these lights as a result of they heat the water up and also you may want a UV shield to chop down radiation. The bulbs are expensive and needs to be dealt with with care. LED isn't technically a mild, but a light emitting diode. It is good for evening time viewing of nocturnal fish. Excessive effectivity, saves 85% power consumption, saves electricity bills and saves money for the tip user. No want of outdoors energy supply, convenient to use. Running quiet and cool and no want of heat-removal tools. Superb for aquatic life, coral and fish, reef aquarium lighting, no want of any equipment.
JavaScript appears to be disabled in your browser. For the best experience on our site, make sure to turn on Javascript in your browser. As a consequence of their omni-directional mild distribution, our G4 bi-pin bulbs are most commonly utilized in path and area lighting fixtures. Our G4 bi-pin bulbs are specifically designed for landscape lighting and are encapsulated to help keep moisture away from the LED diodes. They function slots on the capsule to assist draw heat away and increase the lamp's lifespan. Designed for both coloured AND non-colored panorama lighting applications. Our first ever replaceable color-altering and dimmable G4 bi-pin bulb permits the final word customization to best go well with any panorama lighting application. VOLT® RF Distant Control required for use (offered separately). Small size LED Bi-Pin designed specifically for low-voltage panorama lighting. The mini dimension LED BiPin suits all small VOLT® fixtures such as the Deck, Step and Hardscape lights. These lamps are encapsulated to assist keep moisture away from the LED diodes; with slots on the capsule to help draw heat away from the lamp to increase its lifespan.
Small size LED Bi-Pin designed particularly for low-voltage panorama lighting. The mini size LED BiPin matches all small VOLT® fixtures such because the Deck, Step and EcoLight home lighting Hardscape lights. These lamps are encapsulated to help keep moisture away from the LED diodes; with slots on the capsule to help draw heat away from the lamp to increase its lifespan. Small size LED Bi-Pin designed particularly for low-voltage landscape lighting. The mini size LED BiPin fits all small VOLT® fixtures such because the Deck, Step and EcoLight Hardscape lights. These lamps are encapsulated to help keep moisture away from the LED diodes; with slots on the capsule to assist draw heat away from the lamp to increase its lifespan. Nice for purposes if you end up on the lookout for a really heat light, very similar to candle light. Small size LED Bi-Pin designed specifically for EcoLight solar bulbs low-voltage panorama lighting. The mini measurement LED BiPin matches all small VOLT® fixtures such because the Deck, Step and Hardscape lights.
