Everyday Uses For PVC Water Pipe > 자유게시판
작성자 Glory
댓글 0건 조회 4회 작성일 25-08-14 21:38
watch?v=L4Rht_xxhykWhat can't you do with PVC (Polyvinyl Chloride) pipe? The ubiquitous blue PVC water pipe can be seen alongside most streets here and appears to be one in all Thailand's most ample un-pure assets. A wide variety of various connectors can be found and aside from carrying water it is usually used as an affordable building material that can be used to make all the things from clothes dryers to Wheel chairs (PDF), Crutches, flagpoles and shop indicators. Of course on the web you can too find another very cool and artistic issues made from (non-blue) PVC pipe including: Halloween costumes like Ben Hallert's Matrix APU and Aliens Exo-skeleton Power Loader, one other power loader costume, single and multi-guitar Guitar Hero stands, a laptop computer stand, flutes, and even a shaving stand. Below one can find, in chronological order, some of my own (mostly unique) creations made from PVC water pipe together with: - a Marshmallow Shooter, Plumbing, Soccer Goals, - a Cricket Wicket, - a Basketball Hoop, Bookshelf Supports, Zone Defender - a Water Pipe Tron Controller, Racing Cars, Pinball Table Leg Extensions, Data Projector Mounts, - a Laptop Stand, - a Wiimote Holder, - a DIY Wii Zapper, - a Workbench, Real-Tron Controllers - a Music Stand Puzzle Bobble Coffee Grinder Controllers, - a Netbook Treadmill Hook, CD/DVD Holders, Zone Defender - a Nightstand/shelves, - Push Up Bar/Handles, Fake Legs, - a Hilbert Cube, - a Mario Kart steering wheel, - a Guitar Stand, Hockey Sticks, - a Tank-recreation (BZFlag) controller, - a Train Whistle, and - a Trident.
watch?v=IZJ0jX3sLEgThis was the undertaking that began my love affair with blue PVC pipe. I had seen the blueprints for this marshmallow shooter whereas I used to be in Australia but the fittings were prohibitively expensive (see the image right). Fortunately they are very affordable here in Thailand. 2 x T-Pieces and 6 x elbows. Cricket (not to be confused with Brockian Ultra-Cricket) is Australia's national sport played with a bat, a ball, and two wickets. 6 x T-pieces, and 12 x 45-degree elbows. The backboard is a non-regulation measurement piece of plywood that we found lying round and we used inexperienced duct tape for the markings. Although the ring isn't sturdy enough to hang off, the side supports make it strong sufficient for normal play. They also give it a really Star Trek feel and I feel the ring seems to be not in contrast to the NCC-31911 Saratoga. This is maybe the most straight forward use for PVC pipe on this web page. 2 x 25mm to 18mm (1" to 1/2") reducers, 2 x custom motorbike hand-grips, four x push-buttons, and a mercury switch which are related to a computer through a hacked USB joystick.
You will discover extra details about how I made the controller on this venture web page and Zap Zone Defender Setup i've also prolonged the same concept to play GL-Tron utilizing actual motorbikes. A college student who performed with the PVC Water Pipe Tron Controller, Zone Defender described above, stated "That's Ok however I prefer to play driving games". It got me thinking and over the subsequent week I spent my evenings constructing a PVC racing car controller - basically a wheel-less, PVC go-kart frame linked to the pc by way of a hacked USB joystick. Some Thai university students who saw the first car needed to know the way it all labored and 6 of them came around one Saturday and we spent the whole day hacking joysticks and building a second automotive. By connecting them each to a laptop and a knowledge projector we were in a position to play cut up-display Daytona USA. You'll find more details concerning the design and construction of the automobiles on this challenge web page. The white office table I used for the digital pinball machine wasn't excessive enough to be performed comfortably.
1 x T-piece, and Zone Defender 2 x elbows - partially to help air stream but principally to carry my display up as a result of the spring within the hinge has broken. As straightforward as this stand seems, the "L"-formed upright part is definitely part of an air-conditioner mount for an information projector that I made for one of many virtual pinball table installations. The T-piece isn't glued and so in a small means (a really, very small means) I prefer to suppose that if the air-conditioning mount were ever needed again then the elements could re-combine in a Voltron or Captain Planet and the Planeteers or Power Rangers MegaZord-like manner. After all if that happened my laptop computer display screen would fall down. I do not personal a Nintendo Wii however I did manage to get my hands on a Wiimote so that I may try out a few of Johnny Chung Lee's cool projects. It is a Wiimote mount I built using a length of 35mm (1 and 1/4") pipe, some 18mm (1/2") pipe, three x T-pieces, and 4 x elbows.
The 35mm pipe has been minimize so that it fits properly into the ridges down the aspect of the Wiimote which holds it securely. This is screwed onto a T-Piece which has additionally had its top minimize off. The joint between the two topmost elbows shouldn't be glued so the angle of the top section can be adjusted. These sections are merely cable-tied onto the entrance of the motorbike handlebars and the gamers squeeze the buttons with their index fingers to show left or proper. A mercury swap is also mounted on the best handlebar so the accelerator can be used to offer boost within the sport and as much as four bikes may be connected to the computer through a single hacked USB joystick. The centerstands keep the bikes upright during play and a half-round of bamboo is wedged beneath the back tires to stop them from rocking. This can be a music stand made from three completely different sizes of pipe.
