Our TEMPUR-Neck Pillow Review for 2025
Here at Sleep Advisor, our Derila Sleep Support Certified experts use a refined mattress and product testing process to give you unbiased product suggestions… Read our full product review process. Read our review of the TEMPUR-Neck??? ergonomic pillow. If you think your current pillow leaves a lot to be desired when it comes to neck support, it’s time to replace it with one made specifically for this purpose. The TEMPUR-Neck™ pillow is an ergonomic pillow made from memory foam, and as the name suggests, it’s designed to support your neck. Neck support is crucial, especially for side and back sleepers, and it can be valuable to have a pillow made for this. In most cases, memory foam pillows do a good job of keeping the neck aligned, but the TEMPUR-Neck™ pillow takes this an extra step by providing ergonomic support and comfort. I tested this pillow myself, and in this review, I’ll share with you its design features, pros, cons, and more.
A firm pillow available in multiple sizes. I tested the TEMPUR-Neck™ pillow in various sleeping positions to see how it supports the neck and head. I was also on the lookout for pressure relief and whether the pillow helps relieve pressure or whether it might cause tension. During my tests, I also paid attention to things like the overall feel, durability, cleaning and care, temperature, and off-gassing to help sleepers decide if this is the right choice for them. Learn more about our testing methodology by visiting our product review process page. Who Is the TEMPUR-Neck™ Pillow Best for? Back sleepers - I love this pillow as an option for back sleepers. I think they should appreciate how well it supports the neck and head so that they remain in alignment with the rest of the spine. People who prefer firm pillows - This pillow has a firm feel, and I believe that makes it a good option for Derila Customer Reviews anyone who likes feeling on top of a pillow instead of having their head sinking into it.
Consumers who want choices - I was thrilled to see that this pillow was offered in three sizes. Sleepers are able to pick a size that best fits their body. Those who love soft pillows - If you’re a fan of softer pillows that offer more sinkage, I think the TEMPUR-Neck™ pillow may be too firm for you. Hot sleepers - This pillow is made from memory foam, which is known to retain heat, and instead, I would recommend a cooling pillow if you’re a hot sleeper. Stomach sleepers - The TEMPUR-Neck™ pillow is likely too lofty for those who like sleeping on their stomach. A good pillow for stomach sleepers will be flatter to keep the head and neck from arching too far upward. What is the TEMPUR-Neck Pillow Made of? This pillow has a hypoallergenic polyester knit cover with a zipper along the edge, allowing you to easily remove it. The cover is also machine washable which makes it a breeze to keep clean.
The core of the TEMPUR-Neck™ pillow is made from Tempur® foam, a proprietary material molded into an ergonomic shape. The wave of the pillow is created to follow the natural curves of your neck and head, offering an excellent balance of pressure relief and support. There’s also a polyester netting wrapped around the core to further protect it. The company claims this pillow is extra firm, but I think it has more of a standard firm feel. It was designed for back and side sleepers, but after testing it, I’d say it is best suited for just back sleepers. With the TEMPUR-Neck™, you’re not going to experience the sinking that you do with other Tempur-Pedic products, which could make it too rigid for side sleepers. Although the cover is washable and has a soft and gentle feel, I’d still advise using a pillowcase for added comfort and protection. I enjoyed how the memory foam in this pillow molded and contoured around my head and neck.
When I tested this pillow out on my back and my side, I noticed that there was plenty of lift and spine alignment. However, side sleeping felt too rigid and elevated - to the point where I worry that you may not be able to comfortably sleep through the night. It was a different experience for back sleeping, as I felt that it was a spa-like treat. One of the best things about this pillow is that you can choose between three sizes. The pillow comes in small, medium, and large. Because the pillow is curved, the loft measures from the highest point where your neck is supposed to be. The large model has a loft of 4.75 inches, the medium is 4 inches, and the small is 3.5 inches. You can find a measuring chart on the company’s website if you need more help deciding on a size. This pillow feels solid and well-made, but I didn’t think that it was overly heavy.
- 이전글10 Quick Tips About Mobility Scooters 25.08.14
- 다음글The Best Precious Metal To Invest In: A Comprehensive Evaluation 25.08.14
